0 Replies Latest reply on Mar 28, 2017 3:09 PM by jfbertrand
    PhoneGap Build - Code signing is required for product type 'Application' in SDK 'iOS 10.1'
    jfbertrand
      0 down vote  favorite
      I am building an Ionic app and I ran into a few issues trying to use PhoneGap Build to build my iOS version of it. I am developing using Visual Studio on a Windows 10 machine. I have both platforms installed (iOS and Android), and of course the Android build works just great.
      I went to developer.apple.com and created my certificate and provisioning profile. I can use those to create the p12 file and create the key in PhoneGap Build. Then the fun starts. Here is the summary for the build-release.xcconfig file
      ARCHS = armv7 arm64
        CLANG_ALLOW_NON_MODULAR_INCLUDES_IN_FRAMEWORK_MODULES
      = YES
        CODE_SIGN_ENTITLEMENTS
      = /tmp/gimlet/1121295/project/app.entitlements
        CODE_SIGN_IDENTITY
      = iPhone Distribution
        CONFIGURATION_BUILD_DIR
      = /tmp/gimlet/1121295/project/build
        CORDOVALIB
      = /tmp/gimlet/1121295/project/CordovaLib
        DEVELOPMENT_TEAM
      = 6US3xxxx5
        ENABLE_BITCODE
      = false
        HEADER_SEARCH_PATHS
      = "$(TARGET_BUILD_DIR)/usr/local/lib/include" "$(OBJROOT)/UninstalledProducts/include" "$(OBJROOT)/UninstalledProducts/$(PLATFORM_NAME)/include" "$(BUILT_PRODUCTS_DIR)"
        IPHONEOS_DEPLOYMENT_TARGET
      = 8.0
        ONLY_ACTIVE_ARCH
      = NO
        OTHER_CODE_SIGN_FLAGS
      = --keychain /tmp/gimlet/1121295/secure.keychain
        OTHER_LDFLAGS
      = -ObjC
        PROVISIONING_PROFILE
      = ba85b501-xxxx-xxxx-xxxx-cfd0d1950e70
        SWIFT_OBJC_BRIDGING_HEADER
      = $(PROJECT_DIR)/$(PROJECT_NAME)/Bridging-Header.h
        TARGETED_DEVICE_FAMILY
      = 1,2
      and here is the config.xml header
      <widget xmlns="http://www.w3.org/ns/widgets"
      xmlns:cdv="http://cordova.apache.org/ns/1.0"
      xmlns:gap = "http://phonegap.com/ns/1.0"
      id="com.golfgameskeeper.*"
      version="4.0.001"
      versionCode="40001">
      <name>MyAppName</name>
      As far as I can tell this is correct, however my build fails with this error:
      Check dependencies
      myAppName requires a provisioning profile
      . Select a provisioning profile for the "Release" build configuration in the project editor.
      ** ARCHIVE FAILED **
      I have tried creating a build.json but that didn't work. I made sure my provisioning profile matches the id in the widget header, that didn't work.
      I will appreciate any kind of help.
      Thank you,
