I was wondering how you can open the same file twice so that you can position one window at one point in the file and the other window in another part. Ideally, it would be best to somehow split the code view pane for the file so that you can go to one part of the file in one window and another part of the same file in the other window.
I've tried undocking the pane, but that just creates a floating pane. If you try to open the same file, it doesn't do anything because it is already open.
This is for Dreamweaver CC 2017.0.1
ADVthanksANCE,
Vik
In DW CC 2017, there is an option of code-code view which allows you to have code view split in 2 windows.
This option is available under View menu > Split Views > Code code.
Do check that out, should be helpful.
Lalita
Lalita
Thank You Lalita. That was exactly what I needed!
Best,
Vik
