1. Re: GPS METADATE
johnrellis Mar 29, 2017 8:11 AM (in response to habana1959)1 person found this helpfulTo test my understanding: Your camera is recording GPS location in photos but it's not showing up in LR. Some troubleshooting steps:
1. Does the location appear in the GPS field of the Library's Metadata panel, as shown here:
If it does appear, then describe in more detail what your issue is.
2. If it doesn't appear in the Metadata panel, then in the Import window, make sure that Apply During Import > Metadata is set to None, and then import a fresh photo never before imported into LR:
3. If that doesn't help, upload a fresh photo right from the camera to Dropbox or similar and post the sharing link here. We can verify that it has GPS location that LR can properly import.
2. Re: GPS METADATE
ChaeeBokaa Jun 2, 2017 10:56 AM (in response to johnrellis)Hi,
I am facing an issue on similar lines... I can see GPS metadata in LR but after export, GPS data is not present in the exported JPEG.
I already ensured to tick off 'Remove Location Off' and 'include all metadata' on the export option. Above settings are already ensured to be in place but still GPS metadata is not exported to JPEGS.
Please help and let me know if you need any other details on this.
Amit
3. Re: GPS METADATE
johnrellis Jun 2, 2017 11:02 AM (in response to ChaeeBokaa)See my reply to your other post: Re: GPS data are not exported
4. Re: GPS METADATE
Richardok Aug 23, 2017 10:26 AM (in response to habana1959)This has been helpful in part, however how do I set other metadata like copyright, name, email address etc as a preset with out it deleting the GPS coordinates? LR used to allow the preset on import to set copyright, name, email address etc and retain the camera GPS metadata.
5. Re: GPS METADATE
johnrellis Aug 23, 2017 11:20 AM (in response to Richardok)1 person found this helpfulHow do I set other metadata like copyright, name, email address etc as a preset with out it deleting the GPS coordinates? LR used to allow the preset on import to set copyright, name, email address etc and retain the camera GPS metadata.
Edit the import metadata preset and make sure these three checkboxes are unchecked:
6. Re: GPS METADATE
Richardok Aug 23, 2017 11:28 AM (in response to johnrellis)Perfect, thanks for the help
