Buenos dias, me llamo jose,
he instalado el photoshop cc 2017, y mi sorpresa es que en guardar como, nno puedo guardar en la carpeta que quiero o crear carpeta,
si dentro de una carpeta tengo otra, por ejemplo, si tengo una carpeta llamada book juan, y dentro de esa otra que sea " retocadas" no me da opcion de guardar ahi los ficheros
Gracias de antemano
(Discussion successfully moved from Photoshop Lightroom to Photoshop General Discussion)
ayukito wrote
Good morning, my name is jose,
I have installed the photoshop 2017 cc, and my surprise is that save as, n I can save to the folder I want to or create folder,
If within a folder I have another, for example, if I have a folder named John book, and within that one that is "retouched" does not give me option save files there
Thanks in advance
What operating system are you using? Photoshop should work the same as your operating system regards file handling.
Which operating system are you using?
Do you not see something like below (this is Photoshop CC2017.0.1 on Windows 10)
Dave
