• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Trouble with Canon XF100
New Here ,
Mar 29, 2017 Mar 29, 2017
Hi
I have recorded several videos on a Canon XF 100 and can view the footage using the canon utilities software. However, I cannot upload the video from the card reader to Premiere Elements 11
I have tried using the following route + Add Media then selecting Videos from Flip or cameras
The Canon XF comes up in the source menu but in the window below the following message appears
This device does not contain any supported media
What am I doing wrong?
Views
757
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
I know nothing about that camera, so I'm guessing.  (Also, by responding it bumps to the top of the list!  Others may know what you need.)
The "MPEG-2 4:2:2 50Mbps Codec (Canon XF Codec)" may be a little too advanced for the older version of Premiere Elements you are using.   It may not be compatible with the newest version of PrE either!   Canon is big enough that sometimes they go their own way with some things like codecs.
A second possibility is that if you can find the MPEG-2 files on your card, copy them to you computer with Windows Explorer or Apple Finder and then "Add Media" from "Files and Folders".
A third possibility is that, if it is a compatibility problem, you can convert the original format to something more universal with the shareware program called Handbrake.
If you're inclined, you could post a clip on DropBox (or equivalent) where I could download and try it with my computer.
Good luck with your project.
Bill
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
I have the same camera.
Elements on windows does not support .mxf.
If you change the extension to .mpg you will be able to import (uploading means transferring files from pc to internet).
Use the xf utitlity to export to mxf first then change the extension.
The Mac has no problem importing the mxf files.
I am not sure for E11 but this method works in E14 and E15.
Votes
Translate
Translate
Report
Report
