So I have a .ai file with many layers on separate 1920x1080 artboards; what I need is a script to export every top layer into a separate .ai file on a single 1920x1080 artboard (so I can later fix/import into AE)
*Here is a base Script* Can someone help me edit this? As this script only creates new AI files with all the same artboard/layers; but just hides the ones I don't need.
//////////////Start
var doc = app.activeDocument;
if (documents.length > 0){
// Create the illusrtratorSaveOptions object to set the AI options
var saveOpts = new IllustratorSaveOptions();
// Setting IllustratorSaveOptions properties.
saveOpts.embedLinkedFiles = true;
saveOpts.fontSubsetThreshold = 0.0
saveOpts.pdfCompatible = true
if (doc.saved==false) doc.save();
for (i=0; i<doc.layers.length; i++)
if (doc.layers.locked == false) doc.layers.visible = false;
fullDocName = doc.fullName;
var param = doc.name.split('.');
realDocName = param[0];
for (i=0; i<doc.layers.length; i++){
if (i-1<0) doc.layers.visible = true;
else {
doc.layers[i-1].visible = false;
if (doc.layers.locked == false) {
docName = realDocName+doc.layers.name+".ai";
var saveName = new File ( doc.path + "/" + docName );
doc.saveAs( saveName, saveOpts );
doc.close(SaveOptions.DONOTSAVECHANGES);
doc = null;
app.open (fullDocName);
/////////End
Questionable link removed by moderator.
