1 Reply Latest reply on Mar 30, 2017 12:25 AM by Laubender
    Save frame as jpg whthout contour
    robertm43450875
      Hi
      How can i save frame witout contour.
      For example:
      1. remember contour thickness
      2. set contoru thickness = 0
      3. save frame as jpg
      var exportFile = new File('d:\\test.jpg');
      graphics[i].parent.exportFile(ExportFormat.JPG, exportFile);
      4. restore contour thickness
      Thanks for advice
        • 1. Re: Save frame as jpg whthout contour
          Hi Robert,
          as Karti already pointed out here:How can i change rectangle contour the property is strokeWeight.
          FWIW: Setting the strokeWeight to zero, export and resetting the strokeWeight to its old value is no good idea.
          You would have to memorize all other properties of a stroke to make that work without issues.
          What could go wrong? The color of the stroke could change after resetting the weight.
          And some other properties of a stroke could be changed as well.
          What can go wrong will depend ( for example ) on the activate object style in the Object Styles panel.
          Too much to memorize…
          So I would do it differently.
          Do a duplicate of the graphic container and work with that.
          Reset strokeWeight of the duplicate to 0 .
          Export the duplicate.
          Remove the duplicate.
          See Jongware's resource for older versions like CS5.5:
          Indesign JavaScript Help
          Regards,
          Uwe
