Hi there
I'm new to After Effects so there may be an easy fix for this but i can't find on the forums.
When I open After Effects and I have on my headphones (that are synced to my computer via bluetooth) I can hear myself back. The microphone has been enacted somehow. Is there a reason for this with AE?? How do I stop this from happening?
I have gone to settings and checked the audio and my headphones are selected as the output source but that doesn't explain the microphone sound?? I know it is After Effects because when I quit it straight after opening, the microphone is turned off.
i'm using
V 14.1.0.57
Any explanation to this mystery would be appreciated.
Alex
UPDATE: It looks like it's my MacBook Pro rather than the program. It has something to do with the keyboard dictation. It does it as well when iMessage sends me a text message. I haven't figured out how to stop it coming through bluetooth headphones but I'm on the Apple Forums to see if I can get an answer there 🙂
That sounds odd. I would expect the mic to be needed for Character Animator, but not for After Effects. That's really weird. You might consider filing a bug report.
Same problem with mine. Does the same thing. CRAZY annoying.
Contact Adobe support and please let us know what they suggest and if it worked.
Hi Roaring Dog,
Can you check the issue with wired headphones? See if that works and report back.
Kevin
I'm working this bug out through Apple as I think its a flaw with the keyboard dictation setting on my Mac. Did you find a solution yet? I'll let you know what I find out 🙂
