2 Replies Latest reply on Mar 30, 2017 6:53 AM by openskies2009
    Saving PSB Files
    openskies2009 Level 1
      I have nearly a 2GB psb file that I need to save to JPEG or PSD. When I try it takes more then thirty minutes just to merge layers before it actually saves.
      Moving the scratch disks and the psb file itself onto my internal SSD drive woudl speed up the process? What are some other operations I can try?
        • 1. Re: Saving PSB Files
          Trevor.Dennis Adobe Community Professional (Moderator)
          How big is the file in pixels, and how many layers does it?
          What sort of content does it have? Mostly raster, or Type and other vector layers?
          Check your primary Scratch drive for a current 'Photoshop temp...' file.  How big is that file, and how much free space is there on that drive?
          What is the spec of the computer you are using?  CPU, RAM, GPU, Drives? It might be easier to open Photoshop and go Help > System info > Copy and paste to this thread with Ctrl v
          What will you be using this file for?
          Will it be printed, or what?
          • 2. Re: Saving PSB Files
            31 x 70 inches / 25 layers
            Raster. I couldnt find the temp location.
            Free space 50GB.
            This is going to be used for a movie type banner on printed material.
            Adobe Photoshop Version: 2017.0.1 20161130.r.29 2016/11/30:23:00:00 CL 1099099  x64
            Number of Launches: 109
            Operating System: Mac OS 10.12.3
            System architecture: Intel CPU Family:6, Model:62, Stepping:4 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
            Physical processor count: 4
            Logical processor count: 8
            Processor speed: 3700 MHz
            Built-in memory: 12288 MB
            Free memory: 5869 MB
            Memory available to Photoshop: 10080 MB
            Memory used by Photoshop: 70 %
            History Thumbnails: Enabled.
            Touch Bar: Enabled.
            Alias Layers: Disabled.
            Modifier Palette: Disabled.
            3D Multitone Printing: Disabled.
            Highbeam: Enabled.
            Image tile size: 1024K
            Image cache levels: 4
            Font Preview: Medium
            TextComposer: Latin
            Display: 1
            Main Display
            Display Bounds: top=0, left=0, bottom=1080, right=1920
            Display: 2
            Display Bounds: top=0, left=1920, bottom=1080, right=3840
            Display: 3
            Display Bounds: top=-193, left=-1920, bottom=887, right=0
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            AIFCoreInitialized=1
            AIFOGLInitialized=1
            OGLContextCreated=1
            NumGLGPUs=2
            NumCLGPUs=2
            NumNativeGPUs=2
            glgpu[0].GLVersion="2.1"
            glgpu[0].IsIntegratedGLGPU=0
            glgpu[0].GLMemoryMB=2048
            glgpu[0].GLName="AMD Radeon HD - FirePro D300 OpenGL Engine"
            glgpu[0].GLVendor="ATI Technologies Inc."
            glgpu[0].GLVendorID=4098
            glgpu[0].GLRectTextureSize=16384
            glgpu[0].GLRenderer="AMD Radeon HD - FirePro D300 OpenGL Engine"
            glgpu[0].GLRendererID=16915458
            glgpu[0].HasGLNPOTSupport=1
            glgpu[0].CanCompileProgramGLSL=1
            glgpu[0].GLFrameBufferOK=1
            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            clgpu[0].CLPlatformVersion="1.2 (Jan  4 2017 22:35:59)"
            clgpu[0].CLDeviceVersion="1.2 "
            clgpu[0].IsIntegratedCLGPU=0
            clgpu[0].CLMemoryMB=2048
            clgpu[0].CLName="AMD Radeon HD - FirePro D300 Compute Engine"
            clgpu[0].CLVendor="AMD"
            clgpu[0].CLVendorID=16915456
            clgpu[0].CLDriverVersion="1.2 (Jan 10 2017 22:25:08)"
            clgpu[0].CLBandwidth=1.26046e+11
            clgpu[0].CLCompute=990.4
            nativegpu[0].NativeName="AMD Radeon HD - FirePro D300"
            glgpu[1].GLVersion="2.1"
            glgpu[1].IsIntegratedGLGPU=0
            glgpu[1].GLMemoryMB=2048
            glgpu[1].GLName="AMD Radeon HD - FirePro D300 OpenGL Engine"
            glgpu[1].GLVendor="ATI Technologies Inc."
            glgpu[1].GLVendorID=4098
            glgpu[1].GLRectTextureSize=16384
            glgpu[1].GLRenderer="AMD Radeon HD - FirePro D300 OpenGL Engine"
            glgpu[1].GLRendererID=33692674
            glgpu[1].HasGLNPOTSupport=1
            glgpu[1].CanCompileProgramGLSL=1
            glgpu[1].GLFrameBufferOK=1
            glgpu[1].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
            glgpu[1].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
            glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
            glgpu[1].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[1].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[1].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            glgpu[1].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
            glgpu[1].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
            glgpu[1].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
            glgpu[1].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            glgpu[1].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            glgpu[1].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            glgpu[1].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            clgpu[1].CLPlatformVersion="1.2 (Jan  4 2017 22:35:59)"
            clgpu[1].CLDeviceVersion="1.2 "
            clgpu[1].IsIntegratedCLGPU=0
            clgpu[1].CLMemoryMB=2048
            clgpu[1].CLName="AMD Radeon HD - FirePro D300 Compute Engine"
            clgpu[1].CLVendor="AMD"
            clgpu[1].CLVendorID=33692672
            clgpu[1].CLDriverVersion="1.2 (Jan 10 2017 22:25:08)"
            clgpu[1].CLBandwidth=1.27686e+11
            clgpu[1].CLCompute=990.908
            nativegpu[1].NativeName="AMD Radeon HD - FirePro D300"
            License Type: Subscription
            Serial number: 90970373845866109477
            GUIDBucket:
              bucket: 227
              test: DocumentPanel
            Application folder: /Applications/Adobe Photoshop CC 2017/
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              Media, 3.64T, 1.91T free
            Required Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/
            Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-ins/
            Installed components:
               AdbePM.framework   AdbePM   2.5.00.377243   1.578146
               adobe_caps.framework   adobe_caps   10.0.0.6   1.584361
               AdobeACE.framework   AdobeACE   2.20.02.37447   79.578171
               AdobeAGM.framework   AdobeAGM   4.30.60.37447   79.578171
               AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
               AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
               AdobeBIB.framework   AdobeBIB   1.2.03.37447   79.578171
               AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.578171
               AdobeCoolType.framework   AdobeCoolType   5.15.00.37447   79.578171
               AdobeCrashReporter.framework   AdobeCrashReporter   7.3.2
               AdobeExtendScript.framework   AdobeExtendScript   4.5.6.4   80.1060872
               AdobeJP2K.framework   AdobeJP2K   1.2.2.36529   79.262945
               AdobeLinguistic.framework      21429
               AdobeMPS.framework   AdobeMPS   5.8.1.37174   79.577269
               AdobeOwl.framework   AdobeOwl   5.2.11
               AdobePDFL.framework   AdobePDFL   15.0.0.36975   79.195992
               AdobePDFSettings.framework   AdobePDFSettings   1.4
               AdobePIP.framework   AdobePIP   7.4.1.60.45263
               AdobeScCore.framework   AdobeScCore   4.5.6.4   80.1060872
               AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.37447   79.578171
               AdobeSVGRE.framework   AdobeSVGRE   6.0   79.578171
               AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
               AdobeXMP.framework   AdobeXMPCore   79.159824   79.159824
               AdobeXMPFiles.framework   AdobeXMPFiles   79.159824   79.159824
               AdobeXMPScript.framework   AdobeXMPScript   79.159824   79.159824
               ahclient.framework   ahclient   2.0.0.1
               AIDE.framework   AIDE   1.5.0.36540   79.574279
               aif.framework   aif   6.0.00.1   1.
               amtlib.framework   amtlib   10.0.0.47
               boost_date_time.framework   boost_date_time   10.0.0.0
               boost_filesystem.framework   boost_filesystem   10.0.0.0
               boost_signals.framework   boost_signals   10.0.0.0
               boost_system.framework   boost_system   10.0.0.0
               boost_threads.framework   boost_threads   10.0.0.0
               Cg.framework   NVIDIA Cg
               CIT.framework
               CITThreading.framework
               dvaaudiodevice.framework   dvaaudiodevice   10.0.0.0
               dvacore.framework   dvacore   10.0.0.0
               dvamarshal.framework   dvamarshal   10.0.0.0
               dvamediatypes.framework   dvamediatypes   10.0.0.0
               dvametadata.framework   dvametadata   10.0.0.0
               dvametadataapi.framework   dvametadataapi   10.0.0.0
               dvametadataUI.framework   dvametadataUI   10.0.0.0
               dvaplayer.framework   dvaplayer   10.0.0.0
               dvatransport.framework   dvatransport   10.0.0.0
               dvaui.framework   dvaui   10.0.0.0
               dvaunittesting.framework   dvaunittesting   10.0.0.0
               dynamiclink.framework   dynamiclink   10.0.0.0
               ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
               ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
               ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
               LogSession.framework   LogSession   7.4.1.60.45263
               manta.framework   manta   2.0.00.1   1.
               mediacoreif.framework   mediacoreif   10.0.0.0
               PlugPlugExternalObject.framework      7.0.0.67
               PlugPlugOwl.framework   PlugPlugOwl   7.0.0.67
               UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
               WRServices.framework   WRServices   12.0.0   12.0.0.1000
            Required plug-ins:
               3D Studio 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               Accented Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Adaptive Wide Angle 18.0.1, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
               Angled Strokes 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Average 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “Average.plugin”
               Bas Relief 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               BMP 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Camera Raw 9.9 (718), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Camera Raw Filter 9.9 (718), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Chalk & Charcoal 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Chrome 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Cineon 18.0.1  ©2002-2016 Adobe Systems Incorporated - from the file “Cineon.plugin”
               Clouds 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Collada DAE 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               Color Halftone 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Colored Pencil 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               CompuServe GIF 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Conté Crayon 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Craquelure 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crop and Straighten Photos 18.0.1  Copyright © 2003-2016 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
               Crop and Straighten Photos Filter 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Crosshatch 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crystallize 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Cutout 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Dark Strokes 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               De-Interlace 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dicom 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “dicom.plugin”
               Difference Clouds 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Diffuse Glow 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Displace 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dry Brush 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Eazel Acquire 18.0.1  Copyright © 2007-2016 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
               Entropy 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               Export Color Lookup Tables 18.0.1  Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
               Extrude 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               FastCore Routines 18.0.1  ©1990-2016 Adobe Systems Incorporated - from the file “FastCore.plugin”
               Fibers 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Film Grain 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Filter Gallery 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Flash 3D 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               Fresco 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glass 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glowing Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Google Earth 4 KMZ 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               Graphic Pen 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Halftone Pattern 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               HDRMergeUI 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
               HSB/HSL 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               IFF Format 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               IGES 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               Ink Outlines 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               JPEG 2000 18.0.1  Copyright © 2001-2016 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
               Kurtosis 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               Lens Blur 18.0.1, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
               Lens Correction 18.0.1, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
               Lens Flare 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Liquify 18.0.1, Copyright © 2001-2016 Adobe Systems Incorporated - from the file “Liquify.plugin”
               Matlab Operation 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Maximum 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mean 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               Measurement Core 18.0.1  Copyright © 1993-2016 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
               Median 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mezzotint 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Minimum 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               MMXCore Routines 18.0.1  ©1990-2016 Adobe Systems Incorporated - from the file “MMXCore.plugin”
               Mosaic Tiles 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Multiprocessor Support 18.0.1  Copyright © 1990-2016 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
               Neon Glow 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Note Paper 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               NTSC Colors 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
               Ocean Ripple 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               OpenEXR 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Paint Daubs 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Palette Knife 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Patchwork 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Paths to Illustrator 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               PCX 18.0.1  ©1989-2016 Adobe Systems Incorporated - from the file “PCX.plugin”
               Photocopy 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Photoshop 3D Engine 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
               Photoshop Touch Copyright ©2013-2016 Adobe Systems Incorporated - from the file “PSDX.plugin”
               Picture Package Filter 18.0.1  ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Pinch 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pixar 18.0.1  ©1989-2016 Adobe Systems Incorporated - from the file “Pixar.plugin”
               Plaster 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Plastic Wrap 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               PLY 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               PNG 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pointillize 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Polar Coordinates 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Portable Bit Map 18.0.1  ©1989-2016 Adobe Systems Incorporated - from the file “PBM.plugin”
               Poster Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               PRC 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               Radial Blur 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Radiance 18.0.1  ©2003-2016 Adobe Systems Incorporated - from the file “Radiance.plugin”
               Range 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               Rays v2.0 NO VERSION - from the file “Rays.plugin”
               Render Color Lookup Grid 18.0.1  Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
               Reticulation 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Ripple 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Rough Pastels 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Save for Web 18.0.1, Copyright © 1999-2016 Adobe Systems Incorporated - from the file “Save for Web.plugin”
               ScriptingSupport 18.0.1, Copyright © 2016 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
               Shake Reduction 18.0.1, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
               Shear 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Skewness 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               Smart Blur 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Smudge Stick 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Solarize 18.0.1  Copyright © 1993-2016 Adobe Systems Incorporated - from the file “Solarize.plugin”
               Spaces 18.0.1, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
               Spatter 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Spherize 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Sponge 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Sprayed Strokes 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stained Glass 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stamp 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Standard Deviation 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               STL 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               Sumi-e 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Summation 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               Targa 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Texturizer 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Tiles 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Torn Edges 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Twirl 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               U3D 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               Underpainting 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Vanishing Point 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
               Variance 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
               Virtual Reality Modeling Language | VRML 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               Water Paper 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Watercolor 18.0.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Wave 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wavefront|OBJ 18.0.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
               Wind 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wireless Bitmap 18.0.1  ©1989-2016 Adobe Systems Incorporated - from the file “WBMP.plugin”
               ZigZag 18.0.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
            Optional and third party plug-ins:
               Filter Forge 6 NO VERSION - from the file “/Applications/Filter Forge 6/Filter Forge 6 universal.plugin/”
            Duplicate and Disabled plug-ins: NONE
            Plug-ins that failed to load: NONE
            Extensions:
               com.adobe.inapp.purchase  2.7.122 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/purchase.html ”
               Recent Files  1.4.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
               Libraries  2.7.122 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html”
               New Document  1.4.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/fnft.html”
               com.adobe.experimentation.extension  2.0.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.experimentation.extension/index.html”
               Start  1.4.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
               Adobe Color Themes  6.1.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
               Export As  3.0.8 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
               Device Preview  1.3.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSPanel/panel.html”
               com.adobe.preview.loader  1.3.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSLoader/loader.html”
               Luminosity Masks (Greg Benz)  1.3.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.freemasksbenz.ext/index.html”
            Installed TWAIN devices: NONE
