• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CF-Ajax-Javascript Issue
New Here ,
Dec 29, 2008 Dec 29, 2008
Hello,
We have added a "recently viewed items" panel to the right side of our website.
In this panel we simply loop through the array of viewed items and present them
stacked up in the panel. The code for rendering the list of items is in a
separate CF template that is placed using an Ajax call within a <DIV>.
The problem is that the javascript is not executing in the recently viewed items
panel. For instance:
var pr_page_id="#currItem#"; snippet(document);
</script>
This code is in the loop so that each iteration of an item should show the
"snippet." I can't see the javascript in the source code since it's inside a
<DIV> but the non-Ajax (CF) pages that use the same technique are getting
the correct snippet so I know that the code works and that the problem must come
from the use of the Ajax call.
Any ideas on a different way to call this so it will fire the javascripts
correctly.
Thanks much,
Jerry
TOPICS
Advanced techniques
Views
418
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Dec 30, 2008 Dec 30, 2008
Inside a script tag for a cfm file you need to wrap every coldfusion variable individually with cfoutput tag, if you don't, it's passing, in your case #currItem# and not the value of the variable.
ie.
var pr_page_id=<cfoutput>#currItem#</cfoutput>; snippet(document);
</script>
Votes
Translate
Translate
Report
Report
LEGEND ,
> </script>
OR if you prefer a little less code, assuming you have more then one
variable in your script tag.
<cfoutput>
var pr_page_id=#currItem#; snippet(document);
</script>
</cfoutput>
Votes
Translate
Translate
Report
Report
New Here ,
Thanks for your responses. The CFOUTPUT tags are present in my code I just did not include them in the text of the thread.
Any other ideas out there?
Jerry
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
why it is not working and how to fix it will likely depend on:
- how you make your ajax call
- which js framework, if any, you are using
- where and how your js functions are declared
- how you write you js in the included page
- specifically your snippet() function
so, please, elaborate a bit more...
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
Votes
Translate
Translate
Report
Report
Resources
Documentation
