3 Replies Latest reply on Apr 14, 2017 2:01 AM by Peter Grainge
    RH 2015 Updates Not Installing
    Tim D Morris Level 1
      I and a coworker both have copies of RH 2015.  An Adobe Support rep recently asked me to install the latest updates to fix an issue I reported.  I am now on version 12.0.4.460.  My co-worker is on 12.0.0.306.  When he clicks File > Help > Updates..., nothing happens.  I saw a "General Discussions" post, suggesting users check to see if an older update program might still exist (RH 7.0.1) and delete it using Add/Remove Programs.  No such programs exist.  Has anyone else had issues with the installer not updating?  If yes, do you know how to resolve this issue?  Thanks.  Tim
        • 1. Re: RH 2015 Updates Not Installing
          Not that it matters here but it is fine to have older versions running.
          The first thing to check is whether the other person has local admin rights on their machine, they are required for updating.
          If that is not the cause, then click here and download the patch to install it. You only need to install Update 4 as it contains all the previous ones.
          See www.grainge.org for RoboHelp and Authoring information
          @petergrainge
          • 2. Re: RH 2015 Updates Not Installing
            Peter, sorry for the delay.  My co-worker was able to download the and unzip the files from the link you sent.  When he clicked the icon to install the files, which he tried both by clicking "Open" and by clicking "Run as administrator", nothing happened.  If it matters, he is on Windows 10; I'm on Windows 7.  Here is a screen shot of his current RH 2015 "About" window, which shows that the version number did not update.
            Any suggestions before we request our IT department try uninstalling and reinstalling his software--and do you think uninstalling/reinstalling the software will work?  He's still going to have to update his software for us both to be on the same version of RH 2015.  Thanks.
            Tim
            • 3. Re: RH 2015 Updates Not Installing
              Clicking Run as Administrator will only work if you have admin rights.
              My suspicion is what rights your colleague has and if that is the problem, they will be able to uninstall but not reinstall. My next step would be to get an IT person to log onto the machine and install the update. If that works it confirms the problem is with rights and IT can fix that as well.
              @petergrainge
