I am currently trying to insert a Char tab into a new paragraph, I'd like to separate each variable I insert into the paragraph separated by a Char Tab.
I am updating an existing mif file. I am trying to figure how to insert the <Char Tab> using Extend Script.
Any help would be appreciated.
Sebin
Existing Mif File Screenshot:
<String `Attribute1: '>
<Variable
<VariableName `Variable_1'>
<Unique 6767868>
> # end of Variable
<Char Tab>
<String `Attribute2: '>
<Variable
<VariableName `Variable_2'>
<Unique 6767812>
> # end of Variable
<Char Tab>
#target framemaker
var doc = app.ActiveDoc;
// Make a variable for the paragraph containing the text cursor.
var pgf = doc.TextSelection.beg.obj;
// Make a text location variable at the beginning of the paragraph.
var textLoc = new TextLoc (pgf, 0);
// Insert a tab character in the paragraph.
doc.AddText (textLoc, "\x08");
You should be able to use "\x08".
Could you also let me know how to use it? What function should I invoke to insert the tab?
I'm not sure how to use the 'Tab' function.
Sebin
#target framemaker
Thank you so much! It worked!
Please mark my answer as correct. Thank you.
