1 Reply Latest reply on Jan 6, 2009 6:00 AM by AAnkurA
    can't publish
      have Presenter 7.0.2
      When I try to publish a .ppt file, Presenter starts and the publishing window opens, but it shuts down after a few seconds and is not complete. The presentation is 38 slides with no video or audio. I have been able to publish test files with one slide.
        • 1. Re: can't publish
          AAnkurA Adobe Employee
          I am afraid you have to isolate which slide is causing this problem.
          Quick way to check that will be to check the publish location (C:\abc for example), check data folder inside it and see how many slide[slide no].swf (Slide1.swf, Slide2.swf etc.) are generated.
          If you find 24 SWF's are getting generated then problem will be with 25th slide. Delete 25th slide and publish again.
