6 Replies Latest reply on Mar 31, 2017 10:35 AM by scottyb34
    My flattened Photoshop documents maintain Transparency in InDesign. Is that Ok for print?
    scottyb34 Level 1
      Greetings forum,
      My flattened Photoshop documents still maintain Transparency when placed into InDesign. Is this OK in terms of printing? I thought once the photoshop documents were flattened, so too was the transparency. Will this present a problem when exporting a PDF for Print? Or does the PDF Presets take care of the transparency?
      Once again, dazed and confused.
      Thanks in advance, Scott
        • 1. Re: My flattened Photoshop documents maintain Transparency in InDesign. Is that Ok for print?
          Derek Cross Adobe Community Professional
          Select PDF/X-4 from the InDesign Acrobat PDF Presets (unless advised otherwise by your printer).
          • 2. Re: My flattened Photoshop documents maintain Transparency in InDesign. Is that Ok for print?
            scottyb34 Level 1
            Hi Derek -
            Using the PDF Preset would certainly work, but I'm still stumped as to WHY my "flattened images" from photoshop that are placed into InDesign show up on the Links panel as "Transparency: Yes." I must be missing some sort of setting because I've tried everything that I can think of. In my earlier tests the Links panel would indicate that my flattened and placed photoshop images were indeed Not transparent, i.e. in the Links panel it'd say "Transparency: no." I don't know why this has changed. I need to sleep now, so I'm hoping to awaken to a simple solution that I've overlooked.
            Thanks for your input.
            Scott
            • 3. Re: My flattened Photoshop documents maintain Transparency in InDesign. Is that Ok for print?
              I assume the link is up to date and doesn't show as modified? Does the Window>Output>Flattener Preview set to Highlight Transparent Objects highlight the Photoshop file?
              I don't think you have to worry about Photoshop transparency at all. if you are in a print workflow that demands flattened PDF (X-1a) the flattening will happen at export. Also, you can have PSD files with transparency that doesn't interact with the InDesign page (a PSD file with the bottom layer showing as Background), and in that case it is not consider a transparent object by either ID or a PDF with live transparency.
              • 4. Re: My flattened Photoshop documents maintain Transparency in InDesign. Is that Ok for print?
                My question is, why did you flatten the image in Photoshop? You should not do so in any way as this can cause other problems. Leave all layers and transparency alive (and even in RGB!!!!) in Photoshop and place the file, only if you want to use the flattened image only.
                If the image contained text or vector layers, leave it alive, save as PDF (with default Photoshop settings) and place the PDF instead.
                If you are flattening an image and it is seen as Layer and not as Background, InDesign sees it as a file with transparency even if there is none.
                • 5. Re: My flattened Photoshop documents maintain Transparency in InDesign. Is that Ok for print?
                  Just to avoid Merge/Flatten term confusion; Photoshop's Layer>Flatten, or the Layer panel's Flatten Image, always completely flattens the image and you get a single layer named Background.
                  If you use one of the Merge commands—Merge Down or Merge Visible—you might not completely flatten an image even when there is only one layer.
                  A Photoshop file can have multiple layers with transparent objects that InDesign will see as having no transparency. So the first file below would be considered transparent in ID, but the second example would not because of the bottom Background layer that I made from layer 1 via Layer>New>Background from Layer
                  ID doesn't consider the second version with the Background layer to have transparency
                  • 6. Re: My flattened Photoshop documents maintain Transparency in InDesign. Is that Ok for print?
                    scottyb34 Level 1
                    Wow, another perfectly detailed answer. Thanks, again, Rob for not only answering my question, but showing me exactly what you mean. It now makes perfect sense. Typically I flatten an image by using Layers>Flatten Image, but lately I've been merging all layers except the background then flattening so as to apply "rich black" in CMYK to the black background. I had a feeling it was something that was right under my nose but I just couldn't see it. There's a method to my madness as to why I need to perform some tasks that others seem to think are foolish, but you just accept the fact that we're all working on very different projects and you simply answer the question(s). You should be an instructor.
                    Best regards,
                    Scott
