16 Replies Latest reply on Apr 8, 2017 4:05 PM by kunwarb
    Lightroom CC 2015.9 on MBP 2016 crashes repeatedly when importing iPhone images
    kunwarb
      Can somebody help me?
      I cannot resolve this issue which has happened consistently for the last dozen times I have tried to import photos into LR from my iPhone 5S.
      I have a matchbook pro 15inch late 2016 with touch bar, 2.9Ghz i7 CPU, graphics card and 16GB RAM.
      Lightroom CC 2015.9 constantly freezes and fails to import and freezes when I try to import pictures taken with the iPhone. This happens if I try to import directly from the iPhone or indirectly via a folder on my Desktop which I have previously imported/copied photos to using a separate program called Image capture.  I have not had this issue until recently.  I usually select "Copy... New photos" in the process of importing. (On a separate issue, I find that the iPhone is frequently not recognised by the LR program, so I often have to resort to restarting both LR and reconnecting the iPhone)
      Just to clarify, I can see the preview thumbnails of iPhone images in the import window before I commence the LR import, but the import freezes without any photos actually being imported into LR.
      I have disabled all LR plug ins and reset preferences to defaults. This does not rectify the issue. Each time it freezes, I have to Force Quit LR to close the program.
      Strangely, I can import photos from an SD card used in my camera  (Canon DSLR) without any problems.
      Thanks.
      If anyone is interested, I have copied the error report generated after the I have restarted the LR program following a Forced Quit. I can paste it into another message if anyone wants to look at it (It is very long!)
      My MBP is running a current version of Sierra 10.12.3 with software updates etc.
      If I cannot get a resolution on this problem, I will likely abandon the program. This is a shame as LR has served me well for years.
      Kunwar
        • 1. Re: Lightroom CC 2015.9 on MBP 2016 crashes repeatedly when importing iPhone images
          Jao vdL Adobe Community Professional & MVP
          I don't know why it freezes but have you tried simply using the mobile LR app and import there? log on with your CC account on both the iPhone and on your laptop and it will sync to your laptop without connecting the cable. LR/mobile can even shoot raw (although probably not on the 5s). This works quite reliably for me and I have not connected my phone to a computer for years.
          That said, you should be able to import using the cable. No clue why it doesn't work.
          • 2. Re: Lightroom CC 2015.9 on MBP 2016 crashes repeatedly when importing iPhone images
            Mohit Goyal Adobe Employee (Admin)
            Hi kunwarb,
            Have you tried turning off 1:1 previews on import? also, turn off the GPU from the Lightroom preferences and check if that helps.
            Open Lightroom > Edit menu > Preferences > Performance tab > Uncheck the GPU > Restart.
            Regards,
            Mohit
            • 3. Re: Lightroom CC 2015.9 on MBP 2016 crashes repeatedly when importing iPhone images
              SmitKeniya Adobe Employee
              Hi Kunwar,
              When Lightroom Crashes, you would see the crash log from Apple. Please send us the report with your email mentioned in the form. Also please share the logs here.
              Smit Keniya
              • 4. Re: Lightroom CC 2015.9 on MBP 2016 crashes repeatedly when importing iPhone images
                kunwarb Level 1
                Hi, I have been trying some of the above suggestions including disable the discrete GPU and turning off 1:1 previews. Still no success. Not familiar with how to sync photos from lightroom mobile.
                Here is a crash report generated when I had to Force Quit LR after it hung during an import attempt. Restarting LR showed that no images were imported.
                Any more suggestions?
                Date/Time:       2017-04-01 22:03:49 +0100
                OS Version:      Mac OS X 10.12.4 (Build 16E195)
                Architecture:    x86_64h
                Report Version:  25
                Data Source:     Stackshots
                Command:         Adobe Lightroom
                Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                Version:         Adobe Lightroom [1106920] (6.9)
                Parent:          launchd [1]
                PID:             5438
                Event:           hang
                Duration:        1.00s (process was unresponsive for 171 seconds before sampling)
                Steps:           10 (100ms sampling interval)
                Hardware model:  MacBookPro13,3
                Active cpus:     8
                Fan speed:       2618 rpm
                Timeline format: stacks are sorted chronologically
                Use -i and -heavy to re-report with count sorting
                Heaviest stack for the main thread of the target process:
                  10  start + 1 (libdyld.dylib + 21045) [0x7fff976e2235]
                  10  main + 1095 (Adobe Lightroom + 7079) [0x109b96ba7]
                  10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fff7fa3b1de]
                  10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fff7fa707ab]
                  10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fff801f785e]
                  10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fff7fa7be24]
                  10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fff814e0b26]
                  10  ReceiveNextEventCommon + 184 (HIToolbox + 199673) [0x7fff814e0bf9]
                  10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fff814e0ebc]
                  10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fff81f7f1c4]
                  10  __CFRunLoopRun + 917 (CoreFoundation + 554933) [0x7fff81f7f7b5]
                  10  __CFRunLoopDoBlocks + 356 (CoreFoundation + 557108) [0x7fff81f80034]
                  10  __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 12 (CoreFoundation + 684572) [0x7fff81f9f21c]
                  10  __52-[NSApplication(NSAppleEventHandling) _handleAEQuit]_block_invoke + 46 (AppKit + 4457620) [0x7fff7fe75494]
                  10  -[NSApplication _terminateFromSender:askIfShouldTerminate:saveWindows:] + 224 (AppKit + 4457966) [0x7fff7fe755ee]
                  10  -[NSApplication terminate:] + 1662 (AppKit + 2390933) [0x7fff7fc7cb95]
                  10  -[NSNotificationCenter postNotificationName:object:userInfo:] + 66 (Foundation + 27031) [0x7fff83975997]
                  10  _CFXNotificationPost + 604 (CoreFoundation + 366044) [0x7fff81f515dc]
                  10  -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 1827 (CoreFoundation + 370083) [0x7fff81f525a3]
                  10  ___CFXNotificationPost_block_invoke + 50 (CoreFoundation + 643442) [0x7fff81f95172]
                  10  _CFXRegistrationPost + 427 (CoreFoundation + 644107) [0x7fff81f9540b]
                  10  __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 644364) [0x7fff81f9550c]
                  10  ??? (Adobe Lightroom + 15032) [0x109b98ab8]
                  10  ??? (<B5A2691C-C7C2-3F81-8F41-3BF90D4BF6DB> + 422445) [0x109e0622d]
                  10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 81416) [0x109ea5e08]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8433) [0x109d560f1]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41185) [0x109d5e0e1]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 99677) [0x109d6c55d]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 40469) [0x109d5de15]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 16070) [0x109d57ec6]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8562) [0x109d56172]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41789) [0x109d5e33d]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 38782) [0x109d5d77e]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 135929) [0x109d752f9]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 133207) [0x109d74857]
                  10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 159188) [0x109d7add4]
                  10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fff97810bf2]
                *10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d]
                Process:         Adobe Lightroom (Lightroom) [5438]
                Parent:          launchd [1]
                UID:             503
                Task size:       4438.57 MB
                CPU Time:        <0.001
                Note:            Unresponsive for 171 seconds before sampling
                Note:            3 idle work queue threads omitted
                  Thread 0x200d3            DispatchQueue 1           10 samples (1-10)         priority 47 (base 47)
                  <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [165], process received importance donation from EmojiFunctionRowIM_Extension [487], IO tier 0>
                  10  start + 1 (libdyld.dylib + 21045) [0x7fff976e2235] 1-10
                    10  main + 1095 (Adobe Lightroom + 7079) [0x109b96ba7] 1-10
                      10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fff7fa3b1de] 1-10
                        10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fff7fa707ab] 1-10
                          10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fff801f785e] 1-10
                            10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fff7fa7be24] 1-10
                              10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fff814e0b26] 1-10
                                10  ReceiveNextEventCommon + 184 (HIToolbox + 199673) [0x7fff814e0bf9] 1-10
                                  10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fff814e0ebc] 1-10
                                    10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fff81f7f1c4] 1-10
                                      10  __CFRunLoopRun + 917 (CoreFoundation + 554933) [0x7fff81f7f7b5] 1-10
                                        10  __CFRunLoopDoBlocks + 356 (CoreFoundation + 557108) [0x7fff81f80034] 1-10
                                          10  __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 12 (CoreFoundation + 684572) [0x7fff81f9f21c] 1-10
                                            10  __52-[NSApplication(NSAppleEventHandling) _handleAEQuit]_block_invoke + 46 (AppKit + 4457620) [0x7fff7fe75494] 1-10
                                              10  -[NSApplication _terminateFromSender:askIfShouldTerminate:saveWindows:] + 224 (AppKit + 4457966) [0x7fff7fe755ee] 1-10
                                                10  -[NSApplication terminate:] + 1662 (AppKit + 2390933) [0x7fff7fc7cb95] 1-10
                                                  10  -[NSNotificationCenter postNotificationName:object:userInfo:] + 66 (Foundation + 27031) [0x7fff83975997] 1-10
                                                    10  _CFXNotificationPost + 604 (CoreFoundation + 366044) [0x7fff81f515dc] 1-10
                                                      10  -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 1827 (CoreFoundation + 370083) [0x7fff81f525a3] 1-10
                                                        10  ___CFXNotificationPost_block_invoke + 50 (CoreFoundation + 643442) [0x7fff81f95172] 1-10
                                                          10  _CFXRegistrationPost + 427 (CoreFoundation + 644107) [0x7fff81f9540b] 1-10
                                                            10  __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 644364) [0x7fff81f9550c] 1-10
                                                              10  ??? (Adobe Lightroom + 15032) [0x109b98ab8] 1-10
        10  ??? (<B5A2691C-C7C2-3F81-8F41-3BF90D4BF6DB> + 422445) [0x109e0622d] 1-10
        10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 81416) [0x109ea5e08] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8433) [0x109d560f1] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41185) [0x109d5e0e1] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 99677) [0x109d6c55d] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 40469) [0x109d5de15] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 16070) [0x109d57ec6] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 8562) [0x109d56172] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41789) [0x109d5e33d] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 38782) [0x109d5d77e] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 135929) [0x109d752f9] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 133207) [0x109d74857] 1-10
        10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 159188) [0x109d7add4] 1-10
        10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fff97810bf2] 1-10
        *10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-10
                  Thread 0x2012b            Thread name "cr_scratch"  10 samples (1-10)         priority 31 (base 31)
                  <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [165], process received importance donation from EmojiFunctionRowIM_Extension [487], IO tier 0>
                  10  <truncated backtrace> 1-10
                  Thread 0x201c3            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 47 (base 47)
                  10  thread_start + 13 (libsystem_pthread.dylib + 12545) [0x7fff978fb101] 1-10
                    10  _pthread_start + 286 (libsystem_pthread.dylib + 14587) [0x7fff978fb8fb] 1-10
                      10  _pthread_body + 180 (libsystem_pthread.dylib + 14767) [0x7fff978fb9af] 1-10
                        10  _NSEventThread + 205 (AppKit + 1655506) [0x7fff7fbc92d2] 1-10
                            10  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fff81f7f971] 1-10
                              10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fff81f804e4] 1-10
                                10  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fff9780934a] 1-10
                                 *10  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-10
                  Thread 0x201c5            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
                        10  __NSThread__start__ + 1243 (Foundation + 207821) [0x7fff839a1bcd] 1-10
                          10  +[NSURLConnection(Loader) _resourceLoadLoop:] + 313 (CFNetwork + 26116) [0x7fff810bd604] 1-10
                  Thread 0x201c9            10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
                        10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1403241) [0x116c2d969] 1-10
                          10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 867579) [0x116baacfb] 1-10
                            10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1069145) [0x116bdc059] 1-10
                              10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1406447) [0x116c2e5ef] 1-10
                                10  ??? (<2116CCCF-BA38-366C-8BCE-91827BA52E6D> + 1412300) [0x116c2fccc] 1-10
                  Thread 0x201d5            Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 47 (base 47)
                        10  __select + 10 (libsystem_kernel.dylib + 106166) [0x7fff97810eb6] 1-10
                         *10  ??? (kernel + 5801776) [0xffffff8000788730] 1-10
                  Thread 0x202f1            10 samples (1-10)         priority 31 (base 31)
                  Thread 0x202f2            10 samples (1-10)         priority 31 (base 31)
                        10  ??? (<D9194969-C41E-37DF-A816-9CFA013C632B> + 6085) [0x1146a87c5] 1-10
                          10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 105673) [0x115869cc9] 1-10
                            10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 107314) [0x11586a332] 1-10
                              10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 178264) [0x11587b858] 1-10
                                10  ??? (<12E3207D-9B3A-37A8-B20F-8D584742797E> + 179436) [0x11587bcec] 1-10
                                  10  kevent + 10 (libsystem_kernel.dylib + 109974) [0x7fff97811d96] 1-10
                                   *10  ??? (kernel + 5627984) [0xffffff800075e050] 1-10
                  Thread 0x202fb            10 samples (1-10)         priority 31 (base 31)
                  Thread 0x202fc            10 samples (1-10)         priority 31 (base 31)
                  Thread 0x202fd            10 samples (1-10)         priority 31 (base 31)
                  Thread 0x202fe            10 samples (1-10)         priority 31 (base 31)
                  Thread 0x31b8c            Thread name "Protected Background Thread"           10 samples (1-10)         priority 31 (base 31)
                          10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 78703) [0x109ea536f] 1-10
                                        10  ??? (<EA22D365-4FEB-3119-AA45-4A0814D2A1A5> + 130233) [0x109eb1cb9] 1-10
                                            10  ??? (<552408AE-9F72-3E5A-8157-7690BEBAEC93> + 41168) [0x109d5e0d0] 1-10
        10  ??? (<35D1FB78-7295-3206-BD04-6A6245227F6B> + 16468) [0x114432054] 1-10
        10  ??? (<35D1FB78-7295-3206-BD04-6A6245227F6B> + 8149) [0x11442ffd5] 1-10
        10  -[NSCondition wait] + 240 (Foundation + 208171) [0x7fff839a1d2b] 1-10
                  Binary Images:
                           0x109b95000 -        0x109bb0fff  com.adobe.Lightroom6 Adobe Lightroom [1106920] (6.9) <7A685660-150F-3A23-B64A-6AEE19D3D338>  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                           0x109d54000 -                ???  ???                                                  <552408AE-9F72-3E5A-8157-7690BEBAEC93>
                           0x109d9f000 -                ???  ???                                                  <B5A2691C-C7C2-3F81-8F41-3BF90D4BF6DB>
                           0x109e92000 -                ???  ???                                                  <EA22D365-4FEB-3119-AA45-4A0814D2A1A5>
                           0x11442e000 -                ???  ???                                                  <35D1FB78-7295-3206-BD04-6A6245227F6B>
                           0x1146a7000 -                ???  ???                                                  <D9194969-C41E-37DF-A816-9CFA013C632B>
                           0x115850000 -                ???  ???                                                  <12E3207D-9B3A-37A8-B20F-8D584742797E>
                           0x116ad7000 -                ???  ???                                                  <2116CCCF-BA38-366C-8BCE-91827BA52E6D>
                        0x7fff7fa35000 -     0x7fff8080efff  com.apple.AppKit 6.9 (1504.82.104)                   <C295FF09-9984-34C3-953B-B263EF2107AB>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                        0x7fff810b7000 -     0x7fff81491fff  com.apple.CFNetwork 811.4.18 (811.4.18)              <9CE329E8-6177-3474-976D-F5C63FC875CD>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                        0x7fff814b0000 -     0x7fff817b9fff  com.apple.HIToolbox 2.1.1 (857.8)                    <40254D9A-E477-3F33-B2A2-807D399BF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                        0x7fff81ef8000 -     0x7fff82391fff  com.apple.CoreFoundation 6.9 (1349.65)               <F79384D1-FA3F-38CA-A847-B2625EBB790E>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                        0x7fff8396f000 -     0x7fff83d15fff  com.apple.Foundation 6.9 (1349.64)                   <49C8DA40-9E5B-33F9-B092-F50115B59E95>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                        0x7fff976dd000 -     0x7fff976e2fff  libdyld.dylib (433.5)                                <129D3B44-FB21-3750-9A68-48B5C3DC632B>  /usr/lib/system/libdyld.dylib
                        0x7fff977f7000 -     0x7fff97819fff  libsystem_kernel.dylib (3789.51.2)                   <FC51D7B0-8292-3F6A-9231-64340B237EB7>  /usr/lib/system/libsystem_kernel.dylib
                        0x7fff978f8000 -     0x7fff97902fff  libsystem_pthread.dylib (218.51.1)                   <62A84A68-431D-3B54-A7B6-31367CCF2884>  /usr/lib/system/libsystem_pthread.dylib
                   *0xffffff7f81356000 - 0xffffff7f81361fff  com.apple.kec.pthread 1.0 (1)                        <4EFF2F70-C9B9-3176-BF83-F1B660C42135>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
                   *0xffffff8000200000 - 0xffffff80009fffff  kernel (3789.51.2)                                   <06F94FD7-451F-34A1-B13C-D68FF7EDE0A0>  /System/Library/Kernels/kernel
                Process:         1PasswordAgent [458]
                Path:            /Users/USER/Library/Application Support/1Password/*/1PasswordAgent.app/Contents/MacOS/1PasswordAgent
                Parent:          launchd [1]
                UID:             503
                Task size:       56.77 MB
                Process:         AccessMenuBarApps (☯) [1557]
                Path:            /Applications/AccessMenuBarApps.app/Contents/MacOS/AccessMenuBarApps
                Parent:          launchd [1]
                UID:             503
                Task size:       36.60 MB
                CPU Time:        0.001
                Process:         accountsd [333]
                Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
                Parent:          launchd [1]
                UID:             503
                Sudden Term:     Tracked (allows idle exit)
                Task size:       60.17 MB
                Note:            5 idle work queue threads omitted
                  Thread 0xbad              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                    10  ??? (accountsd + 2602) [0x10383fa2a] 1-10
                  Thread 0x76d6             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10383f000 -        0x10383ffff  accountsd (640.0.19)                   <C9C497BB-575F-31BA-B4EF-4108EB9389D5>  /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
                Process:         Adobe CEF Helper [811]
                Path:            /Library/Application Support/Adobe/*/Adobe CEF Helper.app/Contents/MacOS/Adobe CEF Helper
                Architecture:    i386
                Parent:          Creative Cloud [449]
                Responsible:     Creative Cloud [449]
                UID:             503
                Task size:       32.24 MB (+4096  B)
                CPU Time:        0.002
                Process:         Adobe CEF Helper [818]
                Architecture:    i386
                UID:             503
                Task size:       43.39 MB
                Process:         Adobe CEF Helper [851]
                Architecture:    i386
                UID:             503
                Task size:       44.91 MB
                CPU Time:        0.004
                Process:         Adobe Desktop Service [815]
                Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/MacOS/Adobe Desktop Service
                Architecture:    i386
                Parent:          launchd [1]
                UID:             503
                Task size:       26.22 MB
                CPU Time:        0.005
                Process:         Adobe QT32 Server [5475]
                Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Helpers/DynamicLinkMediaServer/application/dynamiclinkmediaserver. app/Contents/Adobe QT32 Server.app/Contents/MacOS/Adobe QT32 Server
                Architecture:    i386
                Parent:          launchd [1]
                UID:             503
                Task size:       11.49 MB
                Process:         AdobeCrashDaemon [5442]
                Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashDaemo n.app/Contents/MacOS/AdobeCrashDaemon
                Parent:          Adobe Lightroom (Lightroom) [5438]
                Responsible:     Adobe Lightroom (Lightroom) [5438]
                UID:             503
                Task size:       12.94 MB
                CPU Time:        0.002
                Process:         AdobeCRDaemon [800]
                Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/C ontents/MacOS/AdobeCRDaemon
                UID:             503
                Task size:       14.73 MB
                CPU Time:        0.002
                Process:         AdobeCRDaemon [819]
                Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app /Contents/MacOS/AdobeCRDaemon
                Parent:          Adobe Desktop Service [815]
                Responsible:     Adobe Desktop Service [815]
                UID:             503
                Task size:       14.70 MB
                CPU Time:        0.002
                Process:         AdobeCRDaemon [852]
                Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Co ntents/MacOS/AdobeCRDaemon
                Parent:          Core Sync [844]
                Responsible:     Core Sync [844]
                UID:             503
                Task size:       14.73 MB
                CPU Time:        0.002
                Process:         AdobeIPCBroker [687]
                Path:            /Applications/Utilities/Adobe Application Manager/*/AdobeIPCBroker.app/Contents/MacOS/AdobeIPCBroker
                Architecture:    i386
                Parent:          launchd [1]
                UID:             503
                Task size:       5888 KB
                CPU Time:        0.002
                Process:         AdobeUpdateDaemon [103]
                Path:            /Library/Application Support/Adobe/*/AdobeUpdateDaemon
                Architecture:    i386
                Parent:          launchd [1]
                UID:             0
                Task size:       5264 KB
                CPU Time:        0.002
                Note:            1 idle work queue threads omitted
                  Thread 0x2c2              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)     cpu time 0.002
                  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
                  10  start + 53 (AdobeUpdateDaemon + 5637) [0xa0605] 1-10
                    10  ??? (AdobeUpdateDaemon + 9431) [0xa14d7] 1-10
                      10  ??? (AdobeUpdateDaemon + 8905) [0xa12c9] 1-10
                        10  ??? (AdobeUpdateDaemon + 11733) [0xa1dd5] 1-10
                          10  CommBridgeImpl::initCommBridge(CommunicationBridge::PipeContext, std::string const&, bool, unsigned int, void (*)(void*), void*) + 1173 (AdobeUpdateDaemon + 67893) [0xaf935] 1-10
                            10  usleep$UNIX2003 + 55 (libsystem_c.dylib + 496305) [0xa17542b1] 1-10
                              10  __semwait_signal + 10 (libsystem_kernel.dylib + 112370) [0xa17d56f2] 1-10
                               *10  semaphore_wait_continue + 0 (kernel + 1118912) [0xffffff80003112c0] 1-10
                  Thread 0x1a7b             10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
                    10  __read + 10 (libsystem_kernel.dylib + 118022) [0xa17d6d06] 1-10
                     *10  hndl_unix_scall + 216 (kernel + 645688) [0xffffff800029da38] 1-10
                       *10  unix_syscall + 561 (kernel + 6443777) [0xffffff8000825301] 1-10
                         *10  read_nocancel + 115 (kernel + 5884291) [0xffffff800079c983] 1-10
                           *10  ??? (kernel + 5884954) [0xffffff800079cc1a] 1-10
                             *10  ??? (kernel + 3393726) [0xffffff800053c8be] 1-10
                               *10  fifo_read + 146 (kernel + 3493906) [0xffffff8000555012] 1-10
                                 *10  soreceive + 2209 (kernel + 6080001) [0xffffff80007cc601] 1-10
                                   *10  sbwait + 370 (kernel + 6119186) [0xffffff80007d5f12] 1-10
                                     *10  msleep + 98 (kernel + 5802402) [0xffffff80007889a2] 1-10
                                       *10  ??? (kernel + 5801187) [0xffffff80007884e3] 1-10
                                         *10  lck_mtx_sleep + 132 (kernel + 1026980) [0xffffff80002faba4] 1-10
                                           *10  thread_block_reason + 222 (kernel + 1069422) [0xffffff800030516e] 1-10
                                             *10  ??? (kernel + 1073995) [0xffffff800030634b] 1-10
                                               *10  machine_switch_context + 206 (kernel + 2082766) [0xffffff80003fc7ce] 1-10
                  Thread 0x1a7c             10 samples (1-10)         priority 20 (base 20)
                    10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 111374) [0xa17d530e] 1-10
                  Binary Images:
                               0x9f000 -           0x167fff  AdobeUpdateDaemon                  <C496393C-CFD1-3934-95F5-C1DDC73747AD>  /Library/Application Support/Adobe/*/AdobeUpdateDaemon
                            0xa16db000 -         0xa1769fff  libsystem_c.dylib (1158.50.2)      <2252D116-215B-3C01-A85F-0AAC10DB36CC>  /usr/lib/system/libsystem_c.dylib
                            0xa17ba000 -         0xa17dbfff  libsystem_kernel.dylib (3789.51.2) <50D0E6F1-6F9C-303F-BCD6-F72AD4485B6E>  /usr/lib/system/libsystem_kernel.dylib
                Process:         AGSService [90]
                Path:            /Library/Application Support/Adobe/*/AGSService
                Parent:          launchd [1]
                UID:             0
                Task size:       26.08 MB
                  Thread 0x2b9              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                  10  start + 52 (AGSService + 5412) [0x100001524] 1-10
                    10  ??? (AGSService + 30627) [0x1000077a3] 1-10
                      10  ??? (AGSService + 105425) [0x100019bd1] 1-10
                        10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 140362) [0x7fff8399144a] 1-10
                          10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 140658) [0x7fff83991572] 1-10
                  Thread 0x58c              10 samples (1-10)         priority 20 (base 20)
                        10  ??? (AGSService + 30325) [0x100007675] 1-10
                          10  sleep + 42 (libsystem_c.dylib + 526803) [0x7fff977979d3] 1-10
                            10  __semwait_signal + 10 (libsystem_kernel.dylib + 106310) [0x7fff97810f46] 1-10
                  Thread 0x23f7a            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
                  Thread 0x23f7b            Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
                  Binary Images:
                           0x100000000 -        0x10023ffff  AGSService                             <4EE77B93-276B-3660-BC65-BB91D37D6FAF>  /Library/Application Support/Adobe/*/AGSService
                        0x7fff97717000 -     0x7fff977a4fff  libsystem_c.dylib (1158.50.2)          <B03F8915-1E9B-3C84-AED5-68E2E0031630>  /usr/lib/system/libsystem_c.dylib
                Process:         AirPlayUIAgent [447]
                Path:            /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
                Parent:          launchd [1]
                UID:             503
                Task size:       30.16 MB
                  Thread 0xfe1              DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
                  <thread QoS user interactive (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
                              10  ReceiveNextEventCommon + 432 (HIToolbox + 199921) [0x7fff814e0cf1] 1-10
                                         *8  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-8
                  <process clamped>
                                         *2  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 9-10
                  Thread 0x11f6             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                  <process clamped>
                  Thread 0x28cbe            10 samples (1-10)         priority 31 (base 31)
                  <process sudden termination clean, process unclamped, IO tier 0>
                *8  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-8
                  <process clamped>
                *2  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 9-10
                  Binary Images:
                           0x104e38000 -        0x104e42fff  com.apple.AirPlayUIAgent 2.0 (320.18)  <3F810C5B-8F96-3408-8567-B4225FF7F76E>  /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
                Process:         AirPlayXPCHelper [129]
                Path:            /usr/libexec/AirPlayXPCHelper
                Parent:          launchd [1]
                UID:             0
                Task size:       20.77 MB
                  Thread 0x6ce              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
                  10  _dispatch_sig_thread + 41 (libdispatch.dylib + 62031) [0x7fff976ba24f] 1-10
                    10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 106982) [0x7fff978111e6] 1-10
                  Binary Images:
                           0x102539000 -        0x10253afff  AirPlayXPCHelper (320.18)          <A2A06D93-12D1-30A2-959B-6D9ED81B0205>  /usr/libexec/AirPlayXPCHelper
                        0x7fff976ab000 -     0x7fff976dcfff  libdispatch.dylib (703.50.37)      <D122E712-9593-31CA-BAC4-4A54410BF4A0>  /usr/lib/system/libdispatch.dylib
                Process:         airportd [72]
                Path:            /usr/libexec/airportd
                Parent:          launchd [1]
                UID:             0
                Task size:       32.09 MB
                  Thread 0x2e4              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from sharingd [411], process received importance donation from WiFiProxy [528], IO tier 0>
                    10  ??? (airportd + 298142) [0x10830fc9e] 1-10
                  Thread 0x6b5              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x1082c7000 -        0x1083e2fff  airportd (1200.46)                     <1A52D6C7-F435-359B-A14B-23FCB2EBFEEA>  /usr/libexec/airportd
                Process:         akd [253]
                Path:            /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
                Parent:          launchd [1]
                UID:             0
                Task size:       21.16 MB
                  Thread 0x7e8              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (akd + 102357) [0x10ac44fd5] 1-10
                  Thread 0x7f4              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10ac2c000 -        0x10acacfff  akd (141.0.1)                          <E8D1B327-73BF-3198-9DF3-E647964A26F9>  /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
                Process:         akd [354]
                Parent:          launchd [1]
                UID:             503
                Task size:       28.16 MB
                Note:            4 idle work queue threads omitted
                  Thread 0xca2              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (akd + 102357) [0x10d558fd5] 1-10
                  Thread 0xcec              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10d540000 -        0x10d5c0fff  akd (141.0.1)                           <E8D1B327-73BF-3198-9DF3-E647964A26F9>  /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
                Process:         amfid [130]
                Path:            /usr/libexec/amfid
                Parent:          launchd [1]
                UID:             0
                Task size:       19.06 MB
                  Thread 0x38d              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
                  Binary Images:
                           0x10efc3000 -        0x10efc9fff  amfid (225.50.12)                  <B6C62BC3-D705-354C-9A1B-68BB01970323>  /usr/libexec/amfid
                Process:         AppActivity [452]
                Path:            /Users/USER/Library/Application Support/AppPolicy/AppActivity
                Parent:          launchd [1]
                UID:             503
                Task size:       14.44 MB
                  Thread 0xfe4              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                  10  start + 52 (AppActivity + 4548) [0x1000011c4] 1-10
                    10  main + 7127 (AppActivity + 173127) [0x10002a447] 1-10
                  Binary Images:
                           0x100000000 -        0x100041fff  AppActivity                            <55420A9F-ADC1-338F-A565-DFF617E08BE6>  /Users/USER/Library/Application Support/AppPolicy/AppActivity
                Process:         apple.DevicePropertyReader [5466]
                Path:            /System/Library/Image Capture/Devices/PTPCamera.app/Contents/XPCServices/apple.DevicePropertyReader.xpc/Content s/MacOS/apple.DevicePropertyReader
                Parent:          launchd [1]
                Responsible:     PTPCamera [5463]
                UID:             503
                Task size:       15.89 MB
                  Thread 0x20288            10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                Process:         appleeventsd [57]
                Path:            /System/Library/CoreServices/appleeventsd
                Parent:          launchd [1]
                UID:             55
                Task size:       13.99 MB
                  Thread 0x4fb              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
                  Binary Images:
                           0x1000c2000 -        0x1000c2fff  appleeventsd (712.5)               <04BA7041-9063-3F04-B0BB-5DE3ECB6C013>  /System/Library/CoreServices/appleeventsd
                Process:         AppleIDAuthAgent [355]
                Path:            /System/Library/CoreServices/AppleIDAuthAgent
                Parent:          launchd [1]
                UID:             503
                Task size:       30.95 MB
                  Thread 0xca3              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
                    10  ??? (AppleIDAuthAgent + 10824) [0x107643a48] 1-10
                      10  CFRunLoopRun + 97 (CoreFoundation + 814129) [0x7fff81fbec31] 1-10
                  Thread 0x1470             DispatchQueue 18          10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default, override user initiated), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
                  10  start_wqthread + 13 (libsystem_pthread.dylib + 12529) [0x7fff978fb0f1] 1-10
                    10  _pthread_wqthread + 1299 (libsystem_pthread.dylib + 13846) [0x7fff978fb616] 1-10
                      10  _dispatch_worker_thread3 + 99 (libdispatch.dylib + 13452) [0x7fff976ae48c] 1-10
                        10  _dispatch_root_queue_drain + 476 (libdispatch.dylib + 14005) [0x7fff976ae6b5] 1-10
                          10  _dispatch_queue_invoke + 1046 (libdispatch.dylib + 41734) [0x7fff976b5306] 1-10
                            10  _dispatch_queue_serial_drain + 443 (libdispatch.dylib + 96219) [0x7fff976c27db] 1-10
                              10  _dispatch_source_invoke + 1248 (libdispatch.dylib + 16699) [0x7fff976af13b] 1-10
                                10  _dispatch_source_latch_and_call + 194 (libdispatch.dylib + 51820) [0x7fff976b7a6c] 1-10
                                  10  _dispatch_continuation_pop + 533 (libdispatch.dylib + 92694) [0x7fff976c1a16] 1-10
                                    10  _dispatch_client_callout + 8 (libdispatch.dylib + 6396) [0x7fff976ac8fc] 1-10
                                      10  ??? (AppleIDAuthAgent + 25705) [0x107647469] 1-10
                                        10  _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 43108) [0x7fff976b5864] 1-10
                                          10  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 74654) [0x7fff9780939e] 1-10
                  Thread 0x14f2             10 samples (1-10)         priority 4 (base 4)
                  Thread 0x166c             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x107641000 -        0x107684fff  AppleIDAuthAgent (775.19)               <B4035FFE-7812-3E21-B2F5-02CEBDFC8171>  /System/Library/CoreServices/AppleIDAuthAgent
                Process:         AppleSpell [2689]
                Path:            /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
                Parent:          launchd [1]
                UID:             503
                Task size:       81.16 MB
                  Thread 0xc830             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (AppleSpell + 8648) [0x1098fb1c8] 1-10
                      10  -[NSSpellServer run] + 73 (Foundation + 2086692) [0x7fff83b6c724] 1-10
                  Binary Images:
                           0x1098f9000 -        0x1099f8fff  com.apple.AppleSpell 2.4 (389)         <00AE3ABF-3C83-33BF-8A49-17C38946F37F>  /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
                Process:         AppStatus [459]
                Path:            /Users/USER/Library/Application Support/AppCommon/AppStatus
                Parent:          launchd [1]
                UID:             503
                Task size:       18.56 MB
                  Thread 0xfe6              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                  10  start + 52 (AppStatus + 6948) [0x100001b24] 1-10
                    10  main + 12591 (AppStatus + 451647) [0x10006e43f] 1-10
                  Thread 0x4653             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
                  Binary Images:
                           0x100000000 -        0x1000dafff  AppStatus                              <EC2E7301-9F78-3D8A-8C20-9FE1079414B4>  /Users/USER/Library/Application Support/AppCommon/AppStatus
                Process:         apsd [101]
                Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
                Parent:          launchd [1]
                UID:             0
                Task size:       49.00 MB
                  Thread 0x2bd              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), IO tier 0>
                    10  ??? (apsd + 389558) [0x1054e31b6] 1-10
                  Thread 0xe76              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
                  Thread 0x4f0b             10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user interactive), IO tier 0>
                  Thread 0x7185             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x105484000 -        0x10554efff  apsd (305.1)                            <818B3867-774D-3408-B919-7F6346DAD6EA>  /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
                Process:         ARDAgent [345]
                Path:            /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
                Parent:          launchd [1]
                UID:             503
                Task size:       21.22 MB
                  Thread 0xc18              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                    10  ??? (ARDAgent + 6081) [0x1093f57c1] 1-10
                  Thread 0xc4f              10 samples (1-10)         priority 20 (base 20)
                  Thread 0xc51              10 samples (1-10)         priority 97 (base 97)
                  <thread QoS utility, timers tier 3 (coalesced), IO tier 1>
                  Thread 0x11ee             10 samples (1-10)         priority 20 (base 20)
                        10  ??? (ARDAgent + 49751) [0x109400257] 1-10
                          10  _dispatch_semaphore_wait_slow + 103 (libdispatch.dylib + 43153) [0x7fff976b5891] 1-10
                            10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 74630) [0x7fff97809386] 1-10
                  Thread 0x11f1             10 samples (1-10)         priority 20 (base 20)
                        10  ??? (ARDAgent + 53009) [0x109400f11] 1-10
                  Thread 0x11f2             10 samples (1-10)         priority 20 (base 20)
                        10  __accept + 10 (libsystem_kernel.dylib + 102594) [0x7fff978100c2] 1-10
                         *10  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 1-10
                           *10  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 1-10
                             *10  accept_nocancel + 482 (kernel + 6133394) [0xffffff80007d9692] 1-10
                  Thread 0x32d19            10 samples (1-10)         priority 20 (base 20)
                *10  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-10
                  Binary Images:
                           0x1093f4000 -        0x1094f7fff  com.apple.RemoteDesktopAgent 3.9.2 (3.9.2) <57C03F35-34ED-3521-ACD3-4B6A76423EAD>  /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
                Process:         askpermissiond [359]
                Path:            /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermiss iond
                Parent:          launchd [1]
                UID:             503
                Task size:       21.27 MB
                  Thread 0xca4              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (askpermissiond + 52455) [0x1001ebce7] 1-10
                  Binary Images:
                           0x1001df000 -        0x1001f9fff  askpermissiond (78)                    <1A812667-3249-33DD-B3AE-9F2C2E054177>  /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermiss iond
                Process:         aslmanager [144]
                Path:            /usr/sbin/aslmanager
                Parent:          launchd [1]
                UID:             0
                Task size:       8548 KB
                  Thread 0x3aa              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, IO tier 3>
                  Binary Images:
                           0x10bee1000 -        0x10beeafff  aslmanager (349.50.5)              <3D79D9F7-A61E-33FB-A878-611D0123F7FA>  /usr/sbin/aslmanager
                Process:         AssetCache [377]
                Path:            /usr/libexec/AssetCache/AssetCache
                Parent:          launchd [1]
                UID:             235
                Task size:       17.28 MB
                  Thread 0xd11              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (AssetCache + 6119) [0x10a9eb7e7] 1-10
                      10  ??? (AssetCache + 76716) [0x10a9fcbac] 1-10
                        10  ??? (AssetCache + 79432) [0x10a9fd648] 1-10
                  Binary Images:
                           0x10a9ea000 -        0x10ad1bfff  AssetCache (170)                       <192D7EAD-1094-3C68-A51A-C1CF04899F1A>  /usr/libexec/AssetCache/AssetCache
                Process:         AssetCacheLocatorService [943]
                Path:            /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/Ass etCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
                Parent:          launchd [1]
                UID:             503
                Task size:       11.78 MB
                  Thread 0x1ec2             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 71 (AssetCacheLocatorService + 34884) [0x1060c1844] 1-10
                      10  -[AssetCacheLocatorService start] + 626 (AssetCacheLocatorService + 57455) [0x1060c706f] 1-10
                  Binary Images:
                           0x1060b9000 -        0x1060f3fff  com.apple.AssetCacheLocatorService 48.3 (48.3) <6FD939E9-7C1D-37B8-9DB8-8850F5E1D431>  /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/Ass etCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
                Process:         assistant_service [1942]
                Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/assistant_service
                Parent:          launchd [1]
                UID:             503
                Task size:       96.44 MB
                  Thread 0x780e             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (assistant_service + 5509) [0x1036ca585] 1-10
                  Thread 0x33e98            10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                  Binary Images:
                           0x1036c9000 -        0x1036d3fff  assistant_service (1394.57)            <5740FA7A-C79C-3B98-B9B9-411330E05521>  /System/Library/PrivateFrameworks/AssistantServices.framework/assistant_service
                Process:         assistantd [420]
                Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/assistantd
                Parent:          launchd [1]
                UID:             503
                Task size:       75.89 MB
                  Thread 0x14d3             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (assistantd + 31052) [0x101cc594c] 1-10
                      10  ??? (assistantd + 32861) [0x101cc605d] 1-10
                  Thread 0x7260             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Thread 0x77f5             Thread name "com.apple.CFStream.LegacyThread"       10 samples (1-10)         priority 4 (base 4)
                        10  _legacyStreamRunLoop_workThread + 261 (CoreFoundation + 1435189) [0x7fff82056635] 1-10
                  Thread 0x1ff8f            Thread name "AVVC Rec Queue RunLoop"                10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x101cbe000 -        0x102067fff  assistantd (1394.57)                    <F039C269-B2F8-3262-9E6A-085B0BDDC644>  /System/Library/PrivateFrameworks/AssistantServices.framework/assistantd
                Process:         authd [140]
                Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/M acOS/authd
                Parent:          launchd [1]
                UID:             0
                Task size:       17.16 MB
                  Thread 0x375              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Thread 0x376              DispatchQueue 10          10 samples (1-10)         priority 4 (base 4)
                        10  _dispatch_root_queue_drain + 917 (libdispatch.dylib + 14446) [0x7fff976ae86e] 1-10
                            10  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 42276) [0x7fff976b5524] 1-10
                              10  ??? (authd + 13476) [0x104cc44a4] 1-10
                                10  au_sdev_read_aia + 569 (libbsm.0.dylib + 60343) [0x7fff96262bb7] 1-10
                                  10  fgetc + 52 (libsystem_c.dylib + 253401) [0x7fff97754dd9] 1-10
                                    10  __srget + 14 (libsystem_c.dylib + 280754) [0x7fff9775b8b2] 1-10
                                      10  __srefill1 + 24 (libsystem_c.dylib + 280471) [0x7fff9775b797] 1-10
                                        10  __read_nocancel + 10 (libsystem_kernel.dylib + 105926) [0x7fff97810dc6] 1-10
                                                   *10  spec_read + 201 (kernel + 3497273) [0xffffff8000555d39] 1-10
                                                     *10  ??? (kernel + 5438740) [0xffffff800072fd14] 1-10
                  Binary Images:
                           0x104cc1000 -        0x104cd8fff  com.apple.authd 1.0 ()             <D7484BAE-15D5-31A4-8C05-C4C939362366>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/M acOS/authd
                        0x7fff96254000 -     0x7fff96264fff  libbsm.0.dylib (34)                <20084796-B04D-3B35-A003-EA11459557A9>  /usr/lib/libbsm.0.dylib
                Process:         autofsd [115]
                Path:            /usr/libexec/autofsd
                Parent:          launchd [1]
                UID:             0
                Task size:       7688 KB
                  Thread 0x406              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
                  Binary Images:
                           0x108a58000 -        0x108a58fff  autofsd (259.30.2)                 <36268EDC-126D-39D6-82FC-C9DADF0F6227>  /usr/libexec/autofsd
                Process:         awacsd [206]
                Path:            /usr/libexec/awacsd
                Parent:          launchd [1]
                UID:             0
                Task size:       26.18 MB
                  Thread 0x572              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested default), process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
                  Thread 0x5f5              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
                  Thread 0x7bbe             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested utility), process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
                  Thread 0x355d0            10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility, process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
                  Binary Images:
                           0x10842a000 -        0x1084a4fff  awacsd (118.20.1)                       <B125474E-010F-39C5-8A33-9A9854234F8A>  /usr/libexec/awacsd
                Process:         awdd [233]
                Path:            /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
                Parent:          launchd [1]
                UID:             0
                Task size:       15.82 MB
                  Thread 0x6b2              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (awdd + 21475) [0x1086493e3] 1-10
                  Binary Images:
                           0x108644000 -        0x108729fff  awdd (869)                             <F49410F8-D2A5-366E-8D18-7FAA5BB521C6>  /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
                Process:         bash [69]
                Path:            /bin/bash
                Parent:          launchd [1]
                UID:             0
                Task size:       2476 KB
                  Thread 0x2d4              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                    10  ??? (bash + 7616) [0x1043a8dc0] 1-10
                      10  ??? (bash + 116303) [0x1043c364f] 1-10
                        10  ??? (bash + 117276) [0x1043c3a1c] 1-10
                          10  ??? (bash + 129203) [0x1043c68b3] 1-10
                            10  ??? (bash + 157036) [0x1043cd56c] 1-10
                              10  __wait4 + 10 (libsystem_kernel.dylib + 107502) [0x7fff978113ee] 1-10
                  Binary Images:
                           0x1043a7000 -        0x10442afff  bash (103.50.1)                    <E16744EF-F6E7-3AAD-9D54-3CCE90F8ABA1>  /bin/bash
                Process:         BetterTouchTool [3528]
                Path:            /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
                Parent:          launchd [1]
                UID:             503
                Task size:       65.75 MB
                CPU Time:        <0.001
                Process:         biokitaggdd [256]
                Path:            /usr/libexec/biokitaggdd
                Parent:          launchd [1]
                UID:             0
                Task size:       9212 KB
                  Thread 0x81a              10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 2>
                  Binary Images:
                           0x106440000 -        0x106446fff  biokitaggdd (5.50.1)               <5A3BD8E8-F140-34C5-97F2-3852AD0C5767>  /usr/libexec/biokitaggdd
                Process:         biometrickitd [227]
                Path:            /usr/libexec/biometrickitd
                Parent:          launchd [1]
                UID:             0
                Task size:       22.40 MB
                Note:            2 idle work queue threads omitted
                  Thread 0x662              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (biometrickitd + 312949) [0x1029d1675] 1-10
                  Binary Images:
                           0x102985000 -        0x102a06fff  biometrickitd (424.16)                 <D9177D22-1466-34D4-98E4-72434F11E7CF>  /usr/libexec/biometrickitd
                Process:         bird [328]
                Path:            /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
                Parent:          launchd [1]
                UID:             503
                Task size:       32.82 MB
                  Thread 0xb8f              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Finder [325], IO tier 0>
                    10  ??? (bird + 6002) [0x1008b5772] 1-10
                  Binary Images:
                           0x1008b4000 -        0x1008b5fff  bird (486.28)                          <4361594B-F3A5-3534-9E92-BAC5C54B6433>  /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
                Process:         blued [114]
                Path:            /usr/sbin/blued
                Parent:          launchd [1]
                UID:             0
                Task size:       17.96 MB
                  Thread 0x2cb              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (blued + 187775) [0x106af2d7f] 1-10
                  Thread 0x731              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x106ac5000 -        0x106b98fff  blued (5004.4.18)                      <0675C360-4485-3399-A0D5-F7EBAB1DF761>  /usr/sbin/blued
                Process:         BTTRelaunch [3530]
                Path:            /Applications/BetterTouchTool.app/Contents/Resources/BTTRelaunch.app/Contents/MacOS/BTTRe launch
                Parent:          launchd [1]
                UID:             503
                Task size:       24.24 MB
                Process:         CalendarAgent [445]
                Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
                Parent:          launchd [1]
                UID:             503
                Task size:       68.07 MB
                  Thread 0x12a7             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (CalendarAgent + 6233) [0x109af8859] 1-10
                  Thread 0x1e1d             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x109af7000 -        0x109af8fff  CalendarAgent (386)                     <0EAFB1E4-7D3B-3122-AF64-2CD36B4CAA26>  /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
                Process:         CallHistoryPluginHelper [544]
                Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
                Parent:          launchd [1]
                UID:             503
                Task size:       26.20 MB
                  Thread 0x134b             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (CallHistoryPluginHelper + 5507) [0x10180a583] 1-10
                  Binary Images:
                           0x101809000 -        0x10180afff  CallHistoryPluginHelper (676)          <65E39669-058F-3925-A072-FE0D4254EE09>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
                Process:         CallHistorySyncHelper [358]
                Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
                Parent:          launchd [1]
                UID:             503
                Task size:       27.29 MB
                  Thread 0xca8              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (CallHistorySyncHelper + 70400) [0x10ea57300] 1-10
                  Binary Images:
                           0x10ea46000 -        0x10ea66fff  CallHistorySyncHelper (676)            <13886907-B5B0-31D8-A466-75AB561E6B08>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
                Process:         callservicesd [327]
                Path:            /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
                Parent:          launchd [1]
                UID:             503
                Task size:       53.48 MB
                  Thread 0xb8b              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (callservicesd + 914458) [0x10475e41a] 1-10
                  Binary Images:
                           0x10467f000 -        0x1047c2fff  callservicesd (838.3.7)                <2447A0E6-3C5B-3415-842E-845B910A7195>  /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
                Process:         CalNCService [536]
                Path:            /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/C alNCService.xpc/Contents/MacOS/CalNCService
                Parent:          launchd [1]
                Responsible:     CalendarAgent [445]
                UID:             503
                Task size:       49.80 MB
                  Thread 0x12dc             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 111 (CalNCService + 45654) [0x10ba90256] 1-10
                      10  -[NSXPCListener resume] + 165 (Foundation + 524571) [0x7fff839ef11b] 1-10
                        10  xpc_main + 494 (libxpc.dylib + 62180) [0x7fff9793a2e4] 1-10
                          10  _xpc_objc_main + 731 (libxpc.dylib + 67739) [0x7fff9793b89b] 1-10
                  Binary Images:
                           0x10ba85000 -        0x10ba93fff  com.apple.CalendarNotification.CalNCService 1.0 (507.6) <18ED1256-D076-3514-A4DD-132269BDA25B>  /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/C alNCService.xpc/Contents/MacOS/CalNCService
                        0x7fff9792b000 -     0x7fff97954fff  libxpc.dylib (972.50.27)                                <ABC45890-DA23-3A4A-B50B-1384BD4CBBDF>  /usr/lib/system/libxpc.dylib
                Process:         captiveagent [951]
                Path:            /usr/libexec/captiveagent
                Parent:          launchd [1]
                UID:             258
                Task size:       13.32 MB
                  Thread 0x1f1a             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from configd [58], IO tier 0>
                  Thread 0x1f1e             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
                  Thread 0x70dc             Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x10834e000 -        0x108355fff  captiveagent (346.50.1)            <3DF3F257-09F4-302E-8ED2-81164EE81D86>  /usr/libexec/captiveagent
                Process:         cfprefsd [135]
                Path:            /usr/sbin/cfprefsd
                Parent:          launchd [1]
                UID:             0
                Task size:       9276 KB
                CPU Time:        <0.001
                  Thread 0x33f              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10db26000 -        0x10db26fff  cfprefsd (1349.65)                 <1A1890FC-5C36-3055-A293-C955B09CBAB3>  /usr/sbin/cfprefsd
                Process:         cfprefsd [312]
                Parent:          launchd [1]
                UID:             503
                Task size:       14.58 MB
                CPU Time:        <0.001
                Note:            6 idle work queue threads omitted
                  Thread 0xa54              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x101ee2000 -        0x101ee2fff  cfprefsd (1349.65)                 <1A1890FC-5C36-3055-A293-C955B09CBAB3>  /usr/sbin/cfprefsd
                Process:         Citations [473]
                Path:            /Applications/Papers.app/Contents/SharedSupport/Citations.app/Contents/MacOS/Citations
                Parent:          launchd [1]
                UID:             503
                Task size:       65.59 MB
                Process:         CleanApp Daemon [3686]
                Path:            /Library/Application Support/CleanApp/CleanApp Daemon.app/Contents/MacOS/CleanApp Daemon
                Architecture:    i386
                Parent:          launchd [1]
                UID:             0
                Task size:       18.85 MB
                CPU Time:        <0.001
                Process:         cloudd [350]
                Path:            /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
                Parent:          launchd [1]
                UID:             503
                Task size:       44.93 MB
                Note:            10 idle work queue threads omitted
                  Thread 0xc59              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from Safari [4589], IO tier 0>
                    10  ??? (cloudd + 10716) [0x10d02f9dc] 1-10
                  Thread 0x1d7e             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
                  Thread 0x7678             Thread name "com.apple.CFStream.LegacyThread"       10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x10d02d000 -        0x10d032fff  cloudd (651.14)                        <E0EF61B8-731F-3698-9707-0F2297737232>  /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
                Process:         CloudKeychainProxy [402]
                Path:            /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bun dle/Contents/MacOS/CloudKeychainProxy
                Parent:          launchd [1]
                UID:             503
                Task size:       21.36 MB
                  Thread 0xe5d              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (CloudKeychainProxy + 48371) [0x109638cf3] 1-10
                  Binary Images:
                           0x10962d000 -        0x109641fff  com.apple.security.cloudkeychainproxy3 10.0 () <6A636FFB-2181-3E94-85AD-EB677C09D7F2>  /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bun dle/Contents/MacOS/CloudKeychainProxy
                Process:         cloudpaird [448]
                Path:            /System/Library/CoreServices/cloudpaird
                Parent:          launchd [1]
                UID:             503
                Task size:       26.18 MB
                  Thread 0x14e2             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (cloudpaird + 64917) [0x1071d2d95] 1-10
                  Binary Images:
                           0x1071c3000 -        0x1071e0fff  cloudpaird (5004.4.18)                 <AD97547C-2247-31C1-A4EA-2264E11ADA53>  /System/Library/CoreServices/cloudpaird
                Process:         cloudphotosd [347]
                Path:            /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
                Parent:          launchd [1]
                UID:             503
                Task size:       55.80 MB
                  Thread 0xc56              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 115 (cloudphotosd + 738778) [0x105da25da] 1-10
                  Thread 0xf6d              Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                  Thread 0x1eba             10 samples (1-10)         priority 4 (base 4)
                  Thread 0x1ebd             10 samples (1-10)         priority 4 (base 4)
                  Thread 0x1ec5             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x105cee000 -        0x105de0fff  com.apple.cloudphotosd 2.0 (3150.4.120) <1C223A5B-85FC-32B2-8E0F-D4A67FACE558>  /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
                Process:         com.apple.accessibility.mediaaccessibilityd [1932]
                Path:            /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple. accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessib ilityd
                Parent:          launchd [1]
                UID:             503
                Task size:       7672 KB
                  Thread 0x7789             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10b20b000 -        0x10b20cfff  com.apple.accessibility.mediaaccessibilityd 1.0 (1) <98ACFA8C-EC73-3497-9644-32A817DC96A8>  /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple. accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessib ilityd
                Process:         com.apple.AccountPolicyHelper [290]
                Path:            /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPo licyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
                Parent:          launchd [1]
                UID:             0
                Task size:       8196 KB
                  Thread 0x941              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1001f5000 -        0x1001fefff  com.apple.AccountPolicyHelper 1.0 (1) <5A295718-2EDC-307E-A73F-FEF88E7427EB>  /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPo licyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
                Process:         com.apple.AmbientDisplayAgent [254]
                Path:            /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.app le.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
                Parent:          launchd [1]
                UID:             0
                Task size:       15.45 MB
                  Thread 0x7f6              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 312 (com.apple.AmbientDisplayAgent + 8932) [0x10ee302e4] 1-10
                  Thread 0x873              10 samples (1-10)         priority 4 (base 4)
                        10  ??? (com.apple.AmbientDisplayAgent + 10552) [0x10ee30938] 1-10
                  Binary Images:
                           0x10ee2e000 -        0x10ee34fff  com.apple.AmbientDisplayAgent 1.0 (1)  <13CCDBE2-0ED7-37A4-A05C-9662D6ED9280>  /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.app le.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
                Process:         com.apple.audio.ComponentHelper [5431]
                Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHe lper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
                Parent:          launchd [1]
                Responsible:     assistantd [420]
                UID:             503
                Task size:       9324 KB
                  Thread 0x1ff78            10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10a015000 -        0x10a016fff  com.apple.audio.ComponentHelper 1.0.1 (1) <10948385-A27A-3918-8095-EBAFA2E5B0D2>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHe lper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
                Process:         com.apple.audio.DriverHelper [216]
                Path:            /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.Dri verHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
                Parent:          launchd [1]
                Responsible:     coreaudiod [212]
                UID:             202
                Task size:       9768 KB
                  Thread 0x5dd              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1085da000 -        0x1085dcfff  com.apple.audio.DriverHelper 1.0 (1) <D25F3404-3146-39B9-A8BA-0ED1F4D0CF0C>  /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.Dri verHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
                Process:         com.apple.audio.SandboxHelper [295]
                Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Parent:          launchd [1]
                Responsible:     systemsoundserverd [292]
                UID:             0
                Task size:       11.80 MB
                  Thread 0x95a              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10ddc8000 -        0x10ddccfff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.audio.SandboxHelper [623]
                Parent:          launchd [1]
                UID:             503
                Task size:       11.91 MB
                  Thread 0x1627             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1032a6000 -        0x1032aafff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.audio.SandboxHelper [4703]
                Parent:          launchd [1]
                Responsible:     Mail [1964]
                UID:             503
                Task size:       11.34 MB
                  Thread 0x1a825            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10ba32000 -        0x10ba36fff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.audio.SandboxHelper [4896]
                Parent:          launchd [1]
                Responsible:     Safari [4589]
                UID:             503
                Task size:       11.43 MB
                  Thread 0x1bfe4            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10ddb9000 -        0x10ddbdfff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.audio.SandboxHelper [5097]
                Parent:          launchd [1]
                UID:             503
                Task size:       11.37 MB
                  Thread 0x1d974            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x103e6d000 -        0x103e71fff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.audio.SandboxHelper [5434]
                Parent:          launchd [1]
                Responsible:     com.apple.speech.speechsynthesisd [5432]
                UID:             503
                Task size:       11.20 MB
                  Thread 0x2004f            10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x101241000 -        0x101245fff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.audio.SandboxHelper [7740]
                Parent:          launchd [1]
                UID:             503
                Task size:       11.81 MB
                  Thread 0x30ddb            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x100847000 -        0x10084bfff  com.apple.audio.SandboxHelper 1.0.1 (1) <4C1181EF-4313-3FDE-B8F9-F1D29E990E41>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.CharacterPicker.FileService [490]
                Path:            /System/Library/PrivateFrameworks/CharacterPicker.framework/Versions/A/XPCServices/com.ap ple.CharacterPicker.FileService.xpc/Contents/MacOS/com.apple.CharacterPicker.FileService
                Parent:          launchd [1]
                UID:             503
                Task size:       15.55 MB
                  Thread 0x1115             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 16 (com.apple.CharacterPicker.FileService + 6174) [0x103b4781e] 1-10
                  Binary Images:
                           0x103b46000 -        0x103b4ffff  com.apple.CharacterPicker.FileService 1.0 (1) <71F01DD8-93D0-332D-9CA4-C3AD6EE25CC0>  /System/Library/PrivateFrameworks/CharacterPicker.framework/Versions/A/XPCServices/com.ap ple.CharacterPicker.FileService.xpc/Contents/MacOS/com.apple.CharacterPicker.FileService
                Process:         com.apple.CloudPhotosConfiguration [417]
                Path:            /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/Clou dPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguratio n.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
                Parent:          launchd [1]
                UID:             503
                Task size:       27.11 MB
                  Thread 0xf66              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 24 (com.apple.CloudPhotosConfiguration + 9956) [0x10b9486e4] 1-10
                      10  +[CPSConfigurationService run] + 53 (com.apple.CloudPhotosConfiguration + 10276) [0x10b948824] 1-10
                        10  -[CPSConfigurationService run] + 199 (com.apple.CloudPhotosConfiguration + 10488) [0x10b9488f8] 1-10
                  Binary Images:
                           0x10b946000 -        0x10b957fff  com.apple.CloudPhotosConfiguration 2.0 (3150.4.120) <468A73D0-DF3D-3E6C-83EC-C24BABCCD66A>  /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/Clou dPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguratio n.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
                Process:         com.apple.CodeSigningHelper [262]
                Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSignin gHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
                Parent:          launchd [1]
                UID:             0
                Task size:       10028 KB
                  Thread 0x863              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10874f000 -        0x108750fff  com.apple.CodeSigningHelper 1.0 (1) <E659A190-F50B-3EAF-98A8-E69CD340B0EB>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSignin gHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
                Process:         com.apple.ColorSyncXPCAgent [8010]
                Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/XPCServices/com.apple.ColorSyncXPCAgent.xpc/Contents/MacOS/com.apple. ColorSyncXPCAgent
                Parent:          launchd [1]
                UID:             503
                Task size:       6704 KB
                  Thread 0x32d46            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Thread 0x32d4b            10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x104c1b000 -        0x104c1dfff  com.apple.ColorSyncXPCAgent 1.0 (1) <A0E01710-46FE-338E-AAE4-55E4CFD5B873>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/XPCServices/com.apple.ColorSyncXPCAgent.xpc/Contents/MacOS/com.apple. ColorSyncXPCAgent
                Process:         com.apple.CommerceKit.TransactionService [521]
                Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple. CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
                Parent:          launchd [1]
                Responsible:     storeaccountd [389]
                UID:             503
                Task size:       21.62 MB
                  Thread 0x1257             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x102bdf000 -        0x102dbffff  com.apple.CommerceKit.TransactionService 1.0 (582.5) <F53996E7-9B29-32CD-962F-3BAC16B9C8DA>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple. CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
                Process:         com.apple.ctkpcscd [147]
                Path:            /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/C ontents/MacOS/com.apple.ctkpcscd
                Parent:          launchd [1]
                Responsible:     securityd [108]
                UID:             0
                Task size:       12.14 MB
                  Thread 0x3d6              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10d631000 -        0x10d63bfff  com.apple.ctkpcscd 1.0 (1)         <850303B0-91C7-33D5-98A2-43B2FE07DD42>  /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/C ontents/MacOS/com.apple.ctkpcscd
                Process:         com.apple.DFRSystemExtra.InputMenu [547]
                Path:            /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExt ra.InputMenu.xpc/Contents/MacOS/com.apple.DFRSystemExtra.InputMenu
                Parent:          launchd [1]
                Responsible:     ControlStrip [415]
                UID:             503
                Task size:       27.06 MB
                  Thread 0x13b4             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
                    10  main + 21 (com.apple.DFRSystemExtra.InputMenu + 16051) [0x1041f7eb3] 1-10
                      10  DFRSystemExtraMain + 254 (DFRFoundation + 7633) [0x7fff8df7add1] 1-10
                          10  _xpc_objc_main + 775 (libxpc.dylib + 67783) [0x7fff9793b8c7] 1-10
                  <process clamped>
                  Thread 0x13ee             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 31 (base 31)
                  <process clamped>
                  Thread 0x29282            10 samples (1-10)         priority 31 (base 31)
                  <process clamped>
                  Binary Images:
                           0x1041f4000 -        0x1041fafff  com.apple.DFRSystemExtra.InputMenu 1.0 (1)     <7CE861D7-5801-3E6C-9395-22474A8C160F>  /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExt ra.InputMenu.xpc/Contents/MacOS/com.apple.DFRSystemExtra.InputMenu
                        0x7fff8df79000 -     0x7fff8df83fff  com.apple.framework.DFRFoundation 1.0 (104.25) <A509BF55-7829-3633-A500-EF0B4E21F46B>  /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
                Process:         com.apple.DFRSystemExtra.Siri [5424]
                Path:            /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExt ra.Siri.xpc/Contents/MacOS/com.apple.DFRSystemExtra.Siri
                Parent:          launchd [1]
                UID:             503
                Task size:       21.58 MB
                  Thread 0x1ff31            10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1083d8000 -        0x1083d9fff  com.apple.DFRSystemExtra.Siri 1.0 (1) <31B13320-9F1F-3B49-B2C6-889E523BDE56>  /System/Library/CoreServices/ControlStrip.app/Contents/XPCServices/com.apple.DFRSystemExt ra.Siri.xpc/Contents/MacOS/com.apple.DFRSystemExtra.Siri
                Process:         com.apple.DictionaryServiceHelper [947]
                Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/co m.apple.DictionaryServiceHelper
                Architecture:    x86_64
                Parent:          launchd [1]
                UID:             503
                Task size:       7556 KB
                  Thread 0x1ef2             10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10e641000 -        0x10e646fff  com.apple.DictionaryServiceHelper 1.0 (1) <A061ECBD-D1F9-3BFE-A1A4-DC8F6C3AC8A1>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/co m.apple.DictionaryServiceHelper
                Process:         com.apple.dock.extra [517]
                Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
                Parent:          launchd [1]
                Responsible:     Dock [322]
                UID:             503
                Task size:       46.21 MB
                  Thread 0x11bf             DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
                  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0>
                    10  ??? (com.apple.dock.extra + 4131) [0x103d27023] 1-10
                  <process clamped>
                  Thread 0x1334             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                  <process clamped>
                  Thread 0x28cbf            10 samples (1-10)         priority 31 (base 31)
                  <process sudden termination dirty, process unclamped, IO tier 0>
                  <process clamped>
                  Binary Images:
                           0x103d26000 -        0x103d29fff  com.apple.dock.extra 1.0 (1)           <1EC94376-9485-3284-BE07-E89BF598D04D>  /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
                Process:         com.apple.geod [407]
                Path:            /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
                Parent:          launchd [1]
                UID:             503
                Task size:       31.59 MB
                  Thread 0xead              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 1148 (com.apple.geod + 72697) [0x10fe9fbf9] 1-10
                  Thread 0xed4              Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
                        10  _runNetworkThread + 445 (GeoServices + 4445674) [0x7fff903715ea] 1-10
                  Thread 0xedd              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10fe8e000 -        0x10fea4fff  com.apple.geod 1.0 (1228.24.9.30.34)        <FDF600BB-B52A-3AE8-A5D1-51474AB17023>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
                        0x7fff8ff34000 -     0x7fff905e6fff  com.apple.GeoServices 1.0 (1228.24.9.30.34) <B482AFD6-8E27-3204-A5AA-FD73A1F32B32>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                Process:         com.apple.geod [1157]
                Parent:          launchd [1]
                UID:             0
                Task size:       22.79 MB
                  Thread 0x2ddf             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 1148 (com.apple.geod + 72697) [0x10498dbf9] 1-10
                  Thread 0x2df4             Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
                  Thread 0x2dfc             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10497c000 -        0x104992fff  com.apple.geod 1.0 (1228.24.9.30.34)    <FDF600BB-B52A-3AE8-A5D1-51474AB17023>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
                Process:         com.apple.GSSCred [298]
                Path:            /System/Library/Frameworks/GSS.framework/Helpers/com.apple.GSSCred
                Parent:          launchd [1]
                UID:             0
                Task size:       7204 KB
                  Thread 0x996              DispatchQueue 8           10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
                              10  ??? (com.apple.GSSCred + 11079) [0x103959b47] 1-10
                  Thread 0x998              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
                  Binary Images:
                           0x103957000 -        0x10395efff  com.apple.GSSCred (498.50.8)       <33AAE98E-BF59-3C7E-819E-3B9B02C60AC4>  /System/Library/Frameworks/GSS.framework/Helpers/com.apple.GSSCred
                Process:         com.apple.hiservices-xpcservice [899]
                Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.a pple.hiservices-xpcservice
                Parent:          launchd [1]
                UID:             503
                Task size:       11.48 MB
                  Thread 0x1c69             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x105f7b000 -        0x105f7ffff  com.apple.hiservices-xpcservice 1.22 (591) <99A12FDF-2CB2-352E-88A3-C7B93308B79A>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.a pple.hiservices-xpcservice
                Process:         com.apple.iCloudHelper [6081]
                Path:            /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
                Parent:          launchd [1]
                UID:             503
                Task size:       24.66 MB
                  Thread 0x246ac            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1052f2000 -        0x105304fff  com.apple.iCloudHelper 1.07 (245)  <587F020C-5AC5-3D42-B619-64FC1228BF97>  /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
                Process:         com.apple.ifdreader [225]
                Path:            /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdread er
                Parent:          launchd [1]
                UID:             0
                Task size:       12.54 MB
                  Thread 0x660              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  10  start + 1 (libdyld.dylib + 21045) [0x7fff976e2235] 1-10
                    10  main + 1179 (com.apple.ifdreader + 5165) [0x10f11c42d] 1-10
                          10  CFRunLoopRunSpecific + 420 (CoreFoundation + 553412) [0x7fff81f7f1c4] 1-10
                  Binary Images:
                           0x10f11b000 -        0x10f126fff  com.apple.ifdreader 1.0 (1)            <BD2FF633-DB68-3DB3-8B13-FBFB9D410CD1>  /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdread er
                Process:         com.apple.iTunesLibraryService [621]
                Path:            /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibrar yService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
                Parent:          launchd [1]
                UID:             503
                Task size:       20.19 MB
                  Thread 0x161d             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x104704000 -        0x1047c3fff  com.apple.iTunesLibraryService 12.6 (12.6.0) <A29FB373-FACB-3BD9-8014-A3042EC25704>  /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibrar yService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
                Process:         com.apple.iTunesLibraryService [1944]
                Parent:          launchd [1]
                Responsible:     assistant_service [1942]
                UID:             503
                Task size:       17.11 MB
                  Thread 0x7825             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10ca60000 -        0x10cb1ffff  com.apple.iTunesLibraryService 12.6 (12.6.0) <A29FB373-FACB-3BD9-8014-A3042EC25704>  /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibrar yService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
                Process:         com.apple.notificationcenterui.WeatherSummary [520]
                Path:            /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notifi cationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSum mary
                Parent:          launchd [1]
                Responsible:     NotificationCenter (Notification Center) [432]
                UID:             503
                Task size:       18.99 MB
                  Thread 0x121e             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 147 (com.apple.notificationcenterui.WeatherSummary + 6316) [0x1049fd8ac] 1-10
                  Binary Images:
                           0x1049fc000 -        0x1049fefff  com.apple.notificationcenterui.WeatherSummary 1.0 (552.27) <BFCC76C3-A7E0-359C-AB2C-41920F28997D>  /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notifi cationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSum mary
                Process:         com.apple.PerformanceAnalysis.animationperfd [246]
                Path:            /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/co m.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysi s.animationperfd
                Parent:          launchd [1]
                UID:             0
                Task size:       15.54 MB (-40 KB)
                CPU Time:        <0.001
                Note:            3 idle work queue threads omitted
                  Thread 0x7b3              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x103af8000 -        0x103b01fff  com.apple.PerformanceAnalysis.animationperfd 1.2 (2) <E1044B93-AC85-3D33-AF9A-9FD17D274584>  /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/co m.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysi s.animationperfd
                Process:         com.apple.PhotoIngestService [938]
                Path:            /System/Library/PrivateFrameworks/PhotoLibrary.framework/Versions/A/XPCServices/com.apple .PhotoIngestService.xpc/Contents/MacOS/com.apple.PhotoIngestService
                Parent:          launchd [1]
                Responsible:     cloudphotosd [347]
                UID:             503
                Task size:       20.68 MB
                  Thread 0x1eb7             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  10  <truncated backtrace> 1-10
                     *10  ??? (kernel + 5801776) [0xffffff8000788730] 1-10
                  Binary Images:
                           0x109225000 -        0x10922dfff  com.apple.PhotoIngestService 2.0 (3150.4.120) <EC18FB2E-5E2E-36AD-B976-4D52E040A633>  /System/Library/PrivateFrameworks/PhotoLibrary.framework/Versions/A/XPCServices/com.apple .PhotoIngestService.xpc/Contents/MacOS/com.apple.PhotoIngestService
                Process:         com.apple.photomoments [935]
                Path:            /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/Pho toLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/Mac OS/com.apple.photomoments
                Parent:          launchd [1]
                Responsible:     photolibraryd [573]
                UID:             503
                Task size:       29.39 MB
                  Thread 0x1e62             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 502 (com.apple.photomoments + 6307) [0x10f7838a3] 1-10
                                  10  __CFRunLoopRun + 1361 (CoreFoundation + 555377) [0x7fff81f7f971] 1-10
                                    10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 558308) [0x7fff81f804e4] 1-10
                                      10  mach_msg_trap + 10 (libsystem_kernel.dylib + 74570) [0x7fff9780934a] 1-10
                                       *10  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-10
                  Thread 0x1e98             Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10f782000 -        0x10f787fff  com.apple.photomoments 2.0 (3150.4.120) <B4C51E10-772C-3A4A-9601-11FF55EC3E23>  /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/Pho toLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/Mac OS/com.apple.photomoments
                Process:         com.apple.quicklook.ThumbnailsAgent [372]
                Path:            /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quick look.ThumbnailsAgent
                Parent:          launchd [1]
                UID:             503
                Task size:       13.89 MB
                  Thread 0xd1e              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (com.apple.quicklook.ThumbnailsAgent + 41096) [0x104696088] 1-10
                  Binary Images:
                           0x10468c000 -        0x10469bfff  com.apple.quicklook.ThumbnailsAgent (14.1) <D0787288-3D64-37FE-8AA0-AC62958E5D9E>  /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quick look.ThumbnailsAgent
                Process:         com.apple.Safari.History [877]
                Path:            /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple .Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
                Parent:          launchd [1]
                Responsible:     Spotlight [463]
                UID:             503
                Task size:       26.36 MB
                  Thread 0x1bc9             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  Thread 0x1d36             10 samples (1-10)         priority 4 (base 4)
                    10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 105458) [0x7fff97810bf2] 1-10
                     *10  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-10
                  Binary Images:
                           0x10de3b000 -        0x10de3bfff  com.apple.Safari.History 12603 (12603.1.30.0.34) <59A2B232-DC88-3409-8987-09DDEC59B2A4>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple .Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
                Process:         com.apple.Safari.ImageDecoder [4662]
                Path:            /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple .Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder
                Parent:          launchd [1]
                UID:             503
                Task size:       29.77 MB
                  Thread 0x1a47d            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (com.apple.Safari.ImageDecoder + 6550) [0x1028da996] 1-10
                  Binary Images:
                           0x1028d9000 -        0x1028dafff  com.apple.Safari.ImageDecoder 12603 (12603.1.30.0.34) <9D41229D-27CE-33E5-8C94-F3D790B03B5A>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple .Safari.ImageDecoder.xpc/Contents/MacOS/com.apple.Safari.ImageDecoder
                        0x7fff81ef8000 -     0x7fff82391fff  com.apple.CoreFoundation 6.9 (1349.65)                <F79384D1-FA3F-38CA-A847-B2625EBB790E>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                        0x7fff8396f000 -     0x7fff83d15fff  com.apple.Foundation 6.9 (1349.64)                    <49C8DA40-9E5B-33F9-B092-F50115B59E95>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                        0x7fff976dd000 -     0x7fff976e2fff  libdyld.dylib (433.5)                                 <129D3B44-FB21-3750-9A68-48B5C3DC632B>  /usr/lib/system/libdyld.dylib
                        0x7fff977f7000 -     0x7fff97819fff  libsystem_kernel.dylib (3789.51.2)                    <FC51D7B0-8292-3F6A-9231-64340B237EB7>  /usr/lib/system/libsystem_kernel.dylib
                   *0xffffff8000200000 - 0xffffff80009fffff  kernel (3789.51.2)                                    <06F94FD7-451F-34A1-B13C-D68FF7EDE0A0>  /System/Library/Kernels/kernel
                Process:         com.apple.Safari.SafeBrowsing.Service [922]
                Path:            /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safar i.SafeBrowsing.Service
                Parent:          launchd [1]
                UID:             503
                Sudden Term:     Tracked (allows idle exit)
                Task size:       26.60 MB
                  Thread 0x1d4d             10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                  Thread 0x15510            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  10  thread_start + 13 (libsystem_pthread.dylib + 12545) [0x7fff978fb101] 1-10
                    10  _pthread_start + 286 (libsystem_pthread.dylib + 14587) [0x7fff978fb8fb] 1-10
                      10  _pthread_body + 180 (libsystem_pthread.dylib + 14767) [0x7fff978fb9af] 1-10
                        10  __NSThread__start__ + 1243 (Foundation + 207821) [0x7fff839a1bcd] 1-10
                          10  +[NSURLConnection(Loader) _resourceLoadLoop:] + 313 (CFNetwork + 26116) [0x7fff810bd604] 1-10
                  Binary Images:
                           0x106457000 -        0x106457fff  com.apple.Safari.SafeBrowsing.Service (7603.1.30.0.34) <850386CF-46C1-3F7F-9680-B22A722454D5>  /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safar i.SafeBrowsing.Service
                        0x7fff810b7000 -     0x7fff81491fff  com.apple.CFNetwork 811.4.18 (811.4.18)                <9CE329E8-6177-3474-976D-F5C63FC875CD>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                        0x7fff978f8000 -     0x7fff97902fff  libsystem_pthread.dylib (218.51.1)                     <62A84A68-431D-3B54-A7B6-31367CCF2884>  /usr/lib/system/libsystem_pthread.dylib
                Process:         com.apple.Safari.SearchHelper [4671]
                Path:            /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple .Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
                Parent:          launchd [1]
                UID:             503
                Task size:       36.59 MB
                Note:            5 idle work queue threads omitted
                  Thread 0x1a4d3            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (com.apple.Safari.SearchHelper + 7075) [0x10a46aba3] 1-10
                  Thread 0x1a4d7            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10a469000 -        0x10a46ffff  com.apple.Safari.SearchHelper 12603 (12603.1.30.0.34) <121B875A-6877-33AA-ACFA-9DB882C04611>  /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple .Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
                Process:         com.apple.SafariServices [879]
                Path:            /System/Library/Frameworks/SafariServices.framework/Versions/A/XPCServices/com.apple.Safa riServices.xpc/Contents/MacOS/com.apple.SafariServices
                Parent:          launchd [1]
                UID:             503
                Task size:       28.73 MB
                  Thread 0x1bdd             10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x107d7d000 -        0x107d7ffff  com.apple.SafariServices 12603 (12603.1.30.0.34) <497E71C7-F37B-3995-A51D-B23AFA0B66BF>  /System/Library/Frameworks/SafariServices.framework/Versions/A/XPCServices/com.apple.Safa riServices.xpc/Contents/MacOS/com.apple.SafariServices
                Process:         com.apple.sbd [1928]
                Path:            /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.appl e.sbd.xpc/Contents/MacOS/com.apple.sbd
                Parent:          launchd [1]
                UID:             503
                Task size:       28.57 MB
                Note:            1 idle work queue threads omitted
                  Thread 0x775f             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (com.apple.sbd + 205787) [0x10e3b23db] 1-10
                  Binary Images:
                           0x10e380000 -        0x10e3cafff  com.apple.sbd 1.0 (222.51.1)           <BC39E313-2FC1-3C24-AEDC-617165CE605E>  /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.appl e.sbd.xpc/Contents/MacOS/com.apple.sbd
                Process:         com.apple.speech.speechsynthesisd [5432]
                Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
                Parent:          launchd [1]
                UID:             503
                Task size:       20.64 MB
                  Thread 0x1ff8e            10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x10c393000 -        0x10c3a4fff  com.apple.speech.speechsynthesisd (6.3.3) <4F06A371-5B76-3B08-8F4E-1396325EBBA3>  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/SpeechSynthesis.frame work/Resources/com.apple.speech.speechsynthesisd
                Process:         com.apple.spotlight.IndexAgent [893]
                Path:            /System/Library/PrivateFrameworks/CoreSpotlight.framework/Support/com.apple.spotlight.Ind exAgent
                Parent:          launchd [1]
                UID:             503
                Task size:       12.88 MB
                  Thread 0x1c79             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                  Binary Images:
                           0x101eaa000 -        0x101eabfff  com.apple.spotlight.IndexAgent (144) <A9703E1E-BB4A-374B-8D67-52EB6E24BBDA>  /System/Library/PrivateFrameworks/CoreSpotlight.framework/Support/com.apple.spotlight.Ind exAgent
                Process:         com.apple.WeatherKitService [937]
                Path:            /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.W eatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
                Parent:          launchd [1]
                UID:             503
                Task size:       24.58 MB
                  Thread 0x1e85             10 samples (1-10)         priority 4 (base 4)
                  Thread 0x1e8f             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10fd83000 -        0x10fda1fff  com.apple.WeatherKitService 2.0 (153)  <9842A92C-1EC6-35E7-AEED-97F9A2D2D34F>  /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.W eatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
                Process:         com.apple.WebKit.Databases [4604]
                Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Datab ases.xpc/Contents/MacOS/com.apple.WebKit.Databases
                Parent:          launchd [1]
                UID:             503
                Task size:       18.54 MB
                  Thread 0x19e4f            DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Safari [4589], IO tier 0>
                    10  ??? (com.apple.WebKit.Databases + 6050) [0x1046667a2] 1-10
                          10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 140362) [0x7fff8399144a] 1-10
                            10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 140658) [0x7fff83991572] 1-10
                  Thread 0x19e56            10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Safari [4589], IO tier 0>
                        10  void* std::__1::__thread_proxy<std::__1::tuple<void (*)(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*), bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*> >(void*) + 93 (JavaScriptCore + 12002381) [0x7fff84f8844d] 1-10
                          10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadEntryPoint(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*) + 29 (JavaScriptCore + 12001693) [0x7fff84f8819d] 1-10
                            10  bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadRunLoop() + 155 (JavaScriptCore + 12001995) [0x7fff84f882cb] 1-10
                              10  void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 108 (JavaScriptCore + 12002124) [0x7fff84f8834c] 1-10
                                10  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47 (libc++.1.dylib + 29901) [0x7fff9627b4cd] 1-10
                  Thread 0x19e5c            Thread name "IndexedDatabase Server"                10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Safari [4589], IO tier 0>
                        10  WTF::wtfThreadEntryPoint(void*) + 15 (JavaScriptCore + 14367) [0x7fff8441981f] 1-10
                          10  WTF::threadEntryPoint(void*) + 178 (JavaScriptCore + 14578) [0x7fff844198f2] 1-10
                            10  WebCore::IDBServer::IDBServer::databaseThreadEntry(void*) + 9 (WebCore + 7262937) [0x7fff894362d9] 1-10
                              10  WebCore::IDBServer::IDBServer::databaseRunLoop() + 101 (WebCore + 7269701) [0x7fff89437d45] 1-10
                                10  WTF::CrossThreadQueue<WTF::CrossThreadTask>::waitForMessage() + 95 (WebCore + 7269839) [0x7fff89437dcf] 1-10
                                  10  bool WTF::ConditionBase::waitUntil<WTF::Lock>(WTF::Lock&, WTF::TimeWithDynamicClockType const&) + 150 (WebCore + 2704406) [0x7fff88fdd416] 1-10
                                    10  WTF::ParkingLot::parkConditionallyImpl(void const*, WTF::ScopedLambda<bool ()> const&, WTF::ScopedLambda<void ()> const&, WTF::TimeWithDynamicClockType const&) + 2706 (JavaScriptCore + 11901778) [0x7fff84f6fb52] 1-10
                                      10  WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 63 (JavaScriptCore + 47103) [0x7fff844217ff] 1-10
                  Thread 0x343cc            10 samples (1-10)         priority 31 (base 31)
                  <process sudden termination dirty, process unclamped, process received importance donation from Safari [4589], IO tier 0>
                  Binary Images:
                           0x104665000 -        0x104666fff  com.apple.WebKit.Databases 12603 (12603.1.30.0.34) <7E736085-35E9-34DF-9562-DC20DBD00230>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Datab ases.xpc/Contents/MacOS/com.apple.WebKit.Databases
                        0x7fff84416000 -     0x7fff8501efff  com.apple.JavaScriptCore 12603 (12603.1.30.0.34)   <42993DA4-E18A-3A41-86F8-23A6656273F9>  /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                        0x7fff88d49000 -     0x7fff8a0cffff  com.apple.WebCore 12603 (12603.1.30.0.34)          <57038A29-AC92-33FE-A4D6-DCDD95B88A88>  /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                        0x7fff96274000 -     0x7fff962cafff  libc++.1.dylib (307.5)                             <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C>  /usr/lib/libc++.1.dylib
                   *0xffffff7f81356000 - 0xffffff7f81361fff  com.apple.kec.pthread 1.0 (1)                      <4EFF2F70-C9B9-3176-BF83-F1B660C42135>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
                Process:         com.apple.WebKit.Networking [881]
                Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Netwo rking.xpc/Contents/MacOS/com.apple.WebKit.Networking
                Parent:          launchd [1]
                UID:             503
                Task size:       28.09 MB
                  Thread 0x1beb             DispatchQueue 1           10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Spotlight [463], IO tier 0>
                    10  ??? (com.apple.WebKit.Networking + 6050) [0x102f257a2] 1-10
                  Thread 0x1bf2             10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Spotlight [463], IO tier 0>
                  Thread 0x1bfd             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
                  Thread 0x142b7            Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Spotlight [463], IO tier 0>
                  Binary Images:
                           0x102f24000 -        0x102f25fff  com.apple.WebKit.Networking 12603 (12603.1.30.0.34) <571EFBD1-6B28-3968-8AAE-14C61BBD30B1>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Netwo rking.xpc/Contents/MacOS/com.apple.WebKit.Networking
                Process:         com.apple.WebKit.Networking [1970]
                Parent:          launchd [1]
                UID:             503
                Task size:       37.71 MB
                  Thread 0x7b09             DispatchQueue 1           10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Mail [1964], IO tier 0>
                    10  ??? (com.apple.WebKit.Networking + 6050) [0x10ee0b7a2] 1-10
                  Thread 0x7b13             10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Mail [1964], IO tier 0>
                  Thread 0x7b24             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
                  Thread 0x7b41             Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Mail [1964], IO tier 0>
                  Binary Images:
                           0x10ee0a000 -        0x10ee0bfff  com.apple.WebKit.Networking 12603 (12603.1.30.0.34) <571EFBD1-6B28-3968-8AAE-14C61BBD30B1>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Netwo rking.xpc/Contents/MacOS/com.apple.WebKit.Networking
                Process:         com.apple.WebKit.Networking [4593]
                Parent:          launchd [1]
                UID:             503
                Task size:       63.79 MB
                  Thread 0x19dbf            DispatchQueue 1           10 samples (1-10)         priority 37 (base 37)
                    10  ??? (com.apple.WebKit.Networking + 6050) [0x1073307a2] 1-10
                  Thread 0x19dcf            10 samples (1-10)         priority 37 (base 37)
                  Thread 0x19de1            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
                  Thread 0x1b281            Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
                        10  _privateRunloopEmulationSet(void*) + 258 (CFNetwork + 2423154) [0x7fff81306972] 1-10
                  Binary Images:
                           0x10732f000 -        0x107330fff  com.apple.WebKit.Networking 12603 (12603.1.30.0.34) <571EFBD1-6B28-3968-8AAE-14C61BBD30B1>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Netwo rking.xpc/Contents/MacOS/com.apple.WebKit.Networking
                Process:         com.apple.WebKit.WebContent [1971]
                Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Parent:          launchd [1]
                UID:             503
                Task size:       85.89 MB
                  Thread 0x7b0a             DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x109eaf7a2] 1-10
                          10  NSApplicationMain + 1237 (AppKit + 25054) [0x7fff7fa3b1de] 1-10
                            10  -[NSApplication run] + 926 (AppKit + 243627) [0x7fff7fa707ab] 1-10
                              10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136798) [0x7fff801f785e] 1-10
                                10  _DPSNextEvent + 1120 (AppKit + 290340) [0x7fff7fa7be24] 1-10
                                  10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 199462) [0x7fff814e0b26] 1-10
                                    10  ReceiveNextEventCommon + 432 (HIToolbox + 199921) [0x7fff814e0cf1] 1-10
                                      10  RunCurrentEventLoopInMode + 240 (HIToolbox + 200380) [0x7fff814e0ebc] 1-10
                                               *8  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 1-8
                  <process clamped>
                                               *2  ipc_mqueue_receive_continue + 0 (kernel + 862304) [0xffffff80002d2860] 9-10
                  Thread 0x7b26             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                        10  _NSEventThread + 205 (AppKit + 1655506) [0x7fff7fbc92d2] 1-10
                  <process clamped>
                  Thread 0x7b27             10 samples (1-10)         priority 46 (base 46)
                                   *8  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 1-8
                  <process clamped>
                                   *2  psynch_cvcontinue + 0 (pthread + 38973) [0xffffff7f8135f83d] 9-10
                  Thread 0x7b2c             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, IO tier 0>
                  <process clamped>
                  Thread 0x7b36             Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 46 (base 46)
                  <process clamped>
                  Binary Images:
                           0x109eae000 -        0x109eaffff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                        0x7fff7fa35000 -     0x7fff8080efff  com.apple.AppKit 6.9 (1504.82.104)                  <C295FF09-9984-34C3-953B-B263EF2107AB>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                        0x7fff814b0000 -     0x7fff817b9fff  com.apple.HIToolbox 2.1.1 (857.8)                   <40254D9A-E477-3F33-B2A2-807D399BF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                Process:         com.apple.WebKit.WebContent [3148]
                Parent:          launchd [1]
                UID:             503
                Task size:       114.20 MB
                  Thread 0x1001f            DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10da7b7a2] 1-10
                  <process clamped>
                  Thread 0x10034            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                  <process clamped>
                  Thread 0x10037            10 samples (1-10)         priority 46 (base 46)
                  <process clamped>
                  Thread 0x1003d            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
                  <process clamped>
                  Thread 0x10040            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 46 (base 46)
                            10  WebCore::ScrollingThread::initializeRunLoop() + 253 (WebCore + 330957) [0x7fff88d99ccd] 1-10
                              10  CFRunLoopRun + 97 (CoreFoundation + 814129) [0x7fff81fbec31] 1-10
                  <process clamped>
                  Binary Images:
                           0x10da7a000 -        0x10da7bfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         com.apple.WebKit.WebContent [4685]
                Parent:          launchd [1]
                UID:             503
                Task size:       519.34 MB
                  Thread 0x1a612            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
                  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0, priority 46 (46)>
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x104a807a2] 1-10
                  <process clamped, process suppressed, timers tier 5 (throttled), IO tier 1, priority 4 (4)>
                  Thread 0x1a61f            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x1a620            10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x1a624            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
                  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, IO tier 0, priority 37 (37)>
                  Thread 0x1a625            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x1bfe1            Thread name "Audio Decoder"                         10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x1bfec            Thread name "Audio Decoder"                         10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x1bffc            Thread name "Audio Decoder"                         10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x1c006            Thread name "Audio Decoder"                         10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x1c00e            Thread name "Audio Decoder"                         10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x1c044            Thread name "com.apple.coremedia.asyncio"           10 samples (1-10)         priority 4-52 (base 4-52)
                  <process sudden termination dirty, process unclamped, IO tier 0, priority 52 (52)>
                        10  figThreadMain + 277 (CoreMedia + 277470) [0x7fff82d02bde] 1-10
                          10  ??? (MediaToolbox + 177348) [0x7fff853084c4] 1-10
                            10  FigSemaphoreWaitRelative + 153 (CoreMedia + 274121) [0x7fff82d01ec9] 1-10
                              10  WaitOnCondition + 14 (CoreMedia + 275007) [0x7fff82d0223f] 1-10
                  Thread 0x1c066            Thread name "com.apple.coreaudio.AQClient"          10 samples (1-10)         priority 4-60 (base 4-60)
                  <process sudden termination dirty, process unclamped, IO tier 0, priority 60 (60)>
                  Binary Images:
                           0x104a7f000 -        0x104a80fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                        0x7fff82cbf000 -     0x7fff82d70fff  com.apple.CoreMedia 1.0 (1907.58)                   <9A25B3CA-A006-39D2-A405-194F2BBF9061>  /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                        0x7fff852dd000 -     0x7fff85816fff  com.apple.MediaToolbox 1.0 (1907.58)                <2BF8A414-F33A-333B-97F1-97D3807F96EB>  /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                Process:         com.apple.WebKit.WebContent [4782]
                Parent:          launchd [1]
                UID:             503
                Task size:       288.58 MB
                CPU Time:        <0.001
                  Thread 0x1b1d7            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x104f137a2] 1-10
                  Thread 0x1b20b            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x1b20f            10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x1b212            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x1b21f            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
                  Binary Images:
                           0x104f12000 -        0x104f13fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         com.apple.WebKit.WebContent [5092]
                Parent:          launchd [1]
                UID:             503
                Task size:       240.80 MB
                CPU Time:        <0.001
                Note:            4 idle work queue threads omitted
                  Thread 0x1d903            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10113e7a2] 1-10
                  Thread 0x1d91e            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x1d920            10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x1d925            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x1d926            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
                  Binary Images:
                           0x10113d000 -        0x10113efff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         com.apple.WebKit.WebContent [5561]
                Parent:          launchd [1]
                UID:             503
                Task size:       93.69 MB
                  Thread 0x20922            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x106de37a2] 1-10
                  Thread 0x2092c            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x2092d            10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x20932            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x20935            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
                  Binary Images:
                           0x106de2000 -        0x106de3fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         com.apple.WebKit.WebContent [5583]
                Parent:          launchd [1]
                UID:             503
                Task size:       166.38 MB
                  Thread 0x20a86            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10c3ac7a2] 1-10
                  Thread 0x20a99            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x20a9d            10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x20aa2            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x20aa3            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
                  Binary Images:
                           0x10c3ab000 -        0x10c3acfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         com.apple.WebKit.WebContent [5595]
                Parent:          launchd [1]
                UID:             503
                Task size:       138.90 MB
                  Thread 0x20eef            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10a7357a2] 1-10
                  Thread 0x20ef9            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x20efd            10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x20f01            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x20f0a            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
                  Binary Images:
                           0x10a734000 -        0x10a735fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         com.apple.WebKit.WebContent [7730]
                Parent:          launchd [1]
                UID:             503
                Task size:       378.81 MB
                CPU Time:        <0.001
                  Thread 0x30be9            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10b9ed7a2] 1-10
                  Thread 0x30c04            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x30c08            10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x30c0c            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x30c10            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
                  Binary Images:
                           0x10b9ec000 -        0x10b9edfff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         com.apple.WebKit.WebContent [7787]
                Parent:          launchd [1]
                UID:             503
                Task size:       214.39 MB
                CPU Time:        <0.001
                  Thread 0x3125c            DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)     cpu time <0.001
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x10e2d07a2] 1-10
                  <process clamped>
                  Thread 0x3126b            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                  <process clamped>
                  Thread 0x3126c            10 samples (1-10)         priority 46 (base 46)
                  <process clamped>
                  Thread 0x31270            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
                  <process clamped>
                  Thread 0x31271            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 46 (base 46)
                  <process clamped>
                  Binary Images:
                           0x10e2cf000 -        0x10e2d0fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         com.apple.WebKit.WebContent [7798]
                Parent:          launchd [1]
                UID:             503
                Task size:       148.27 MB
                  Thread 0x31430            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1007237a2] 1-10
                  Thread 0x31452            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x31455            10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x31460            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x31463            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
                  Binary Images:
                           0x100722000 -        0x100723fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         com.apple.WebKit.WebContent [7803]
                Parent:          launchd [1]
                UID:             503
                Task size:       152.50 MB
                  Thread 0x3148f            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46)
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1037247a2] 1-10
                  Thread 0x3149d            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x3149e            10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x314a2            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x314a3            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
                  Binary Images:
                           0x103723000 -        0x103724fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         com.apple.WebKit.WebContent [8152]
                Parent:          launchd [1]
                UID:             503
                Task size:       145.92 MB
                CPU Time:        <0.001
                  Thread 0x33e48            DispatchQueue 1           10 samples (1-10)         priority 4-46 (base 4-46) cpu time <0.001
                    10  ??? (com.apple.WebKit.WebContent + 6050) [0x1020077a2] 1-10
                  Thread 0x33e68            Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x33e6a            10 samples (1-10)         priority 4-46 (base 4-46)
                  Thread 0x33e6f            Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4-37 (base 4-37)
                  Thread 0x33e71            Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 4-46 (base 4-46)
                  Binary Images:
                           0x102006000 -        0x102007fff  com.apple.WebKit.WebContent 12603 (12603.1.30.0.34) <2F32DA20-F06C-340B-8F8A-A3FC8F85C19F>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         CommCenter [318]
                Path:            /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
                Parent:          launchd [1]
                UID:             503
                Task size:       46.16 MB
                  Thread 0xb3c              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
                    10  ??? (CommCenter + 537998) [0x10c85a58e] 1-10
                      10  ??? (CommCenter + 539288) [0x10c85aa98] 1-10
                  Thread 0xb5d              10 samples (1-10)         priority 31 (base 31)
                        10  ATCSThreadStartStub(void*) + 30 (libATCommandStudioDynamic.dylib + 16638) [0x10d4280fe] 1-10
                          10  ATCSTimerDriver::startATCSTimerDispatcher(void*) + 9 (libATCommandStudioDynamic.dylib + 19445) [0x10d428bf5] 1-10
                            10  ATCSTimerDriver::timerDispatcher() + 57 (libATCommandStudioDynamic.dylib + 19765) [0x10d428d35] 1-10
                              10  ATCSCondition::wait(ATCSMutex*, int) + 142 (libATCommandStudioDynamic.dylib + 17566) [0x10d42849e] 1-10
                  Thread 0xb87              10 samples (1-10)         priority 31 (base 31)
                        10  ??? (CommCenter + 4446480) [0x10cc14910] 1-10
                          10  ??? (CommCenter + 4446993) [0x10cc14b11] 1-10
                  Thread 0xb91              10 samples (1-10)         priority 31 (base 31)
                        10  ??? (CommCenter + 4740276) [0x10cc5c4b4] 1-10
                  Thread 0xb92              10 samples (1-10)         priority 31 (base 31)
                        10  ??? (CommCenter + 734555) [0x10c88a55b] 1-10
                  Binary Images:
                           0x10c7d7000 -        0x10cf6afff  CommCenter (4961)                      <12316096-12CC-36C2-BDFB-B1F9F5B2BCBC>  /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
                           0x10d424000 -        0x10d474fff  libATCommandStudioDynamic.dylib (1902) <D9D9EF52-13B8-32FA-96E0-B004C6BE6323>  /usr/lib/libATCommandStudioDynamic.dylib
                Process:         configd [58]
                Path:            /usr/libexec/configd
                Parent:          launchd [1]
                UID:             0
                Task size:       19.91 MB
                  Thread 0x2a4              DispatchQueue 1           Thread name "SCDynamicStore"                        10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user initiated), process sudden termination clean, IO tier 0>
                    10  ??? (configd + 12818) [0x10fff5212] 1-10
                      10  ??? (configd + 17813) [0x10fff6595] 1-10
                  Thread 0x31f              Thread name "Main plugin thread"                    10 samples (1-10)         priority 31 (base 31)
                        10  ??? (configd + 20747) [0x10fff710b] 1-10
                  Thread 0x32f              Thread name "InterfaceNamer thread"                 10 samples (1-10)         priority 31 (base 31)
                        10  ??? (configd + 74950) [0x1100044c6] 1-10
                  Thread 0x3c6              10 samples (1-10)         priority 31 (base 31)
                        10  pppcntl_run_thread + 717 (PPPController + 56727) [0x11018dd97] 1-10
                  Thread 0x3c8              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
                        10  __select + 10 (libsystem_kernel.dylib + 106166) [0x7fff97810eb6] 1-10
                  Thread 0x3cb              10 samples (1-10)         priority 31 (base 31)
                        10  captived_thread + 266 (CaptiveNetworkSupport + 18419) [0x1101527f3] 1-10
                  Thread 0x3dc              10 samples (1-10)         priority 31 (base 31)
                        10  ??? (EAPOLController + 19056) [0x1100e8a70] 1-10
                  Binary Images:
                           0x10fff2000 -        0x110043fff  configd (888.51.2)                                               <D2407749-46E2-3BB0-B3FA-1AB531F772EA>  /usr/libexec/configd
                           0x1100e4000 -        0x1100eafff  com.apple.SystemConfiguration.EAPOLController 14.0.0 (14.0)      <A61C1CE8-230E-345E-9671-3CC2A7DBE116>  /System/Library/SystemConfiguration/EAPOLController.bundle/Contents/MacOS/EAPOLController
                           0x11014e000 -        0x11016efff  com.apple.SystemConfiguration.CaptiveNetworkSupport 16.0.0 (1.0) <5EE013AE-4C0F-32F6-B49E-44FCEE22C07D>  /System/Library/SystemConfiguration/CaptiveNetworkSupport.bundle/Contents/MacOS/CaptiveNe tworkSupport
                           0x110180000 -        0x1101bdfff  com.apple.SystemConfiguration.PPPController 1.10 (1.10)          <21A0E815-45FD-3C37-9FF9-BD119D87D201>  /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
                Process:         ContactsAccountsService [339]
                Path:            /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
                Parent:          launchd [1]
                UID:             503
                Task size:       21.35 MB
                  Thread 0xbdc              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (ContactsAccountsService + 13664) [0x10018f560] 1-10
                  Binary Images:
                           0x10018c000 -        0x100193fff  ContactsAccountsService (1756.20)      <86A1BE6F-1113-3151-B706-A82385FFDFE9>  /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
                Process:         ContactsAgent [930]
                Path:            /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
                Parent:          launchd [1]
                UID:             503
                Task size:       21.84 MB
                  Thread 0x1e25             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 102 (ContactsAgent + 12039) [0x1073f2f07] 1-10
                  Binary Images:
                           0x1073e7000 -        0x1073e7fff  ContactsAgent (10)                     <10E17EFD-F0F4-3F5E-BF4E-BF8D4B517B06>  /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
                           0x1073f0000 -        0x107407fff  com.apple.ContactsAgent 1.0 (1)        <8362ACAF-3807-322E-9741-669D9354CFB1>  /System/Library/PrivateFrameworks/ContactsAgent.framework/Versions/A/ContactsAgent
                Process:         ControlStrip [415]
                Path:            /System/Library/CoreServices/ControlStrip.app/Contents/MacOS/ControlStrip
                Parent:          launchd [1]
                UID:             503
                Task size:       52.82 MB
                  Thread 0xf46              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested user interactive), process unclamped, IO tier 0>
                    10  ??? (ControlStrip + 10025) [0x1021e9729] 1-10
                  <process clamped>
                  Thread 0x1348             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 31 (base 31)
                  <process clamped>
                  Binary Images:
                           0x1021e7000 -        0x102288fff  com.apple.controlstrip 1.0 (104.25)    <B0667090-5F42-32CF-A75B-6DCA8901CD70>  /System/Library/CoreServices/ControlStrip.app/Contents/MacOS/ControlStrip
                Process:         CopyPaste Pro [470]
                Path:            /Applications/CopyPaste Pro.app/Contents/MacOS/CopyPaste Pro
                Parent:          launchd [1]
                UID:             503
                Task size:       68.51 MB (+4096  B)
                CPU Time:        0.002
                Process:         Core Sync [844]
                Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/MacOS/Core Sync
                Parent:          launchd [1]
                UID:             503
                Task size:       36.68 MB
                CPU Time:        <0.001
                Process:         coreaudiod [212]
                Path:            /usr/sbin/coreaudiod
                Parent:          launchd [1]
                UID:             202
                Task size:       25.48 MB
                  Thread 0x5a2              DispatchQueue 1           10 samples (1-10)         priority 63 (base 63)
                  <process sudden termination dirty, IO tier 0>
                    10  ??? (coreaudiod + 162247) [0x1070fe9c7] 1-10
                  Thread 0x6c3              Thread name "SystemSoundServer"                     10 samples (1-10)         priority 61 (base 61)
                        10  CAPThread::Entry(CAPThread*) + 85 (AudioToolbox + 71531) [0x7fff80d5276b] 1-10
                          10  GenericRunLoopThread::Entry(void*) + 189 (AudioToolbox + 71897) [0x7fff80d528d9] 1-10
                  Binary Images:
                           0x1070d7000 -        0x107229fff  coreaudiod (55.12)                               <B319AFF5-1A11-3AFB-AB8F-768D93658E7D>  /usr/sbin/coreaudiod
                        0x7fff80d41000 -     0x7fff80f4dfff  com.apple.audio.toolbox.AudioToolbox 1.14 (1.14) <6EEF498D-8233-3622-B34B-49FDD9D4DF14>  /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                Process:         coreauthd [301]
                Path:            /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
                Parent:          launchd [1]
                UID:             0
                Task size:       16.30 MB
                  Thread 0x9c1              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (coreauthd + 44537) [0x109978df9] 1-10
                  Binary Images:
                           0x10996e000 -        0x10999dfff  coreauthd (240.50.25)                  <6826CA0F-F4A7-369A-84F8-75A39EA1169A>  /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
                Process:         coreauthd [399]
                Parent:          launchd [1]
                UID:             503
                Task size:       15.23 MB
                  Thread 0xe4b              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (coreauthd + 44537) [0x10beb9df9] 1-10
                  Binary Images:
                           0x10beaf000 -        0x10bedefff  coreauthd (240.50.25)                  <6826CA0F-F4A7-369A-84F8-75A39EA1169A>  /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
                Process:         corebrightnessd [128]
                Path:            /usr/libexec/corebrightnessd
                Parent:          launchd [1]
                UID:             0
                Task size:       17.41 MB
                  Thread 0x322              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  Thread 0x57b              10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x107a0f000 -        0x107a10fff  corebrightnessd (452.50.49)        <CD1B6F14-DE44-38ED-9DF8-2957C07D2BEE>  /usr/libexec/corebrightnessd
                Process:         coreduetd [88]
                Path:            /usr/libexec/coreduetd
                Parent:          launchd [1]
                UID:             0
                Task size:       50.35 MB
                  Thread 0x2e7              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (coreduetd + 238664) [0x10a001448] 1-10
                  Binary Images:
                           0x109fc7000 -        0x10a060fff  coreduetd (687.50.20)                  <F013B069-4DCC-332D-8594-F53C2DC26167>  /usr/libexec/coreduetd
                Process:         coreservicesd [143]
                Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/coreservicesd
                Parent:          launchd [1]
                UID:             0
                Task size:       14.89 MB
                  Thread 0x391              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  _CoreServicesServerMain + 706 (CarbonCore + 579053) [0x7fff82e9d5ed] 1-10
                  Thread 0x3ac              10 samples (1-10)         priority 31 (base 31)
                        10  fmodWatchConsumer + 333 (CarbonCore + 313879) [0x7fff82e5ca17] 1-10
                  Thread 0x3ad              10 samples (1-10)         priority 31 (base 31)
                        10  read + 10 (libsystem_kernel.dylib + 111174) [0x7fff97812246] 1-10
                         *10  hndl_unix_scall64 + 22 (kernel + 646470) [0xffffff800029dd46] 1-10
                           *10  unix_syscall64 + 597 (kernel + 6444693) [0xffffff8000825695] 1-10
                             *10  read_nocancel + 115 (kernel + 5884291) [0xffffff800079c983] 1-10
                               *10  ??? (kernel + 5884954) [0xffffff800079cc1a] 1-10
                                 *10  ??? (kernel + 3479568) [0xffffff8000551810] 1-10
                                   *10  ??? (kernel + 5801314) [0xffffff8000788562] 1-10
                                     *10  thread_block_reason + 222 (kernel + 1069422) [0xffffff800030516e] 1-10
                                       *10  ??? (kernel + 1073995) [0xffffff800030634b] 1-10
                                         *10  machine_switch_context + 206 (kernel + 2082766) [0xffffff80003fc7ce] 1-10
                  Binary Images:
                           0x106ada000 -        0x106adafff  coreservicesd (1159.6)                            <6B67A648-F14D-390D-9CF2-A0F66D5749B1>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/coreservicesd
                        0x7fff82e10000 -     0x7fff830ebfff  com.apple.CoreServices.CarbonCore 1159.6 (1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                Process:         CoreServicesUIAgent [670]
                Path:            /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
                Parent:          launchd [1]
                UID:             503
                Task size:       30.71 MB
                  Thread 0x1773             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  Thread 0x1797             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user interactive), process sudden termination clean, IO tier 0>
                  Thread 0x326d5            10 samples (1-10)         priority 31 (base 31)
                  <process sudden termination clean, IO tier 0>
                *10  wq_unpark_continue + 0 (pthread + 15190) [0xffffff7f81359b56] 1-10
                  Binary Images:
                           0x10d2e8000 -        0x10d314fff  com.apple.coreservices.uiagent 168.3 (168.3) <BB0FBFA8-A85F-3E9B-8DF3-F6A7BDD05AB0>  /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
                Process:         corestoraged [223]
                Path:            /usr/libexec/corestoraged
                Parent:          launchd [1]
                UID:             0
                Task size:       11.01 MB
                  Thread 0x63e              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
                    10  ??? (corestoraged + 7983) [0x102672f2f] 1-10
                  Binary Images:
                           0x102671000 -        0x102678fff  corestoraged (540.30.1)                <1C1A0DAF-1E13-3188-ABC6-C3BC71CB3D1F>  /usr/libexec/corestoraged
                Process:         coresymbolicationd [245]
                Path:            /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
                Parent:          launchd [1]
                UID:             0
                Task size:       9516 KB
                  Thread 0x77e              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  10  _dispatch_sig_thread + 41 (libdispatch.dylib + 62031) [0x7fff976ba24f] 1-10
                    10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 106982) [0x7fff978111e6] 1-10
                  Binary Images:
                           0x109b11000 -        0x109b1cfff  coresymbolicationd (62046)         <7B7E8269-3D00-32BD-BF3D-47C6F95CBFCB>  /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
                        0x7fff976ab000 -     0x7fff976dcfff  libdispatch.dylib (703.50.37)      <D122E712-9593-31CA-BAC4-4A54410BF4A0>  /usr/lib/system/libdispatch.dylib
                Process:         CrashReporterSupportHelper [218]
                Path:            /System/Library/CoreServices/CrashReporterSupportHelper
                Parent:          launchd [1]
                UID:             0
                Task size:       9648 KB
                  Thread 0x5eb              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (CrashReporterSupportHelper + 8618) [0x10c5961aa] 1-10
                  Binary Images:
                           0x10c594000 -        0x10c596fff  CrashReporterSupportHelper (823)       <87FD7AA9-4545-344D-883C-A70CC590D42E>  /System/Library/CoreServices/CrashReporterSupportHelper
                Process:         Creative Cloud [449]
                Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/MacOS/Creative Cloud
                Architecture:    i386
                Parent:          launchd [1]
                UID:             503
                Task size:       32.31 MB
                CPU Time:        0.004
                Process:         ctkahp (Smartcard Agent) [288]
                Path:            /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
                Parent:          launchd [1]
                UID:             0
                Task size:       12.05 MB
                  Thread 0x92a              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 460 (ctkahp + 6861) [0x106bcaacd] 1-10
                  Binary Images:
                           0x106bc9000 -        0x106bdefff  com.apple.ctkahp 1.0 (1)               <7F3206EA-1810-3F96-B5A5-A5F4CB02BA01>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
                Process:         ctkahp (Smartcard Agent) [404]
                Parent:          launchd [1]
                UID:             503
                Task size:       12.47 MB
                  Thread 0xe87              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 460 (ctkahp + 6861) [0x108c15acd] 1-10
                  Binary Images:
                           0x108c14000 -        0x108c29fff  com.apple.ctkahp 1.0 (1)               <7F3206EA-1810-3F96-B5A5-A5F4CB02BA01>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
                Process:         ctkd [152]
                Path:            /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
                Parent:          launchd [1]
                UID:             259
                Task size:       13.42 MB
                  Thread 0x3ff              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10c1d1000 -        0x10c1ddfff  ctkd (196.50.16)                   <734E50F1-6E22-3D6E-ACCF-8B457295ABDE>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
                Process:         ctkd [405]
                Parent:          launchd [1]
                UID:             503
                Task size:       14.30 MB
                  Thread 0xe90              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x101000000 -        0x10100cfff  ctkd (196.50.16)                   <734E50F1-6E22-3D6E-ACCF-8B457295ABDE>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
                Process:         cupsd [221]
                Path:            /usr/sbin/cupsd
                Parent:          launchd [1]
                UID:             0
                Task size:       9792 KB
                  Thread 0x6d6              10 samples (1-10)         priority 4 (base 4)
                    10  ??? (cupsd + 97809) [0x102e99e11] 1-10
                      10  kevent + 10 (libsystem_kernel.dylib + 109974) [0x7fff97811d96] 1-10
                       *10  ??? (kernel + 5627984) [0xffffff800075e050] 1-10
                  Thread 0x9b7              10 samples (1-10)         priority 4 (base 4)
                        10  ??? (cupsd + 272372) [0x102ec47f4] 1-10
                  Binary Images:
                           0x102e82000 -        0x102ed7fff  cupsd (450)                            <75B677CA-F944-3801-8A6F-F4D72C990C00>  /usr/sbin/cupsd
                Process:         CVMServer [259]
                Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
                Parent:          launchd [1]
                UID:             0
                Task size:       5304 KB
                  Thread 0x84d              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, IO tier 0>
                  Binary Images:
                           0x1054ff000 -        0x105508fff  CVMServer (156.3)                  <6914E9F7-9E57-31D0-9F34-E5B5F7DBD15B>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
                Process:         dbfseventsd [2180]
                Path:            /Library/DropboxHelperTools/*/dbfseventsd
                Architecture:    i386
                Parent:          Dropbox [476]
                Responsible:     Dropbox [476]
                UID:             0
                Task size:       1520 KB
                CPU Time:        <0.001
                  Thread 0x921f             10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
                  10  __read_nocancel + 10 (libsystem_kernel.dylib + 111922) [0xa17d5532] 1-10
                   *10  hndl_unix_scall + 216 (kernel + 645688) [0xffffff800029da38] 1-10
                     *10  unix_syscall + 561 (kernel + 6443777) [0xffffff8000825301] 1-10
                  Binary Images:
                                0x1000 -             0x8fff  dbfseventsd                        <6E6421C9-0E72-73AF-1821-754B84B964AF>  /Library/DropboxHelperTools/*/dbfseventsd
                            0xa17ba000 -         0xa17dbfff  libsystem_kernel.dylib (3789.51.2) <50D0E6F1-6F9C-303F-BCD6-F72AD4485B6E>  /usr/lib/system/libsystem_kernel.dylib
                Process:         dbfseventsd [2181]
                Architecture:    i386
                Parent:          dbfseventsd [2180]
                UID:             0
                Task size:       3692 KB
                CPU Time:        <0.001
                  Thread 0x9221             10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
                  <IO tier 0>
                  10  ??? (dbfseventsd + 30069) [0x8575] 1-10
                    10  __select_nocancel + 10 (libsystem_kernel.dylib + 112230) [0xa17d5666] 1-10
                  Binary Images:
                Process:         dbfseventsd [2182]
                Architecture:    i386
                Parent:          dbfseventsd [2181]
                UID:             503
                Task size:       668 KB
                CPU Time:        <0.001
                  Thread 0x9223             10 samples (1-10)         priority 31 (base 31)     cpu time <0.001
                  <IO tier 0>
                           *10  ??? (kernel + 5904888) [0xffffff80007a19f8] 1-10
                             *10  ??? (kernel + 5801187) [0xffffff80007884e3] 1-10
                               *10  lck_mtx_sleep + 132 (kernel + 1026980) [0xffffff80002faba4] 1-10
                  Binary Images:
                Process:         Default Folder X Agent [837]
                Path:            /Users/USER/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Default Folder X Agent
                Parent:          Default Folder X Helper [467]
                Responsible:     Default Folder X Helper [467]
                UID:             503
                Task size:       24.21 MB
                  Thread 0x1a59             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  10  start + 52 (Default Folder X Agent + 4376) [0x100001118] 1-10
                    10  main + 141 (Default Folder X Agent + 4525) [0x1000011ad] 1-10
                      10  -[DFXAgent run] + 205 (Default Folder X Agent + 8189) [0x100001ffd] 1-10
                  <process clamped>
                  Thread 0x1a60             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 31 (base 31)
