8 Replies Latest reply on Apr 24, 2018 8:00 AM by Bernd Alheit
    Cannot edit text in DC pro. Help?
    Von70
      I have a PDF file that I am trying to edit.  There are some typos I need to correct. The file opens fine, but when I try to edit any portion of the text, the whole page goes nuts and jumps all over the place.  The text goes all wacky, jumps off the page boundaries and the curser jumps to a complete other spot on the page. This happens no matter what function I try to perform.  Please help me !
      [Moved from non-technical Lounge Forum to specific Program forum... Mod]
      [Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
        • 1. Re: Cannot edit text in DC pro. Help?
          PDF files were not meant to be edited in this way. It works well for some, but not others.
          Basically you need to go back to the original file format used to create the PDF, edit it, and then create a new one.
          If that's not possible you can try exporting the PDF to an editable format, like MS Word, and then edit it there and finally convert to a new PDF when done. Make sure to keep a copy of the Word file, in case you want to edit it further in the future.
          2 people found this helpful
          • 2. Re: Cannot edit text in DC pro. Help?
            Karl Heinz Kremer Adobe Community Professional
            The Acrobat editing functions work reasonably well for "good" PDF files. In your case, I assume you are dealing with a file that has problems. Acrobat is able to display the file correctly, but once it needs access to more information in the PDF file in order to edit it, things go wrong. Try67's advice about always keeping the original file around is very important. Unfortunately that's not much help when you are trying to edit a file that you did not create yourself.
            If exporting the file to MS Word does not work (which I would expect, based on the state of the PDF file), then saving the PDF document as a series of high resolution TIFF images, importing these images back into Acrobat, running OCR, and then editing may be your only option.
            • 3. Re: Cannot edit text in DC pro. Help?
              Von70 Level 1
              Okay.  I figured this was going to be the answer, but I hoped I was wrong.  This is a book and the files were create by Tate Publishing, which went out of business before they published the book.  I am trying to help the author publish them on Amazon.com, these are the files that Tate Publishing gave him.  I have no contact with Tate, so I can't request the source files if they still have them.
              • 4. Re: Cannot edit text in DC pro. Help?
                johna70895075
                No. I cannot edit either. Bought "PRO" to do wedding invitations. edit tool only 'moves' page around.
                tutorial video unhelpful. my  file will not edit - (except on right click - which is very limited -)
                either not a good program, or not a good tutorial!
                • 5. Re: Cannot edit text in DC pro. Help?
                  johna70895075 Level 1
                  1. open file
                  2. click 'edit pdf' tool
                  3. click text or image  you wish to edit    -   OOPS!! NOPE!! this gives me a cross-hatch mouse pointer that ONLY moves the entire page around..
                  NO!
                  • 6. Re: Cannot edit text in DC pro. Help?
                    That means the entire page is an image (probably a scanned one).
                    • 7. Re: Cannot edit text in DC pro. Help?
                      the entire page is pdf?   that's not my doing... the program did it when i saved - to your program, in your files, in your format.
                      this is a poor program for me to use for wedding invitations.
                      - i deleted 'reader' so that would not affect anything... i changed 'properties' to ensure 'dc pro' is default.
                      it still does NOT WORK!
                      (entire page moves with cross hatch pointer.)
                      thanks for your reply and advice - but like your tutorials - it is useless to me inediting my wedding invitation.
                      • 8. Re: Cannot edit text in DC pro. Help?
                        Bernd Alheit Adobe Community Professional & MVP
                        How did you create the PDF file?
