3 Replies Latest reply on Apr 1, 2017 4:02 AM by migs012
    Muliti Check box Exported Data in a Text Field and Calculation
    migs012
      Hi Good day Everyone,
      I would like to seek support to answer my acrobat problem. Im doing a project specifically a multiple check box that has a specific value.
      Example: Check box 1, 2, 3, 4 & 5 have their values 1A, 1B, 1C, 1D 1E.  I wanted to get the result in the check box like this: 1A, 1B, 1C, 1D 1E.
      Would it be possible? I'm working with this code I got from one of the questions here:
      event.value = this.getField("1B").value;
      // if value is "Off" then clear the field
      if (event.value == "Off") event.value = "";
      It's working, only when you select one check box. What I wanted to do is to select multiple boxes and the result will be in a displayed in a comma.
      On the side, I want also to calculate the number of check box selected on text field that will support the result on the other text field.
      Example:
      Text Field (No of Check box Selected) 6
      Text Field (selected Check Boxes) 1A, 1B, 1C, 122B, 121B, 120B
      Thank you in advance for your support!
      Screen Shot 2017-03-31 at 1.08.49 PM.pngScreen Shot 2017-03-31 at 1.09.14 PM.png
        • 1. Re: Muliti Check box Exported Data in a Text Field and Calculation
          You can use this code as the custom calculation script of the field that should contain the list of selected items:
          var fields = ["1A", "1B", "1C", "1D", "1E"]; // Enter the full list of check-boxes here
          var values = [];
          for (var i in fields) {
              var f = this.getField(fields[i]);
              if (f==null) {
                  app.alert("Can't find: " + fields[i]);
                  continue;
              var v = f.value;
              if (v!="Off") values.push(v);
          event.value = values.join(", ");
          this.getField("Counter").value = values.length;
          The last line of the code will populate another field (called "Counter") with the number of selected boxes.
          • 2. Re: Muliti Check box Exported Data in a Text Field and Calculation
            migs012 Level 1
            Hi try67!
            Thank you so much! It works!
            How ever, for the counter code:
            can I copy this an place in a different text box to display the number of check box selected?
            or do I need to copy and paste all of the code in a another text field to display the count?
            Lastly, will the result be limited to a certain number of check box only?
            Thank you again for your help!
            • 3. Re: Muliti Check box Exported Data in a Text Field and Calculation
              migs012 Level 1
              Hi @try67!
              Finally I got what you mean. I replaced the "Counter" with the text field name and it worked!
              Thank you and  More Blessings!
