7 Replies Latest reply on Apr 5, 2017 2:24 AM by ninovillari
    Hyperlinks in a PDF: how to work with them in iOS?
    ninovillari
      I have made a project with QGIS Cloud that allow to reach some PDFs contained in my DropBox space.
      In the PDFs there are some Hyperlinks that work correctly on pc/Mac (after downloading the file) but don't work with iPhone/iPad, also after opening the PDFs with Adobe Acrobat for iOS.
      Could you help me please?
      Thank you
        • 1. Re: Hyperlinks in a PDF: how to work with them in iOS?
          MobileDeveloperCK Adobe Employee
          Hi ninovillari,
          Do the hyperlinks in your PDF documents point to the URLs to your Dropbox (e.g. https://www.dropbox.com/...)?  Are the URLs https or http?
          Would you please open some of your PDF documents in iBooks (instead of Acrobat Reader) on your iPad/iPhone?
          If you would like to share your PDF document with us (Adobe), we can send you the information about how to share it privately via a forum private message.
          Thank you for your help.
          • 2. Re: Hyperlinks in a PDF: how to work with them in iOS?
            ninovillari Level 1
            thank you for the reply.
            The links from my QGIS Cloud project pointing to the ULSs in myDropBox are all http.
            The links contained in PDFs in my DropBox are some with https, some with http: I have made an additional test with these last, but they don’t work, also if I open them with iBooks.
            Here is one of these last PDFs with both https and http:
            I have tried to create the PDF both from “print” and from “save to” but the result is always the same negative.
            Greetings
            Nino
            [personal information removed by moderator]
            • 3. Re: Hyperlinks in a PDF: how to work with them in iOS?
              Hi ninovillari,
              It looks like your PDF document did not get through.  The Adobe forums do not accept any email attachments.
              I've sent you a forum private message with the instructions on how to share your PDF document with us privately.
              Thank you!
              • 4. Re: Hyperlinks in a PDF: how to work with them in iOS?
                Hi ninovillari,
                Thank you for sharing your PDF document with us!
                I examined your PDF document (Senza nome.pdf) and concluded that your PDF document does not contain real hyperlinks.
                I opened the PDF document in Adobe Acrobat Pro DC (desktop app) and used the Edit PDF tool to check if links are available.
                Acrobat Pro DC reported: "There are no links to the Web on this page."
                The desktop version of Acrobat Reader/Pro has the auto link detection feature.  When Acrobat Reader encounters URL text (such as "http://www.adobe.com" and "nobody@adobe.com"), it automatically converts the URL text to links on the fly.
                The feature can be enabled/disabled by selecting/deselecting the General > Basic Tools > "Create links from URLs" option in the Preferences dialog.  (Please note that the Preferences dialog is available in Acrobat Pro, Standard, and Reader desktop apps only.)
                If you deselect the "Create links from URLs" option and reopen your PDF document, you will notice that the "links" no longer work.
                Unfortunately, the auto link detection feature is not supported by Acrobat Reader for iOS or Android.
                If you are interested in making web links work with majority of PDF viewers for desktop and mobile, I'd highly recommend creating real hyperlinks (instead of relying on the auto link detection feature).
                Using Acrobat Pro DC (desktop app), you can add real hyperlinks to the existing PDF document.
                1. Open your document in Acrobat Pro DC.
                2. Select Edit PDF tool.
                3. Select Link > Auto Create Web Links from URLs...
                You can download and install a free trial of Acrobat Pro DC for Windows or Mac.
                Download Adobe Acrobat free trial | Acrobat Pro DC
                Please let us know if you have additional questions.
                Thank you.
                • 5. Re: Hyperlinks in a PDF: how to work with them in iOS?
                  ninovillari Level 1
                  I thank you for your reply: I will follow the indication that you gave me.
                  I have a last doubt: if in the sample file that I sent you there are no links, how is it that by opening the PDF in Adobe Acrobat (Mac version) the links work?
                  Could you, please, send me a PDF in which the links work, so that I could try activate the links on an iOS device?
                  Cheers
                  Nino
                  • 6. Re: Hyperlinks in a PDF: how to work with them in iOS?
                    As I mentioned in the previous reply, the PDF document that you sent to us has no real hyperlinks.
                    The "Create links from URLs" option specifies whether links that weren’t created with Acrobat are automatically identified in the PDF document and become clickable links.  It is enabled in the desktop version of Acrobat Reader/standard/Pro DC by default.
                    To disable the Create links from URLs" option
                    1. Open the Preferences dialog in Acrobat Reader/Standard/Pro (desktop app).
                    2. Select General in the left pane.
                    3. Uncheck the "Create links from URLs" check box.  (You are disabling the option now.)
                      (Click the image to enlarge)
                    4. Open your PDF document (Senza nome.pdf).
                    5. Try clicking each link at the bottom of the page.
                    The text (http://...) is no longer a hyperlink.
                    Please check a new forum private message to find the shared link to the PDF document containing the real hyperlinks that I created using Acrobat Pro DC.  You should be able to tap the hyperlinks in Acrobat Reader to open them in Safari on iPad/iPhone.
                    Hope this helps.
                    • 7. Re: Hyperlinks in a PDF: how to work with them in iOS?
                      ninovillari Level 1
                      thank you indeed: it works finally!
                      I'll buy Acrobat Pro DC and I will have only to add real hyperlinks to each one PDF (they are hundreds, but it's really OK!).
                      The only downside I see is the high cost.
                      Cheers
                      Nino
