1 Reply Latest reply on Apr 3, 2017 7:22 PM by MinusZero
    Show/hide subform with dropdown selection
    christie7F
      I've been working at this for hours and my pea brain just can't handle it!
      My dropdown menu contains two selections, but on form open the selection is <none>
      1 - MAINTENANCE DIRECTIVE
      2 - TECHNICAL INFORMATION BULLETIN
      Dropdown menu is called "TitleType" and is located on the master page.
      I have a subform within the main subform called "subformTIB" It contains information that should be hidden when the client selects dropdown option
      when 1 - MAINTENANCE DIRECTIVE is selected, "subformTIB" should be visible and when <none> is selected, it doesn't make a difference.
      Can anyone help with code?
      I'd be happy to provide the form if necessary.
        • 1. Re: Show/hide subform with dropdown selection
          MinusZero Level 3
          If you only have two options, ensure you have code for both options. I find it works better to have specific code per item rather than an else code.
          Example: If the first option hides a field and the second option doesnt. Make sure that is reflected in both item's code.
               In the first option: show required option 1 fields and hide the option 2 fields.
               In the second option: show the option 2 fields and hide the option 1 fields.
