I have the error coming up every time I open a pdf file either coming from outside or created by myself. This started a 2 or 3 days ago.
When I click on it does not stop adobe reader as claimed only disappear and some time reappear once.
I uninstalled the version 15.023.20070 and downloaded the version available on the site that is the same version.
The problem remain
It appears that I ma not the only one.
Solution?
[Moved from non-technical Lounge to Adobe Reader forum by moderator]
Hi Robertl41493565,
You must try the following steps-
Control Panel\All Control Panel Items\Programs and Features\Visual C++ Redistributable 2013 (right click and repair)
Let us know if
...Copy link to clipboard
Hi Robertl41493565,
Let us know if it still doesn't work.
Regards,
Akanchha
It worked with the repair function
Perfect!
Let us know if there is any further assistance is required.
Regards,
Akanchha
I have this same issue but don't have Microsoft visual C++ 2013 Redistributable(x64&x86) installed on this desktop. Older versions are installed, 2005, 2008, and 2010.
1) Do I just install the 2013 Redistributable?
2) Do I uninstall the older versions, then install the 2013 Redistributable?
3) Try to run Repair on the older versions of the Redistributable
Thank you,
Jack
It's always good to have latest and safest version of an application so repair existing and install 2013 Redistributable.
Let us know how it goes.
-Thanks
Sunil Soni
Thank you. The repair option was not available for the older versions but installing the 2013 Redistributable fixed the issue.
Jack
Adobe u (read "customers") shouldn't have to search for this information and fix. When we download Adobe Reader, or other affected products, Adobe should have notes, warnings, etc. for unsuspecting customers about these issues. Very poor customer support issue here!
