3 Replies Latest reply on Mar 31, 2017 12:56 PM by stevenm67493853
    unit conversion
    stevenm67493853 Level 1
      Does anyone know of a JavaScript that would allow you to have 2 text fields, one that displays a number in Inches, and other that displays the equivalent value in Millimeters, yet both can have a value entered into it with the result being the other field re-calculating to the equivalent value in Inches or Millimeters?
      In other words, both fields would be acting as an input field AND an output display field at the same time.
        • 1. Re: unit conversion
          Joel_Geraci Adobe Community Professional
          I don't have the exact script but I can give you the trick to making it work... put the conversion calculation in a custom format script of each field. The format script in A will set the value in B and vice versa. You want to add the code to the format script because that gets executed after the value has been validated and as long as you don't set a value to the format event, it won't effect the appearance of the value.
          • 2. Re: unit conversion
            A bit tricky, but possible. Let's say these fields are called "Inches" and "MM".
            Enter this code as the custom validation script of Inches:
            this.getField("MM").value = event.value * 25.4;
            And this code as the custom validation script of MM:
            this.getField("Inches").value = event.value * 0.0393701;
            • 3. Re: unit conversion
              Thanks so much, it worked!
