3 Replies Latest reply on Apr 1, 2017 1:26 PM by Tomas Sinkunas
    Save as jpg, containing selected layer name
    mauricior6328708 Level 1
      Hello, greetings to all!
      1- I open a document,
      2- I Perform an action to set the color, size, and print type setting
      3- I Merge all layers of the document, and rename it to: Print_A4-MD
      4- Now I need to create a backup of this configured document for future impressions.
      The first 3 steps I can perfectly with actions I recorded:
      So I found a form that I like a lot:
      When I select the "Print_A4-MD" layer and execute a Script, I save in the same directory a file named Print_A4-MD.jpg, containing the name of the selected layer.
      My question is:
      How to modify the script to save Print_A4-MD_01.jpg, Print_A4-MD_02.jpg, Print_A4-MD_03.jpg ..... whenever I re-run this script on the same selected layer ?? Thank you.
      Here is the script for review:
      // saves jpg into same folder;
      // be advised: this  overwrites existing jpgs of the same name without prompting.
      // 2010, use it at your own risk;
      #target photoshop;
      if (app.documents.length > 0) {
      var thedoc = app.activeDocument;
      // getting the name and location;
      var docName = thedoc.name;
      if (docName.indexOf(".") != -1) {var basename = docName.match(/(.*)\.[^\.]+$/)[1]}
      else {var basename = docName};
      // getting the location, if unsaved save to desktop;
      try {var docPath = thedoc.path}
      catch (e) {var docPath = "~/Desktop"};
      // jpg options;
      var jpegOptions = new JPEGSaveOptions();
      jpegOptions.quality = 9;
      jpegOptions.embedColorProfile = true;
      jpegOptions.matte = MatteType.NONE;
      //save jpg as a copy:
      thedoc.saveAs((new File(docPath+'/'+thedoc.activeLayer.name+'.jpg')),jpegOptions,true);
      //that’s it; thanks to xbytor;
        • 1. Re: Save as jpg, containing selected layer name
          Tomas Sinkunas Level 3
          There you go.
          (function() {
              try {
                  #target photoshop;
                      var basename = docName;
                      var docPath = "~/Desktop";
                      try {
                          docPath = thedoc.path;
                      } catch (e) {}
                      // jpg options;
                      var saveFile = docPath + '/' + thedoc.activeLayer.name + '.jpg';
                      if (File(saveFile).exists)
                          saveFile = incrementFile(saveFile);
                      thedoc.saveAs(new File(saveFile), jpegOptions, true);
                  function incrementFile(pathToFile) {
                      var saveSufixLength = 2,
                          suffix = zeroPad(0, saveSufixLength),
                          newPathToFile = pathToFile,
                          suffixInteger, folder, fileName, extension;
                      while (File(newPathToFile).exists) {
                          suffixInteger = parseInt(suffix, 10);
                          suffixInteger += 1;
                          suffix = zeroPad(suffixInteger, saveSufixLength);
                          folder = File(pathToFile).path;
                          fileName = File(pathToFile).name.substring(0, File(pathToFile).name.lastIndexOf("."));
                          extension = File(pathToFile).name.substring(File(pathToFile).name.lastIndexOf(".") + 1, File(pathToFile).name.length);
                          newPathToFile = folder + "/" + fileName + "_" + suffix + "." + extension;
                      return newPathToFile;
                      function zeroPad(num, digit) {
                          var tmp = num.toString();
                          while (tmp.length < digit) {
                              tmp = "0" + tmp;
                          return tmp;
              } catch (e) {
                  alert(e.toString() + "\nScript File: " + File.decode(e.fileName).replace(/^.*[\|\/]/, '') +
                      "\nFunction: " + arguments.callee.name +
                      "\nError on Line: " + e.line.toString())
          • 2. Re: Save as jpg, containing selected layer name
            It worked perfect! Forever grateful to you. I see almost all posts in this forum and I realize that you "Tomas Sinkunas " has collaborated very efficiently and helped a lot. Many thanks for the great help and congratulations for the work on After Efects.
            www.rendertom.com
