5 Replies Latest reply on Apr 2, 2017 7:41 AM by vincentp81166026
    [JS] #include does not work
      Hi guys,
      i'm an Applescript guy trying to translate an AS script in JS.
      So far, it's working with one pb though: i want to use the array.filter method in my script but it doesn't work.
      I've replaced it via a simple loop and it work, but as it seems it could be done via the use of a polyfill, i tried that too, without success.
      I guess i have done something wrong somewhere and i hoped someone here could help me find it!
      What i've done so far:
      - copy the polyfill for that method from this page on MDN,
      - creating a new file on ExtendScript*, paste the code, save the file ("polyfills.jsx"**) in the same folder as my script.
      - added at the beginning of my script "#include 'polyfills.jsx';"
      * I don't know if it's relevant, but the selected engine when saving the file was "Adobe InDesign CC2017 (12.064)", the same used by my script.
      ** I couldn't use the .jsxinc extension as when i do that, it create a "polyfills.jsxinc.jsx" file.
      When i launch my script in ExtendScript Toolkit, it throws an error on the line where i use the filter method : 'xxx.filter is not a function'.
      So the polyfill doesn't seem to work.
      The code where i use the filter method:
      var my_textFrames = doc.textFrames;
      var my_filtered_textFrames = my_textFrames.filter(function (element) {
          return (element.label.indexOf('tableau') !== -1);
      Thank for your help!
      OS X 10.11.6
      InDesign CC 2017
        • 1. Re: [JS] #include does not work
          Vamitul Level 4
          doc.textFrames is not an ARRAY but a collection.
          you should convert it to an array:
          var my_textFrames = doc.textFrames.everyItem().getElements();
          • 2. Re: [JS] #include does not work
            vincentp81166026 Level 1
            Ok i'll try that, thanks for the quick reply!
            • 3. Re: [JS] #include does not work
              Hi Vincent,
              you have to be very careful using the right string for filtering with prototyped method filter() as presented at MDN.
              I know, it's a bit dump, but I like to show a point here.
              Category 1 | Have some text frames labeled:
              Category 2 | Others should be labeled:
              Example line in your filter function:
              return (element.label.indexOf("SelectThis") !== -1);
              would return all two categories of labeled text frames.
              So I would suggest the more lame approach with a different tool set to get the labeled text frames:
              var doc = app.documents[0];
              var textFramesArray = doc.textFrames.everyItem().getElements();
              var textFramesArrayLength = textFramesArray.length;
              var n = 0;
              var regExp = RegExp("^SelectThis$"); // A softened version would be: RegExp("^SelectThis$", "i")
              var resultArrayOfTextFrames = [];
                  var currentItem = textFramesArray[n];
                      resultArrayOfTextFrames[resultArrayOfTextFrames.length++] =
              Or this alternative in the for loop using method test() on a RegExp.
              // ALTERNATIVE for match():
              • 4. Re: [JS] #include does not work
                Hi Uwe,
                thanks for the reply.
                In the context of my script, i think my test is ok as there is only one text frame in the document that have a label which contain that string, so there is no ambiguity in this case.
                But still, i'll look carefully at your alternative methods: my AS>JS journey is only beginning and i need every advise and code exemples i could get  ;-)
                • 5. Re: [JS] #include does not work
                  Hi Vamitul,
                  it worked as expected, thanks for the tip.
                  For JS/ExtendScript newbies like me, i found a treasure tove of informations regarding how to work with collections in those two articles of Marc Autret.
                  A little difficult to digest at once but nevertheless incredibly useful.
