First, sorry for my "bad" english.
I attemp to use a ICC profile in Lightroom. His adress is "https://static.whitewall.com/ICC/WhiteWall_ICC_Direct_Print_Dibond.icc#_ga=1.164966527.1356638412.14...".
When I want to use it, it don't appears in Lightroom; (I start by charge it into the good directory).
When I ask the internet site , they say that, for them, this profile is ok because it run under Photoshop.
To verify if my process is ok , I did the same process wiht another ICC profile ("https://static.whitewall.com/ICC/WhiteWall_ICC_Lambda_Fuji_Crystal_DP_II_glossy.icc#_ga=1.241700225....") and, in this case, the profile appears in Lightroom.
My Pc is on windows 10-1607 with Lightroom 6 in version 6.8.
Have anyone a suggestion what I did wrong or what the solution is?
Thanks a lot
Yep, it's a CMYK profile. It does work in Photoshop.
It's not working for me either, so it's either a CMYK profile (which Lightroom doesn't support), or there is something wrong with it.
thanks for the 2 responses.
In conclusion, I have to use Photoshop if I want to see the soft proofing.
