1. Re: App design size
kerrishottsApr 2, 2017 12:45 PM (in response to kumarpgt)
If PSDs are used exactly as given, they are typically sliced up into smaller component pieces. JPGs aren't good unless they are for photographic content (icons and such are better as PNGs). From the sounds of it, though, the developer intends on recreating the look from what you send (depending on the type of graphics you're using, it can be done with some CSS). Without knowing what "size" means in this context, it's difficult to know what the developer is requesting -- are they wanting viewport size, widget sizes, etc? If this is a completely custom interface, the developer will need some guidance on the metrics you intend your widgets to use (padding, margins, rhythm, etc.)
So, regarding "size": one "size" doesn't fit all when it comes to mobile devices. Devices have varied pixel densities, aspect ratios, and with the advent of split-screen multitasking, varied viewports as well. Apps need to be able to respond to various visual constraints and device capabilities, hence the term "responsive design". Your developer should recognize the term.
Widget assets should be scaleable to accommodate various viewports (typically this will be by tiling or using a 9-patch-like format). Photographic images should have enough pixels to accommodate the largest possible viewport at the highest possible pixel density (the developer should then create smaller versions that work better for smaller screens and lower-powered devices).
If you are amenable, it might help to see your design PSD; it might help us spot anything your developer might be talking about. If you want to DM it, feel free to do so.
Hope that helps some.
2. Re: App design size
criss14911030 Apr 5, 2017 4:04 AM (in response to kerrishotts)Dimensions
- LDPI:
- Portrait: 200x320px
- Landscape: 320x200px
- MDPI:
- Portrait: 320x480px
- Landscape: 480x320px
- HDPI:
- Portrait: 480x800px
- Landscape: 800x480px
- XHDPI:
- Portrait: 720px1280px
- Landscape: 1280x720px
- XXHDPI:
- Portrait: 960px1600px
- Landscape: 1600x960px
- XXXHDPI:
- Portrait: 1280px1920px
- Landscape: 1920x1280px
Thanks.
Cris
- LDPI:
