• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Move Text Frame Outside Page into Bleed using Javascript
Explorer ,
Apr 02, 2017 Apr 02, 2017
I need to move the text frame created in the below script to outside the page area to the bleed area. If anyone can help me adjust the below script, that would be wonderful. I have been trying to determine how to use Page Height and Width to do an X, Y adjustment once that is determined.
I was thinking of using a Get Bounds variable, but I have not been able to successfully incorporate it.
Please see my code below. Any and all help would be greatly appreciated and thank you in advance.
myDocument = app.activeDocument;
//The bleed and slug properties belong to the documentPreferences object.
with (myDocument.documentPreferences) {
//Bleed
documentBleedBottomOffset = "2in";
documentBleedTopOffset = "2in";
documentBleedInsideOrLeftOffset = "2in";
documentBleedOutsideOrRightOffset = "2in";
//Slug
slugBottomOffset = "0p";
slugTopOffset = "0p";
slugInsideOrLeftOffset = "0p";
slugRightOrOutsideOffset = "0p";
var myDocument = app.documents.item(0);
var myPage = myDocument.pages.item(0);
var myTextFrame = myPage.textFrames.add();
//Set the bounds of the text frame [x1, y1, x2, y2]
//The x1, y1 refers to the upper left coordinate position; the x2, y2 refers to the lower right coordinate
//x2 = Height and y2 = Width
myTextFrame.geometricBounds = [0, 0, .52, 5.5];
//Enter text in the text frame.
//("\r" is a return character.+
myTextFrame.contents = "FName Name//12345-6789//\r WxL//\r XXX-YYYYY//W x L-LtrRD//P_";
myTextFrame.parentStory.insertionPoints.item(-1).contents = SpecialCharacters.autoPageNumber;
//Note that you could also use a properties record to
//create the frame and set its bounds and contents in one line:
//var myTextFrame = myDocument.pages.item(0).textFrames.add({geometricBounds:[72, 72, 288, 288], contents:"This is some example text."});
//Absolute move: based on [X , Y] its important to keep in mind that all units are based on your document units
myTextFrame.move([1, 5.5]);
TOPICS
Scripting
Views
773
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Apr 04, 2017 Apr 04, 2017
I was finally able to figure out that I should use the myDocument.documentPreferences.pageHeight property within my move statement. This will require the move to get the height of the document.
    myTextFrame.move([-1.5161, myDocument.documentPreferences.pageHeight + .72]);
Votes
Translate
Translate
Engaged ,
Apr 03, 2017 Apr 03, 2017
Hi ,
Try this code:
var myDoc = app.documents[0];
with(myDoc.documentPreferences)
documentBleedUniformSize = true;
documentBleedTopOffset = "3p";
var myPage = myDoc.pages.item(0);
myTextFrame.geometricBounds = ["4p", "3p","58p" , "25p"];
// Use Y1, X1, Y2, X2
myTextFrame.contents = "pages\rtextFrame\rgeometricBounds";
var newPosition = ["-1.5in"," 0in"];
myTextFrame.move(newPosition)
alert("TextFrame moved")
Prabu
Prabu
Design smarter, faster, and bolder with InDesign scripting.
Votes
Translate
Translate
Report
Report
Explorer ,
Ananth:
Thank you for sending this over. So, I understand what your doing in terms of the coordinates. So, lets say that the X= -1.5 but the Y= .72" below the page size. Keep in mind that the page size could vary and therefore I need the box to always be .72 below the page size no matter the size.
Best, John
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Votes
Translate
Translate
Report
Report
