1 Reply Latest reply on Jan 5, 2009 10:07 AM by Gregory Lafrance
    custom window
    W0utR
      When you create an AIR application using Flex 3, is it possible to create a custom window?
      For example, can u create a window in the shape of a circle and use it as the normal WindowApplication?
        • 1. Re: custom window
          Gregory Lafrance Level 6
          Sure, just set the systemChrome to none in the -app.xml file: <systemChrome>standard</systemChrome>
          Then set showFlexChrome="false" in the WindowedApplication tag.
          Then set the backgroundImage to the circle image you want the app to use.
