1. Re: How to remove black aberation fringe in a black & white photograph
Mohit GoyalApr 2, 2017 9:51 PM (in response to Diesel16)
Hi Diesel,
You may try the below tutorial.
Get Rid of Those Pesky Edge Halos in Photoshop — SitePoint
Mohit
2. Re: How to remove black aberation fringe in a black & white photograph
Diesel16 Apr 2, 2017 10:05 PM (in response to Mohit Goyal)Thank you so much for replying – I will check that out
3. Re: How to remove black aberation fringe in a black & white photograph
Trevor.Dennis Apr 2, 2017 10:33 PM (in response to Diesel16)We need to see the image to give a proper answer. It's very straight forward. Copy to clipboard and paste to the thread with Ctrl v
4. Re: How to remove black aberation fringe in a black & white photograph
Diesel16 Apr 3, 2017 12:20 AM (in response to Trevor.Dennis)Thanks for your help...image attached. I hope you can see the fringe on the horizon.
Removing the CA in the colour version seems to have darkened that line.
If this reply doesn't show the image in the thread I will paste separately.
cheers Anne
6. Re: How to remove black aberation fringe in a black & white photograph
D Fosse Apr 3, 2017 1:10 AM (in response to Diesel16)Actually this looks like sharpening artifacts to me - there's as much a bright line above the horizon as a dark one below it. I don't think this happened because of CA.
How did you sharpen? There are ways to avoid this kind of thing - primarily using the ACR filter to do sharpening, with a low "detail" setting. You can also sharpen on a duplicate layer and mask out as needed.
7. Re: How to remove black aberation fringe in a black & white photograph
Trevor.Dennis Apr 3, 2017 1:55 AM (in response to Diesel16)1 person found this helpfulHi Ann (it's nice to have real names and know who we are talking to)
OK I can't see a dark fringe, but there is a light one pixel halo in places along the horizon. That is fixable with a semi manual process.
These are zoomed to 200%. It would be a lot more useful to see a section of your image viewed at 100% (Ctrl Alt i — Cmd Opt i)
This trick works because skies tend to be lighter than the ground beneather the horizon, and the halos are lighter still.
Add a new layer and set its blend mode to Darken
Use the Clone tool with its blend mode set to Darken, and clone out the halo.
You don't need to mask because the sky won't overwrite the ground which is darker, but the halo being lighter will be overwritten.
This screen shot shows the original (offset) and the fix. The highlights show the required settings
If I am missing something here (you did say dark fringe) then show us the relevant part of the image at 100%
9. Re: How to remove black aberation fringe in a black & white photograph
Diesel16 Apr 3, 2017 2:32 AM (in response to Trevor.Dennis)You are all amazing at taking the time, I’m very grateful.
Loading up a crop that shows the horizon fringe now
10. Re: How to remove black aberation fringe in a black & white photograph
Diesel16 Apr 3, 2017 2:36 AM (in response to D Fosse)Thanks for your comment.
I did explain in my original post that I have not done any sharpening whatsoever.
Perhaps it was removing the CA in the colour version that created the bright line?
To be honest I hadn’t noticed it – I was focusing my attention on the black line below the horizon.
11. Re: How to remove black aberation fringe in a black & white photograph
Then it is probably resampled (resized) using "bicubic automatic" or "bicubic sharper", which has sharpening built into the algorithm.
Many people feel that sharpening is too aggressive with these interpolation methods, and I happen to be one of them. I always use "bicubic smoother".
I'm almost 100% certain that this is caused by sharpening, not CA.
12. Re: How to remove black aberation fringe in a black & white photograph
Diesel16 Apr 3, 2017 2:43 AM (in response to Trevor.Dennis)Yes – now I’m looking, I can see the light bits. I tried your fix – worked perfectly.
Perhaps I can apply the same principle but use the lighten blending option in place of the darken ones and achieve the opposite? Will give it a try
13. Re: How to remove black aberation fringe in a black & white photograph
Diesel16 Apr 3, 2017 4:25 AM (in response to Diesel16)Thanks again Trevor - it all worked perfectly & I have now got rid of the light parts and the dark band too :-)
It took a while but I am grateful to have learned something new.
I am also impressed that kind people offer solutions and help us less knowledge ones.
