I have a problem quite similar to this one:
Re: how do you have a second picture appear when you rollover the first one
Except that I want to make text appear instead of a new image. The only way I can figure out, to do this, is by converting some text into an image file and using that - but then the text can't easily be changed afterwards. Furthermore, this means I cannot make a hyperlink from some part of the text.
Does anyone in hear know how to do this in a more effective way?
Use a "States" button to achieve this in a very simple way. All elements within a states button are triggered, when the states button itself is "touched" (hovered, clicked) by your mouse:
• Place an image into the button.
• Place a text object into the button too and assign "Opacity: 0 %" to it in normal state.
• Now go to mouseover state and assign "Opacity: 100 %" to the text element.
• That's it.
• That's it.
Yes, that works! Thank you very much!
But I can't make a headline and a paragraph with different fonts and/or sizes, within the same text box. Do anybody know, if this can be done somehow?
What? Could you explain this? Of course you can have different text attributes in the same text box! What exactly do you want to say us?
When I choose a part of the text in my text box and choose another font, size or color, nothing happens except, that the box, where I chose another attribute says, that the text is now for example green. If i choose the entire text, I can change these things, but it will affect everything in the text box. When I view it in preview, the entire text still has the same attributes.
Is it possible, that you didn’t read my posting precisely enough?
Look at this example: http://states-button-demo.businesscatalyst.com/index.html
You may download the example file directly from this site.
I don’t explain anything for now, because it is really better, if you figure out the solution by yourself.
If you can’t -> ask!
