0 Replies Latest reply on Dec 16, 2008 12:50 AM by amaliap
    swf build with java compiler
    amaliap
      Hi.
      I am trying build a swf file using java (Java-based Compiler API);
      I am using some fusion chart:
      ns1:FusionChart id="chart1" FCchartType="MSColumn3D" FCdataURL=" http://localhost:8090/ServletApp"
      I added in the java code the FusionChart.swc as lib and the mxml file containing the chart:
      Application application = new Application(new File("D:\\demo_SWC_app.mxml"));
      Configuration c = application.getDefaultConfiguration();
      File[] libFile = new File[]new File("D:\\libs", "FusionChart.swc")};
      c.addLibraryPath(libFile);
      Using Flex3builder the application (mxml file+ chart swf) works perfectly.
      My problem is that I don t know how to specifiy to the java api how to add the swf files of the charts. I have the file MSColumn3D.swf in the same folder as the mxml and the generated swf file (generated by java)... I added the chart swf file to trusted files in Adobe Manager, but I get the following error when I embed the generated swf into a html file (to see it in a browser):
      ReferenceError: Error #1069: Property url not found on _demo_SWC_app_mx_managers_SystemManager and there is no default value.
      at com.fusionchart.components.flx.external::FlashInterface$/getSWFName()
      at com.fusionchart.components.flx.external::FlashInterface$/getId()
      at com.fusionchart.components.flx.external::FlashInterface$/publish()
      at com.fusionchart.components::FusionChart/loaded()
      I do hope I was clear enough.
      Can anyone provide me some help? Thank you
