I HAVE 100 + MOCKUPS AND WANT TO CHANGE MY DESIGN IN ALL MOCKUPS I ADD DESIGN AND 2 MOCKUPS PLEASE HELP
1st mockup : 1+3 t.psd - Google Drive
2st mockup : Apple Iphone 6 6s.psd - Google Drive
Image : Black-Gold-Marbel-Unisex-Design.psd - Google Driv...
These are 2 mockups and one psd i have multiple mockup like this 100+ i want to do changes in all mockup with this image
// select folder of mock-ups, if they contain exactly one smart object replace its content with selected designs and save jpg-files;
// 2017, use it at your own risk;
#target photoshop
var theFolder = Folder.selectDialog ("select folder");
if (theFolder) {
var theFiles = theFolder.getFiles(/\.(psb|tif|psd)$/i);
if (theFiles.length > 0) {
//var theDesigns = theFolder.getFiles(/\.(psb|jpg|tif|psd)$/i);
// select files;
if ($.os.search(/windows/i) != -1) {var theDesigns = File.openDialog ("please select fil
...Copy link to clipboard
#target photoshop
if (theFolder) {
// select files;
if ($.os.search(/windows/i) != -1) {var theDesigns = File.openDialog ("please select files", "*.psd;*.psb;*.tif", true)}
else {var theDesigns = File.openDialog ("please select files", getFiles, true)};
if (theDesigns.length > 0) {
for (var x = 0; x < theFiles.length; x++) {
replaceSmartObject(theFiles
////// replace smart object content if only one smart object exists //////
function replaceSmartObject (theFile, theDesigns) {
var myDocument = app.open(theFile);
var theSmartObjects = collectSmartObjects();
// if only one smart object;
if (theSmartObjects.length == 1) {
var theName= myDocument.name.match(/(.*)\.[^\.]+$/)[1];
var thePath = myDocument.path;
var theLayer = theSmartObjects[0][0];
myDocument.activeLayer = theLayer;
// psd options;
psdOpts = new PhotoshopSaveOptions();
psdOpts.embedColorProfile = true;
psdOpts.alphaChannels = true;
psdOpts.layers = true;
psdOpts.spotColors = true;
// jpg options;
var jpegOptions = new JPEGSaveOptions();
jpegOptions.quality = 9;
jpegOptions.embedColorProfile = true;
jpegOptions.matte = MatteType.NONE;
// work through the array;
for (var m = 0; m < theDesigns.length; m++) {
// replace smart object;
theLayer = replaceContents (theDesigns
var theNewName = theDesigns
//save jpg;
myDocument.saveAs((new File(thePath+"/"+theName+"_"+theNewName+".jpg")),jpegOptions,true);
myDocument.close();
////// get psds, tifs and jpgs from files //////
function getFiles (theFile) {
if (theFile.name.match(/\.(psd|tif|psb)$/i) != null || theFile.constructor.name == "Folder") {
return true
////// replace contents //////
function replaceContents (newFile, theSO) {
app.activeDocument.activeLayer = theSO;
var idplacedLayerReplaceContents = stringIDToTypeID( "placedLayerReplaceContents" );
var desc3 = new ActionDescriptor();
var idnull = charIDToTypeID( "null" );
desc3.putPath( idnull, new File( newFile ) );
var idPgNm = charIDToTypeID( "PgNm" );
desc3.putInteger( idPgNm, 1 );
executeAction( idplacedLayerReplaceContents, desc3, DialogModes.NO );
return app.activeDocument.activeLayer
////// select smart objects, based on paul riggottās code //////
function collectSmartObjects(){
var theSmartObjects = new Array;
if(!documents.length) {return};
selectAllLayers();
var selectedLayers = getSelectedLayersIdx();
for(var a = 0; a < selectedLayers.length; a++){
if(hasSmartObject(Number(selectedLayers))){
makeActiveByIndex(Number(selectedLayers),false);
theSmartObjects.push([app.activeDocument.activeLayer, a])
return theSmartObjects;
function hasSmartObject(idx){
var ref = new ActionReference();
ref.putProperty( charIDToTypeID("Prpr") , stringIDToTypeID( "smartObject" ));
ref.putIndex( charIDToTypeID( "Lyr " ), idx);
var desc = executeActionGet(ref);
if(desc.hasKey(stringIDToTypeID('smartObject'))) {return true}
else {return false};
function makeActiveByIndex( idx, visible ){
var desc = new ActionDescriptor();
ref.putIndex(charIDToTypeID( "Lyr " ), idx);
desc.putReference( charIDToTypeID( "null" ), ref );
desc.putBoolean( charIDToTypeID( "MkVs" ), visible );
executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
function getSelectedLayersIdx(){
var selectedLayers = new Array;
ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
var c = desc.count;
var selectedLayers = new Array();
for(var i=0;i<c;i++){
try{
activeDocument.backgroundLayer;
selectedLayers.push( desc.getReference( i ).getIndex() );
}catch(e){
selectedLayers.push( desc.getReference( i ).getIndex()+1 );
}else{
ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
try{
selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1);
}catch(e){
selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" )));
return selectedLayers;
function selectAllLayers() {
var desc29 = new ActionDescriptor();
var ref23 = new ActionReference();
ref23.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
desc29.putReference( charIDToTypeID('null'), ref23 );
executeAction( stringIDToTypeID('selectAllLayers'), desc29, DialogModes.NO );
its working fine but ever time popup comes that please close or save
If you are certain the files were not open before running the Script and therefore might contain unsaved changes you could change the line
myDocument.close()
to
myDocument.close(SaveOptions.DONOTSAVECHANGES)
Good luck!
Ohk Thankyou So much My Friend For Your Help Hope Once Day I Will Learn Coading And Help
Hello Maa Friend
Is There Is any why to make it faster
That may well be ā¦
Generally AM code is faster than DOM code so you could try replacing the saving portion with AM code.
The function Ā»collectSmartObjectsĀ« also might be improved in that regard.
Ohk Sure
Hie C.pfaffenbichler I Have One Question When This Script get or open mocups from the folder i want it should ger mockups from the subfolders also so that diffrent diffrent images not mix How Can i change this portion of script
#target photoshop
if (theFolder) {
// select files;
What exactly do you mean?
Please post screenshots clarifying the File/Folder-structure and the results you want to get.
Like Now I Have To Put All Mockups in One Folder i Have 10 Different Category Mockups I Want To Put ALL MOCKUPS in different folder so that one i open script script gonna pick the files from the folders and i am gonna get the output in all folders different different
Maybe this can help:
#target photoshop
// select a folder;
var sourceFolder = Folder.selectDialog("Select folder");
if (sourceFolder) {
// get the contents as one array per folder;
var theFiles = retrieveFiles(sourceFolder, [[]]);
alert (theFiles.join("\n"));
////// get from subfolders //////
function retrieveFiles (theFolder, theFiles) {
if (!theFiles) {var theFiles = [[]]};
var theContent = theFolder.getFiles();
for (var n = 0; n < theContent.length; n++) {
var theObject = theContent
; if (theObject.constructor.name == "Folder") {
theFiles.push(new Array)
retrieveFiles(theObject, theFiles)
if (theObject.name.match(new RegExp(/\.(jpe|jpg|jpeg|gif|png|tif|tiff|bmp|psd|dng|pict|eps|raw|rw2|crw|cr2)/i)) != null) {
theFiles[theFiles.length - 1].push(theObject)
return theFiles
Not Working LET ME EXPLAIN YOU WITH SCREEN SHOT
This is 1st Folder In which all other mockup files are there in diffrent diffrent folders
Now This is inside ALL FOLDER 2 Catagories With Mockup Files
NOW I WANT I WILL OPEN ALL FOLDER AND DONE THEN I CHOOSE IMAGES AND DONE APPLE I6 MOCKUP WILL CREATE READY FILES ON IPHONE 6 FOLDER AND GIONEE A1 MAKE FILES IN GIONEE A1 FOLDER
Not Working
The code was just an example of how to get the files in Folders within a selected Folder.
The screenshots do not seem to clarify the issue to me sufficiently.
Maybe you should start a new thread, that way you may attract somebody elseās attention who may be able to help you better.
Ohk Actually You Write This Code So I Was Thinking You Know Better Then This Code Then Anyone Else
Let Me Give You One Example Like when we search in computers we get all the files even the files which Are in folder or in child folder
its like parent child then sub child game is like this
Convert All The Files Even In Subfolders THERE IS 1 FOLDER INSIDE THE FOLDER THERE IS ONE MORE FOLDER AND IN THAT FOLDER THERE ARE MOCKUPS LIKE THIS (ALL>IPHONE6>I6.PSD) STRUCTURE IS LIKE THIS FOLDER>SUBFOLDER>MOCUP.PSD
WE HAVE TO CHOOSE FOLDER MOCUP.PSD WILL AUTOMATICALLY PIC
WHEN WE DO IMAGE PROCCESS IN PHOTOSHOP THERE WE GET OPTION LIKE INCLUDE SUB FOLDER LIKE THIS WE HAVE TO DO SAME
and how can i change Am Code ???
You can record AM code with ScriptingListener.plugin
