1 Reply Latest reply on Apr 5, 2017 2:39 AM by Günter Heißenbüttel
    The rectangle box expand in the base slide show caption box
    nilleg57851248 Level 1
      At sett the caption box high to 40, but when I add the images in the thumbnail box, it expand to 48 px and I can´t change it. Why? And how can I avoid it ?
      It's only the caption box that changes, not the fwd, bad and numbers placed at the same Y as the caption box.
        • 1. Re: The rectangle box expand in the base slide show caption box
          Günter Heißenbüttel Adobe Community Professional
          I don’t understand. Here the caption box stays at the height you have defined.
          I think, your problem is the following:
          You want to format your text in a size, which won’t fit into the container. If your font size is too big, the container can’t be reduced under a certain limit. You can correct this – of course – within appropriate limits – by
          • selecting the caption box (not the text within), and
          • opening the "Spacing" panel to reduce the values for "Padding", which are set to 10 px by default.
