1 Reply Latest reply on Apr 5, 2017 12:04 PM by ryanskihead
    Faild compling Andriod IP
    rawanda70877183
        Dears,
      I purchased an APP, which i made some minor changes.  After compiling on PhoneGap i get following error result.  can you please help me to resolve this issue?
      Build Date: 2017-04-05 09:32:06 +0000
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preReleaseBuild UP-TO-DATE
      :checkReleaseManifest
      :preDebugBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseAidl
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:processReleaseManifest
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportSupportV132340Library
      :prepareComAndroidSupportSupportV42400Library
      :prepareComGoogleAndroidGmsPlayServicesBase1020Library
      :prepareComGoogleAndroidGmsPlayServicesBasement1020Library
      :prepareComGoogleAndroidGmsPlayServicesGcm1020Library
      :prepareComGoogleAndroidGmsPlayServicesIid1020Library
      :prepareComGoogleAndroidGmsPlayServicesLocation980Library
      :prepareComGoogleAndroidGmsPlayServicesMaps980Library
      :prepareComGoogleAndroidGmsPlayServicesTasks1020Library
      :prepareProjectCordovaLibUnspecifiedReleaseLibrary
      :compileReleaseAidl
      :mergeReleaseResources
      /project/src/plugin/google/maps/PluginCircle.java:28: error: cannot access AbstractSafeParcelable
        circleOptions.center(new LatLng(center.getDouble("lat"), center.getDouble("lng")));
        class file for com.google.android.gms.common.internal.safeparcel.AbstractSafeParcelable not found
      Note: Some input files use unchecked or unsafe operations.
      Note: Recompile with -Xlint:unchecked for details.
      1 error
      :compileReleaseJavaWithJavac FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':compileReleaseJavaWithJavac'.
      > Compilation failed; see the compiler error output for details.
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 3.173 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      1 error
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5) !
        • 1. Re: Faild compling Andriod IP
          ryanskihead Adobe Employee
          Looks like cordova-plugin-googlemaps and phonegap-plugin-push are dependent upon different versions of the android play services / android support libraries. Try this combination:
          <plugin name="phonegap-plugin-push" source="npm" spec="1.5.3"/>
          <plugin name="cordova-plugin-googlemaps" spec="~1.3.0">
          <param name="API_KEY_FOR_ANDROID" value="XXX"/>
          <param name="API_KEY_FOR_IOS" value="XXX"/>
          </plugin>
          Also note the gap: xml namespace is no longer needed on the plugins in your config.xml.
