• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Little effect lines
Explorer ,
Apr 05, 2017 Apr 05, 2017
How to get such little line effects like on the pictures? The ones over the players please.
Views
215
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Apr 05, 2017 Apr 05, 2017
Use the line tool for the vertical lines.
Set the line thickness in the 'Weight' field in the Options bar.
Make sure it is set to Shape
Set Fill to black, and stroke to None.
Add a new layer
Ctrl a to select all
With black as your foreground colour, go Edit > Stroke choose Inside and amount the same as the previous line thickness.
Job done.
Votes
Translate
Translate
Adobe
Community Expert ,
Add a new layer
Job done.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Do you mean those diagonal lines across the whole image?
If so:
1. Create a pattern of black and white horizontal lines (use the line tool then Edit-Define pattern)
2. Add a layer above your image and fill it with your pattern
3. Edit -Transform - Rotate that layer to make the stripes diagonal then use Content aware fill to fill the gaps at the corners
4. Set blending mode to Luminosity and reduce opacity to suit the image and get the effect you want
Dave
Edit : Haha - I hit the reply button and find Trevor has beaten me to it
Votes
Translate
Translate
Report
Report
