0 Replies Latest reply on Apr 5, 2017 10:50 PM by carlosr56034200
    unable to build an android apk
    carlosr56034200 Level 1
      using:
      phonegap -v6.4.7
      cordova  -v6.5.0
      npm      -v4.3.0
      I get the following error when using the command: phonegap -d build android
      [36m[phonegap] [39m executing 'cordova -d build android ' ...
      No scripts found for hook "before_build".
      No scripts found for hook "before_prepare".
      Checking config.xml for saved platforms that haven't been added to the project
      Checking for any plugins added to the project that have not been installed in android platform
      No differences found between plugins added to project and installed in android platform. Continuing...
      Generating platform-specific config.xml from defaults for android at W:\gap\CameraApp\platforms\android\res\xml\config.xml
      Merging project's config.xml into platform-specific android config.xml
      Merging and updating files from [www, platforms\android\platform_www] to platforms\android\assets\www
      Wrote out android application name "helloworld" to W:\gap\CameraApp\platforms\android\res\values\strings.xml
      android-versionCode not found in config.xml. Generating a code based on version in config.xml (1.0.0): 10000
      Wrote out Android package name "com.phonegap.helloworld" to W:\gap\CameraApp\platforms\android\src\com\phonegap\helloworld\MainActivity.java
      Updating icons at res
      Updating splash screens at res
      Prepared android project successfully
      No scripts found for hook "after_prepare".
      Checking config.xml for saved plugins that haven't been added to the project
      No scripts found for hook "before_compile".
      ANDROID_HOME=F:\ANDROID\SDK
      JAVA_HOME=C:\Program Files\Java\jdk1.8.0_121
      Error: Error
          at Object.module.exports.check_gradle (W:\gap\CameraApp\platforms\android\cordova\lib\check_reqs.js:90:25)
          at GradleBuilder.prepEnv (W:\gap\CameraApp\platforms\android\cordova\lib\builders\GradleBuilder.js:161:23)
          at Api.module.exports.run (W:\gap\CameraApp\platforms\android\cordova\lib\build.js:152:20)
          at W:\gap\CameraApp\platforms\android\cordova\Api.js:345:43
          at _fulfilled (W:\gap\CameraApp\platforms\android\cordova\node_modules\q\q.js:834:54)
          at self.promiseDispatch.done (W:\gap\CameraApp\platforms\android\cordova\node_modules\q\q.js:863:30)
          at Promise.promise.promiseDispatch (W:\gap\CameraApp\platforms\android\cordova\node_modules\q\q.js:796:13)
          at W:\gap\CameraApp\platforms\android\cordova\node_modules\q\q.js:604:44
          at runSingle (W:\gap\CameraApp\platforms\android\cordova\node_modules\q\q.js:137:13)
          at flush (W:\gap\CameraApp\platforms\android\cordova\node_modules\q\q.js:125:13)
      I have tried to read all the docs I can get my hands on but have not found an answer.
      I'm following a YouTube tutorial and a pluralsight course. the pluralsight course seems to be out of date because the versions seem to be too out of date. the video seems more up to date.
