14 Replies Latest reply on Apr 11, 2017 9:13 AM by thomasp25902177
    Still Images as Image Sequence - XML Import
    mikkelf3580674 Level 1
      Hi.
      I'm trying to make life a bit easier by generating an XML file to quickly import a number of image sequences into a Premiere Pro project (PPro 2017.0.2 in case it matters).
      It almost works - but when I import this XML file into premiere, it imports the first file in the sequence as a Still Image rather than an image sequence.
      The path to the file is correct, and the first frame does show up just fine.
      It feels like it's only a small change that's required, but I have not been able to find any information on it anywhere.
      Xml download
      Since the (sample) XML is very short, I also included it here (the real file has a few hundred clips, they all behave the same way).
      I tried manually importing an image sequence into premiere and exporting the result as FinalCut XML, but if I re-import that file, it also gets imported as a Still Image, so no help there.
      <?xml version="1.0" encoding="UTF-8"?>
      <xmeml version="4">
        <bin>
          <name>mpf_07 Images</name>
          <children>
            <bin>
              <name>Preview</name>
              <children>
                <clip id="mpf_07_01">
                  <duration>229</duration>
                  <in>0</in>
                  <out>229</out>
                  <name>mpf_07_01</name>
                  <media>
                    <video>
                      <track>
                        <clipitem id="clipitem-Preview-mpf_07_01">
                          <name>clipitem-Preview-mpf_07_01</name>
                          <file id="file-Preview-mpf_07_01">
                            <name />
                            <pathurl>E:\mpf_07_01.0101.jpg</pathurl>
                            <rate>
                              <timebase>24</timebase>
                              <NTSC>FALSE</NTSC>
                            </rate>
                            <duration>320</duration>
                            <timecode>
                              <rate>
                                <ntsc>FALSE</ntsc>
                              </rate>
                              <string>00:00:00:00</string>
                              <frame>0</frame>
                              <displayformat>NDF</displayformat>
                              <reel>
                                <name />
                              </reel>
                            </timecode>
                            <media>
                              <video>
                                <samplecharacteristics>
                                  <width>2048</width>
                                  <height>1126</height>
                                </samplecharacteristics>
                              </video>
                            </media>
                          </file>
                        </clipitem>
                      </track>
                    </video>
                  </media>
                  <rate>
                    <NTSC>FALSE</NTSC>
                  </rate>
                </clip>
              </children>
            </bin>
          </children>
        </bin>
      </xmeml>
