• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Lightroom does not see a new Camera Calibration Profile
New Here ,
Apr 06, 2017 Apr 06, 2017
I created a new profile for Infared images using the Adobe DNG Profile Editor.
The new profile is created OK and resides where it should in the in the C:\Users ....Appdata\Roaming\etc directory ok. However when I open a DNG file the dropdown box under Profile only displays Embedded.
Any ideas why the new profile is not on the list?
Roy
Views
349
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate , Apr 06, 2017 Apr 06, 2017
Because camera profiles are applied to Raw data (whether in maker's format or dng format) as the necessary first step in the processing that leads to the creation of an RGB image file (tiff. psd or jpg) and whatever profile was used to start the process, together with all the other editing that was done, has been "baked into" the image - i.e. "embedded" in it. The appearance of that display usually indicates that you are loading a rendered image - a jpg or a tiff. However, a DNG file that has be
Votes
Translate
Translate
Advocate ,
LATEST
Because camera profiles are applied to Raw data (whether in maker's format or dng format) as the necessary first step in the processing that leads to the creation of an RGB image file (tiff. psd or jpg) and whatever profile was used to start the process, together with all the other editing that was done, has been "baked into" the image - i.e. "embedded" in it. The appearance of that display usually indicates that you are loading a rendered image - a jpg or a tiff. However, a DNG file that has been previously edited while the option to save metadata to xmp is activated or has been exported from LR will have a profile "embedded" in its metadata.
Votes
Translate
Translate
Report
Report
