3 Replies Latest reply on Dec 15, 2008 7:38 AM by Newsgroup_User
    Custom event
    Bilbo1984 Level 1
      Hi
      i've a problem..anibody can help me?
      i created this class:
      public class CompleteEvent extends Event
      private var array:ArrayCollection
      public function CompleteEvent(type:String, array:ArrayCollection)
      super(type);
      this.array = array;
      public override function clone():Event {
      return new CompleteEvent(type, array);
      the main class create the array through a socket connection within the socket listeners for Socket.DATA...the socketdata method listeners dispatch the event...
      [Event(name="newEvent", type="CompleteEvent")]
      public class MainApp{
      socket.addEventListeners(ProgressEvent.SOCKET_DATA, socketData);
      private function socketData(event:Event):void {
      ...some code to create array from server data...
      //dispatch event
      var dipsatcher:EventDispatcher = new EventDispatcher();
      var ev:CompleteEvent = new CompleteEvent("newEvent", array);
      dispatcher.dispatchEvent(ev);
      and this other class listens for the event
      public class BasePanel extends Panel
      private function dataEventHandler():void {
      trace("Array retrieved");
      public function BasePanel()
      super();
      this.addEventListener("newEvent", dataEventHandler);
      but not working...the BasePanel class doesn't listen for the event..
      thanks a lot
      Regards
      Lorenzo
        • 1. Re: Custom event
          Level 7
          "Bilbo1984" <webforumsuser@macromedia.com> wrote in message
          news:gi5hjd$e5r$1@forums.macromedia.com...
          > Hi
          > super(type);
          > this.array = array;
          > socket
          > event...
          > //dispatch event
          > super();
          "this" isn't what's dispatching the event. Instead, you have an
          eventDispatcher that you create within the scope of a function (so you can't
          add a listener on it) dispatching the event. You have taken away the parts
          of the code that make an event bubble, and I suspect your class isn't on the
          display list anyway.
          HTH;
          Amy
          • 2. Re: Custom event
            Bilbo1984 Level 1
            Hi Amy,
            can you explain me what is the error...i don't undestand what do you mean?
            can you post me a little sample..
            thanks a lot
            Regards Lorenzo
            • 3. Re: Custom event
              Level 7
              news:gi5srr$rhq$1@forums.macromedia.com...
              > Hi Amy,
              > thanks a lot
              > Regards Lorenzo
              You may find this helpful:
              http://flexdiary.blogspot.com/2008/11/implementing-ieventdispatcher.html
              Then listen to the instance of the class that implements IEventDispatcher,
              _not_ the class that's doing the listening.
