0 Replies Latest reply on Dec 10, 2008 6:27 AM by swanley007
    Go To Slide On Test Failure Does Not work
    swanley007
      Hello All;
      I am using PPT to create a simple presentation, with a one question quiz at the end. I have set the pass to 100% etc. Upon fail I have it set to jump to slide 1. Upon pass continue to next slide. Attempts set to 999. My problem is that when the user enters the incorrect answer failing the quiz there is a minus sign in the navigation bar to the right and nothing happens. When the user enters the correct answer, the presentation continues to the next slide. I was wondering if someone could help with this issue, maybe providing a step-by-step example if is not a simple fix. Also, I have removed the summary page and the introduction page as I simply want the one question quiz. Thank You all, in advance, that help.
