0 Replies Latest reply on Dec 15, 2008 10:26 AM by Toadsteraz
    RDS CRUD Wizard HELP
    Toadsteraz
      Ok I used the RDS CRUD Wizard which is an extension for Flex3. I created Bean/DAO style CRUD CFCs using the wizard which gave me the following files
      A Bean CFC, also called a Value Object, which contains the property definitions and get and set methods.
      The DAO CFC, which contains the following methods:
      read(primary key value)
      create(cfc instance)
      update(cfc instance)
      delete(cfc instance)
      Data Service assembler CFC, which includes a Bean (also referred to as a Value Object), a DAO CFC, and an assembler CFC. The assembler CFC is required to take advantage of the Flex Data Services feature.
      Now that I have these CFCs, HOW do I use them in Flex? In other words how do I send parameters into these CFCs in Flex and return results.
      Such as letting me send in a primary key and getting Content back (string).
