• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
replace paragraph return inside specific xml tag
Community Beginner ,
Apr 08, 2017 Apr 08, 2017
Hello Everyone,
I need help to replace within one specific xml tag, <Name>, all paragraph return with a Line break and keep the paragraph return that is already at the end of the tag.
Paul
TOPICS
Scripting
Views
1.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor , Apr 10, 2017 Apr 10, 2017
You have to adapt this code snippets to your situation, e.g. ...
var _rootXMLElement = app.activeDocument.xmlElements.firstItem();
var _nameXMLElements = _rootXMLElement.evaluateXPathExpression("//Name");
for(var i=0; i<_nameXMLElements.length; i++) {
    app.findGrepPreferences = NothingEnum.nothing;
    app.changeGrepPreferences = NothingEnum.nothing;
    app.findGrepPreferences.findWhat = "~b(?=[^~b])";
    app.changeGrepPreferences.changeTo = "\n";
    _nameXMLElements.changeGrep(true);
    app
Votes
Translate
Translate
Contributor ,
Apr 09, 2017 Apr 09, 2017
Hello Paul,
you can try this ...
Get xml elements with evaluateXPathExpression:
RootXMLElement.evaluateXPathExpression("//Name")
And change the paragraph returns in this xml elements with changeGrep in a loop:
XMLElement.changeGrep(true);
Roland
Votes
Translate
Translate
Report
Report
Hello Roland,
Thank you for your help. I am getting an error message "RootXMLElement is undefined".
Could you please help? I am truly a beginner in Javascript.
Thank you again.
Votes
Translate
Translate
Report
Report
Contributor ,
Roland
Votes
Translate
Translate
Report
Report
Hi Roland,
Thank you again for your support. Unfortunately the code still showing the error " undefined is not an objet". I am not sure what to do.Error.PNG
Votes
Translate
Translate
Report
Report
Participant ,
The first line add;
#target indesign
Votes
Translate
Translate
Report
Report
Thank you uniqued_tol​ but now I am getting : Result: undefined
Votes
Translate
Translate
Report
Report
Apr 11, 2017 Apr 11, 2017
Hello Everyone,
I am getting result: undefined. And after running the script in indesign nothing change in the document.
Can you please help.
Votes
Translate
Translate
Report
Report
People's Champ ,
Apr 13, 2017 Apr 13, 2017
The console would only log what YOU would return. As your code returns anything but undefined, console displays…
Votes
Translate
Translate
Report
Report
Yes, I understand. So what should I do?
Votes
Translate
Translate
Report
Report
People's Champ ,
//Some code
//some code
//some code
"yolo" //will output "yolo" in the console
or if you are using a function
function yolo() {
return "yolo";
yolo();
Votes
Translate
Translate
Report
Report
People's Champ ,
var count = 0;
    count+=_nameXMLElements.changeGrep(true).length;
alert(count+" replacements have been made…");
Votes
Translate
Translate
Report
Report
Thank you so much, Loic.AigonThe script is working now. Also my many thanks to drerol74 uniqued_tol
Votes
Translate
Translate
Report
Report
People's Champ ,
You could have scored drerol74​ as I mostly used his snippet here
Votes
Translate
Translate
Report
Report
LATEST
Yes, You are right. I will do that. Sorry.
Votes
Translate
Translate
Report
Report
Can you please suggest the code I should put to have the result. The problem actualy is that when I run the code in Indesign nothing happen. All I wanted to do is : to replace within one specific xml tag, <Name>, all paragraph return(\r) with a Line break(\n) and keep the paragraph return that is already at the end of the tag.
Thanks for your help.
Votes
Translate
Translate
Report
Report
