Yeah as the titel said, how to remove Faux Finish brush preset completely for example.
I want all the brush presets like DP Brushes and Calligraphic gone completely, if possible : )
It is possible to delete the brushes but not the whole presets. And if I switch from a preset to another then the deleted brushes is still avalible under the presets.
So all in all. I would like to all my brush presets completely gone : )
(Reason I maybe have a little OCD, it's a mess for me to have something I don't use)
I'm guessing that you have reset the brush panel so you are only left with the default standard set? The Calligraphy brush set is one of those installed with Photoshop, and can be found in the location shown below. (click to expand to see easier)
If you have additional brush sets, thei location will depend on where you put them, but I like to use the 'App Data\Roaming...' location.
You can delete these sets, or change the file extension to something like .bak. Or you can modify the sets with th
...Copy link to clipboard
You can delete these sets, or change the file extension to something like .bak. Or you can modify the sets with the Preset Manager
