Export Video is not in 4k as chosen but much smaller after exportieren Trier it Severin Times The Video is 28 MB and not 5 GB weich ist chose after export
I'm using Premier Elements 15 with footage from two Panasonic 4K cameras. I don't have your problem. Perhaps you can go through your steps and I may be able to help.
Bill
I could upload all 4k footage and cut it. When I want to save it on my computer I chose 264, 4k and demand vor a 5.16 Gb HD Version before I render and save it. But after Export the film has just 68 MB on my computer. I can not screen it in this size! I retried it several times but nothing changed. I never had this downsize Problems with Elements 11.
You are not offering to supply the steps you are taking, so there is little room to guess why you are getting what you are getting.
Try this:
Export&Share > Devices > Custom > Advanced Settings (button) > Match Source (button).
Then check the bit rate settings. They should be about the same as your source.
Good luck!
I have the same problem, I use Sony a6500, settings are as follows size 1,98 GB
but after export file has size 42,1 MB and quality is very bad
but in properties you can see 4K
