• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
2017CC Crash Problem
Explorer ,
Apr 10, 2017 Apr 10, 2017
Strange. Booted PSD this morning and program is crashing as soon as you try to work. It's not hanging on open and I am not getting a the crash window. Checked preferences, reloaded program, ran windows scan and still stuck. Here is the report. Any help would be appreciated - dead in the water.
Faulting application name: Adobe Spaces Helper.exe, version: 0.0.0.0, time stamp: 0x58c11b5f
Faulting module name: libcef.dll, version: 3.2924.1537.0, time stamp: 0x584a4ed5
Exception code: 0xc0000005
Fault offset: 0x0000000000147fc5
Faulting process id: 0x1bd0
Faulting application start time: 0x01d2b23c5876fdd1
Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\Spaces\Adobe Spaces Helper.exe
Faulting module path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\Spaces\libcef.dll
Report Id: d8459460-1e2f-11e7-8259-b4b52fe05606
Views
892
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Apr 10, 2017 Apr 10, 2017
What Win version are using? Did you install the 18.1 update that was posted last week, or is this 18.0.1?
regards,
steve
Votes
Translate
Translate
Adobe
Adobe Employee ,
regards,
steve
Votes
Translate
Translate
Report
Report
Explorer ,
Running Windows 7 Pro. I do not see an update in the history that ran last week. Running a check for updates right now to see - will get back when I get the update.
Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
libcef.dll that is from Chromium Embedded Framework architecture, responsible for everything in audio and video.
Make sure your video driver and audio driver are up to date
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Another thing to try if you don't get locked out first. Launch Ps, then go to Help> System Info... and copy the text in there.
And, have you tried launching Ps via double click on a PSD?
regards,
steve
Votes
Translate
Translate
Report
Report
Explorer ,
I found an issue. Somehow windows has not been auto updating. Last update received was 11 weeks ago. I manually set it to update and it's still waiting so left it for overnight. Will get back as soon as it's fully updated.
Thanks again for the assistance
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 15, 2017 Apr 15, 2017
Still having trouble. Updated the Windows System and fixed that problem. Made sure all drivers are updated. Photoshop is running and not crashing but some of the features are not working and when I close the document it crashes.
I checked others programs and everything is fine. Premiere is running with 4 layers of video so the card seems fine.
Here is the lastest crash log and the help log from PSD
Thanks again for help.
The program Photoshop.exe version 18.1.0.207 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
Process ID: 1028
Start Time: 01d2b61f648e8de3
Termination Time: 188
Application Path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
Report Id:
Adobe Photoshop Version: 2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877  x64
Number of Launches: 6
Version: 7 SP1
System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 3591 MHz
Built-in memory: 16311 MB
Free memory: 2 MB
Memory available to Photoshop: 14532 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
It's running. Reload from scratch again, cleaned pref files and it going.
Thanks for all the help.
Votes
Translate
Translate
Report
Report
