1 Reply Latest reply on Apr 11, 2017 9:39 AM by johnrellis
    How to change a font dynamically?
    Griffel Level 1
      At a dialog I try to change a font dynamically. "Dynamically" means, changes of the font name and size by changes of related controls should affect the font of a static text (or edit field) immediatetly – not only if the values are stored at preferences and read by a subsequent call of the dialog. A test script:
      local LrDialogs = import 'LrDialogs'
      local LrView = import 'LrView'
      local LrFunctionContext = import 'LrFunctionContext'
      local LrBinding = import 'LrBinding'
      local LrPrefs = import 'LrPrefs'
      local LrLogger = import 'LrLogger'
      local log = LrLogger('TestLogger')
      log:enable('logfile')
      local f = LrView.osFactory()
      local bind = LrView.bind
      local prefs = LrPrefs.prefsForPlugin()
      local text = 'Lorem ipsum dolor sit amet, consectetur adipisici elit, ...'
      LrFunctionContext.callWithContext ('showPreview', function(context)
        local props = LrBinding.makePropertyTable(context)
        props.font_name = prefs.fontName or 'Courier'
        props.font_size = prefs.fontSize or 12
        log:trace('Read: ' .. props.font_name .. '/' .. props.font_size)
        local previewText = f:static_text {
          title = text,
          font = {
            name = props.font_name,
            size = tonumber(props.font_size)
        local function updateFont()
          previewText.font = {
            size = tonumber(props.font_size),
          log:trace('Change: ' .. props.font_name .. '/' .. props.font_size)
        end
        props:addObserver('font_name', updateFont)
        props:addObserver('font_size', updateFont)
        local contents = f:column {
          spacing = f:control_spacing(),
          bind_to_object = props,
          previewText, -- defined above
          f:separator { fill_horizontal = 1 },
          f:row {
            f:static_text { title = 'Font Name:' },
            f:combo_box {
              value = bind 'font_name',
              width_in_chars = 10,
              immediate = true,
              items = {
                'Courier', -- Mac
                'Courier New', -- Win
                'Lucida Console', -- Win
                'Monaco', -- Mac
            f:static_text { title = 'Font Size:' },
            f:combo_box {
              value = bind 'font_size',
              width_in_chars = 2,
              immediate = true,
              precision = 0,
              items = { 10, 12, 14, 16, },
        LrDialogs.presentModalDialog({
          title = 'Font Change Test',
          contents = contents,
        log:trace('Save: ' .. props.font_name .. '/' .. props.font_size)
        prefs.fontName = props.font_name
        prefs.fontSize = props.font_size
      end)
      The problem is: It works on macOS, not on Windows.
        • 1. Re: How to change a font dynamically?
          johnrellis Most Valuable Participant
          Some of these restrictions are documented, many not.  (For example, "background_color" of scrolled_view() cannot be dynamically changed on Windows.)
          I worked around the restriction by using two overlapping static_text() controls, one with regular font and one with bold, with the visibility of each dynamically controlled.
