• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
access to _root from remote loaded swf
Guest
Apr 11, 2017 Apr 11, 2017
Hi. please help me. I have a AS2 program called Main.swf. It loads another(not mine) program (call it Base.swf). Both of these files are located locally on my computer. I load into my program Mine.swf an external file load.swf.
//Main.swf
System.security.allowDomain('*');
this.createEmptyMovieClip('module', 0);
module.loadMovie('http://192.168.10.102/loaded.swf');
From the loaded.swf file, I try to access _root which should be equal to Base.swf. But I can not do it. Although from the file Main.swf I can access _root.
//Main.swf
_root.someFunctionFromBase(); //it work
module._root.someFunctionFromBase(); //even so works
//loaded.swf
_root.someFunctionFromBase(); //undefined
How can I access variables and functions in _root from the loaded file?
TOPICS
ActionScript
Views
885
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Apr 14, 2017 Apr 14, 2017
Main loads loaded and Main loads Base?
Votes
Translate
Translate
Report
Report
Guest
Apr 15, 2017 Apr 15, 2017
Sorry, probably not correctly explained. The sequence is as follows: Base <- Main <- loaded
Votes
Translate
Translate
Report
Report
Community Expert ,
Apr 16, 2017 Apr 16, 2017
if you want to reference objects in Main from loaded, use _parent.
Votes
Translate
Translate
Report
Report
Guest
no. I want to refer to objects in Base.swf from a loaded.swf
Votes
Translate
Translate
Report
Report
Community Expert ,
use _parent._parent
Votes
Translate
Translate
Report
Report
Guest
this does not work. Files Main.swf and Base.swf - local, and loaded.swf - remote. If I load a loaded.swf from the local, everything works. But if I load the file from the http server - I can not access _root. That is the problem.
Votes
Translate
Translate
Report
Report
Community Expert ,
then you probably have a timing issue.  _parent._parent is the correct path if you explained the loading correctly.
Votes
Translate
Translate
Report
Report
Guest
It seems to me that the problem is with some limitations of security. Because the problem only occurs when load file from a remote location. I repeat that when I load file from a local location(from the same directory where Main.swf is located), I can access _root, _parent._parent, etc.
Votes
Translate
Translate
Report
Report
Community Expert ,
Apr 17, 2017 Apr 17, 2017
or timing.
Votes
Translate
Translate
Report
Report
Guest
This is not a timing. I see when the loaded.swf is added to the Main and only after that I try access to _root. I'm sure that at this point in time the file is already loaded.
Votes
Translate
Translate
Report
Report
Community Expert ,
what's the url to Base?
Votes
Translate
Translate
Report
Report
Guest
Base.swf and Main.swf are local files. They are located on my computer. And loaded.swf it remote file, located on my web server. I will try to explain in more detail: Base.swf is the main application (it is quite large and complex). Main.swf is simply a loader that loads an external file (loaded.swf) as a plug-in that will later work with objects and functions of Base.swf. But if I load a loaded.swf from a web server, and not from a local location, then I can not access _root from it. Sorry for my bad english =(
Votes
Translate
Translate
Report
Report
Community Expert ,
that is a security issue.
check the Security class'es allowDomain() method.
Votes
Translate
Translate
Report
Report
Guest
LATEST
I have already tried everything that is possible with a security class. I guess that the problem is with security, but I can not understand what exactly will solve this problem.
Votes
Translate
Translate
Report
Report
