• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
IDML file corruped
Community Beginner ,
Apr 11, 2017 Apr 11, 2017
After export the design file with XML structure as an IDML file. the IDML file not getting opening. How to fix this issue.
TOPICS
Scripting
Views
392
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged ,
Export as IDML and open that and save again.
If this does nt work, save as IDML without opening the file. This is possible via script.
If this does not work use your latest backup.
Prabu
Design smarter, faster, and bolder with InDesign scripting.
Votes
Translate
Translate
Report
Report
When i open the exported idml file its getting corrupted
Votes
Translate
Translate
Report
Report
Any idea? How to solve the issue
Votes
Translate
Translate
Report
Report
Engaged ,
below link helpful to you:
Cannot open an idml file created in CS5.5 in either CS5 or CS5.5
Prabu
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi Ananth,
your link is not working…
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Here again the link:
Hope it is working…
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Community Expert ,
what exact version of InDesign on what OS?
Is there an error message if you open the IDML?
Without seeing the document I see no chance that anybody can help.
It might be that the InDesign document is already corrupted.
Two things you could try:
1. Save the document to a new name with Save As.
2. Move all pages to a new document and proceed from that.
If that will not help you could try a divide and conquer algorithm.
Save your document two times with new names using Save As.
First document delete the first half of the pages, second document delete second half of the pages.
Always do a Save As after removing the pages.
Now try to export to IDML each of the documents.
Go on with the divide algorithm until you single out a page or a range of pages where you see the problem.
Then tackle the problem by removing objects on the page.
Regards,
Uwe
Votes
Translate
Translate
Report
Report
