• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Event for changed ActiveSequence
Engaged ,
Apr 11, 2017 Apr 11, 2017
is there an event allowing us to create a listener for a change of the active sequence, i.e. if a different (already open) sequence is being activated, or another sequence is opened from the project window? I don't really want to use an interval timer for polling..
Cheers,
Erik
TOPICS
SDK
Views
373
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Apr 11, 2017 Apr 11, 2017
There is no such message.
Instead of polling, why not just check the active sequence, before doing anything?
Votes
Translate
Translate
Adobe Employee ,
Votes
Translate
Translate
Report
Report
Engaged ,
Bruce,
the intention is to populate a read-only textfield with the sequence name for the purpose of cross-checking, before the user hits the export button next to said text field, which will trigger a custom export process. I want to circumvent having an "update" button, or use panel focus/click events, that's always one click more than necessary. The ideal solution would be to have non-blocking events, alternatively I prbably would have to use an interval-based poll, but only when the panel is visible to the user. I think there is a switch for this...correct? To check if a panel is active (not focused, but visible in the GUI)?
Erik
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Yes, you can tell if an extension is open or not; see CEP HTML Test Extension.
Perhaps your panel could enable/disable the export button, after confirming whether the current active sequence is the same as the previously noticed active sequence?
Votes
Translate
Translate
Report
Report
Engaged ,
Okay, so there is (currently) no way to "know" programmatically if the
panel is visible, just open or closed.
I was also thinking about pausing the interval timer whenever PPro is
"idle", i.e. not playing back, mouse button is pressed etc., basically
excluding "global" states that might be disturbed by a timed blocking
method. Do you reckon this is feasible, because the "exclusion list" might
be quite vast?
Erik
Votes
Translate
Translate
Report
Report
Adobe Employee ,
LATEST
We don't recommend interval timers, at all.
I'd recommend checking the active sequence immediately after the user clicks that button, and fail out if the current sequence is incorrect.
Votes
Translate
Translate
Report
Report
