4 Replies Latest reply on May 24, 2017 5:34 PM by Kevin-Monahan
    Image sequences cut to black randomly two thirds into timeline
    CR_Studio
      We do stop-motion animation and use After Effects to do clean-up work, comping and grading as a regular activity. Most rushes we process are 5184 pixels wide and we've had no trouble with CS4 and upwards to CS6, other than the usual lag when layering up to multiple levels and adding effects, which is to be expected. Since upgrading to CC we've noticed that AE won't cope with a simple image sequence. The timeline cuts to black at an arbitrary point around 2/3rds in making post-production near to impossible. There is also black on any renders we attempt to export. The only way we can work with the animation rushes is to import the entire folder of Jpegs and sequence them in a comp which is slow and laggy, even more so with RAW images, which we sometimes need. We have 2 macs with the same problem, spec as follows:
      iMac (Retina 5k, 27-inch, Late 2015)
      Processor 4 GHz Intel Core i7
      Memory 32GB 1867 MHz DDR3
      Graphics AMD Radeon R9 M395X 4096 MB
      Wondered if anyone else has experienced this issue.
      Chris
