• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Photoshop "Select and Mask" Tool throws Program Error message (Mac 10.12.4)
New Here ,
Apr 11, 2017 Apr 11, 2017
Hi everyone!
I've been looking all over the Internet about this issue, have tried almost everything, and still can't find a solution.
I am currently working on an image that requires me to make a selection, and then use the Select and Mask tool to make a composite. After making my selection and opening Select and Mask, I tried to select the "Onion Skin" option to help select some hair on my subject.
I am met with an error message that simply reads: "Could not apply the workspace because of a program error."
I noticed that this is something that happened AFTER updating my MacBook to Sierra 10.12.4, and updating my Photoshop CC to the most current version.
I also noticed that this error message shows up when I try to apply the "Onion Skin" to images that I open in Photoshop CC through Lightroom CC (via Photo/Edit In/Photoshop CC 2017), but not with images that have been opened and edited in the updated version of Camera RAW. I think it's worthy to note that my Lr CC has been updated as well.
From previous threads, I was able to at least find my Library folder and locate the PSErrorLog.txt file and found this:
2017:04:11 13:20:15 : /Volumes/workarea/PS_18.1_Mac_Daily_Retail/20170309.r.207/photoshop/main/photoshop/sources/SmartBrushTool.cpp : 3367 : REQUIRE failed
2017:04:11 13:22:02 : /Volumes/workarea/PS_18.1_Mac_Daily_Retail/20170309.r.207/photoshop/main/photoshop/sources/SmartBrushTool.cpp : 3367 : REQUIRE failed
2017:04:11 13:31:20 : /Volumes/workarea/PS_18.1_Mac_Daily_Retail/20170309.r.207/photoshop/main/photoshop/sources/SmartBrushTool.cpp : 3367 : REQUIRE failed
2017:04:11 13:31:25 :            0xb50 of type P5_ADsc not found : 1 : REQUIRE failed
2017:04:11 13:31:25 : /Volumes/workarea/PS_18.1_Mac_Daily_Retail/20170309.r.207/photoshop/main/photoshop/xcode/../interfaces/UTrackResourceImp.h : 137 : REQUIRE failed
2017:04:11 13:31:25 :            0xb58 of type P5_ADsc not found : 1 : REQUIRE failed
2017:04:11 13:31:25 :            0x1d8 of type P5_ARef not found : 1 : REQUIRE failed
2017:04:11 13:38:26 :            0xb30 of type P5_ADsc not found : 1 : REQUIRE failed
2017:04:11 13:38:26 : /Volumes/workarea/PS_18.1_Mac_Daily_Retail/20170309.r.207/photoshop/main/photoshop/xcode/../interfaces/UTrackResourceImp.h : 137 : REQUIRE failed
2017:04:11 13:38:26 :            0x198 of type P5_ARef not found : 1 : REQUIRE failed
2017:04:11 13:38:26 :            0xb28 of type P5_ADsc not found : 1 : REQUIRE failed
2017:04:11 13:39:04 : /Volumes/workarea/PS_18.1_Mac_Daily_Retail/20170309.r.207/photoshop/main/photoshop/sources/SmartBrushTool.cpp : 3367 : REQUIRE failed
2017:04:11 13:39:32 : /Volumes/workarea/PS_18.1_Mac_Daily_Retail/20170309.r.207/photoshop/main/photoshop/sources/SmartBrushTool.cpp : 3367 : REQUIRE failed
2017:04:11 13:41:34 : /Volumes/workarea/PS_18.1_Mac_Daily_Retail/20170309.r.207/photoshop/main/photoshop/sources/SmartBrushTool.cpp : 3367 : REQUIRE failed
2017:04:11 13:44:08 : /Volumes/workarea/PS_18.1_Mac_Daily_Retail/20170309.r.207/photoshop/main/photoshop/sources/SmartBrushTool.cpp : 3367 : REQUIRE failed
Unfortunately, I'm not THAT savvy, so I'm not sure what these necessarily mean... Are there tools/applications within my Photoshop that are misbehaving and causing other tools to stop working, or is there something deeper going on?
I also don't know if other tools have been affected by the same error, so far it's just the tools within "Select and Mask" tool that don't work. I understand that other people have had the same message pop up with other tools, and somehow have been able to fix their issues. All attempts to try what worked for them have done nothing for me.
If someone could help me figure out what's going on with my Ps CC, I would really appreciate it!
Thanks!
-Miki
Views
704
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Enthusiast ,
You've got other issues with your Mac.
Onion Skin works fine on my MAC Mini 10.12.4 OS.
Make sure your graphics card/chip has the latest drivers.
Make sure you have enough internal memory and Hard Drive free space.
It's not Photoshop giving you the grief.
Joe
ps: I'm using Photoshop 2017.1.0  (the latest).
Votes
Translate
Translate
Report
Report
New Here ,
Apr 12, 2017 Apr 12, 2017
Hi Joe,
I just now checked the internal memory, and I have ample space left. Also, wouldn't the graphics card/chip's drivers be updated with the new OS X Sierra update that I just installed or is there more to it?
Thanks!
-Miki
Votes
Translate
Translate
Report
Report
New Here ,
I'm not sure if this helps, but these are the graphics drivers that I am working with. According to Adobe's website, both are current.
Could there possibly be something wrong with Lightroom CC? It seems that when I open an image from there into Photoshop, things go wrong.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Yes Apple updates to the OS include all elements of the hardware including the graphics card/chip.  There is no path to just do the graphics card/chip.  If Apple gets an updated driver from the vendor AMD-Radeon, then Apple will post the update into the Apple Store for just that option and notify you.
So, you are current as is pertains to the Apple Hardware drivers and OS.
Since I have no problems with the same environment, your should probably elevate this problem directly to Adobe Support.
Sorry I couldn't help.
Joe
ps:  If your image is a 16bit image, try 8 bit.  Sometimes 16 bit images have special issues.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 13, 2017 Apr 13, 2017
LATEST
I ended up having a representative take over my computer, it turned out that some of the updates didn't sync completely in Photoshop, I have no idea how. But everything works now!
Thanks again for taking the time out and responding.
Votes
Translate
Translate
Report
Report
